djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Thu May 08, 2014 6:49 pm Post subject: |
Where all that comes together there are three sheets of metal in thickness. The piece that covers the end of the rocker section is actually folded off of the outer skin that is the inner wheel well but behind the mud plate. It folds out and has the hole for the wire tube. Part of the heater channel goes in about 6 inches behind that and I believe part of the A pillar/door frame also sandwiched over all that on the cabin side. I believe that piece continues on to make the inner wheel well and spare tire area. The fender goes onto the lower lip all that creates. I found a front A pillar clip from a wreck once and dissected it to see how things went together. Lots of overlaps for strength. |
ScottDoonan Samba Member
Joined: August 04, 2005 Posts: 546 Location: Northern California
Posted: Thu May 08, 2014 7:25 pm Post subject: |
Hey Dave I have more photos for that section. If you need them just PM me. Sounds like you got it figured, but if I can assist just let me know. _________________ If you take time to do it, do it right and don't be so damn cheap.....🤙🏻
1959 Karmann Ghia Cabriolet (current restoration)
1965 Porsche 356 SC coupe
1967 Volkswagen Convertible Beetle
1969 Porsche 911E Targa 3.2 twin plug
2006 Porsche 987 Rüf 3400K Prototype #2 of 2 |
Porschedave Samba Member
Joined: July 01, 2004 Posts: 454 Location: Vancouver, Canada
Posted: Tue Oct 07, 2014 9:13 pm Post subject: rocker assembly |
Hi Folks
It's been a while since I was able to get to the Ghia - had to sell the notch and finish other projects, or at least move them along. I have now completed the restoration of the passenger-side rocker and will share a few pictures here.
I have removed the rusty bits and made a new piece that will form the backbone of the rocker:
and then the supporting piece:
and painted
and finally the new outer section (purchased from CIP) with the new wire harness tube in place
and that's it. I'm very pleased to be at this point, finally. Now I need to look at the driver's-side as it is in very poor shape.
Dave _________________ 1977 911S
1958 Karmann Ghia build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=571683
1965 Sunroof Notch build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?p=5600139&highlight=#5600139 |
Loren Samba Member
Posted: Tue Oct 07, 2014 9:38 pm Post subject: |
Did you flare the end of the wiring tube like this?
If not you might consider flaring it. There is supposed to be a rubber gromet that fits over this flare to keep moisture from getting into the tube. I know Danny Gabbard was selling a bent piece of tubing with the end flared, but I don't see his ad anymore. |
Tall Bloke Samba Member
Joined: October 07, 2005 Posts: 233 Location: UK>Ohio>UK
Posted: Thu Aug 13, 2015 1:03 pm Post subject: |
Any Updates Dave ? _________________ -------------------
All of 30 horses ! |
Posted: Thu Aug 13, 2015 1:50 pm Post subject: had some time for my '58 low light today |
Howdy
Well, yes, it has been quite a while since I last posted here. I got distracted. A friend of mine ended up with a '64 356 Porsche. He had been mis-lead about its state and what it needed to get it on the road. So, we moved the low light to his garage and his 356 to my garage and for the past 6 months I've been working on it. I have not created a thread here but there are pictures and part of the story at my site, here
http://www.sandersonmotorsports.com/Notch/Documents/Gerry's/Goal/index.html
(you'll have to copy the whole like I think)
It will be a while before I get back to the low light but I will.
Thanks for asking.
Posted: Tue Sep 13, 2016 5:29 pm Post subject: Re: Had some time for my '58 low light today |
Hi Folks
Well, the Porsche has been completed and is with the owner and now I am back working on the Ghia. Today i moved the pan into my workspace to get a closer look at it. Here's what I saw
The passenger side is repairable but the driver's side is toast. My first job will be to clean the old undercoat crap off and then come up with a plan of attack. Should be interesting.
calexican Samba Member
Joined: June 11, 2008 Posts: 730 Location: El Paso, TX
Posted: Tue Sep 13, 2016 8:11 pm Post subject: Re: Had some time for my '58 low light today |
Glad to see you are back in action. |
danny gabbard Samba Member
Joined: September 08, 2008 Posts: 588 Location: carson city. Nevada
Posted: Wed Sep 14, 2016 10:23 am Post subject: Re: Had some time for my '58 low light today |
http://www.thesamba.com/vw/classifieds/detail.php?id=1451581 Hi dave , I ave them if you need one ?? _________________ Shipping is NOT included in any of my products or parts. Just want to say thanks from GAB-FAB for any purchase!! |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
Posted: Wed Sep 14, 2016 12:19 pm Post subject: Re: Had some time for my '58 low light today |
Great! Glad to see you back in action on this, really enjoy your work. Looking forward to watching and learning. _________________ Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807 |
Posted: Sat Sep 24, 2016 4:38 pm Post subject: Re: Had some time for my '58 low light today |
Hey
Worked not he pan today, using my lift as a work bench. Got both pans off with not too much of a hassle. I used the drawings from Evil Fiz to check the dimensions (there were a couple of small differences, like the position of the seat rails but over all a good match). With the pans off I will take the centre trunck and have it blasted before I fit and weld in the new sections.
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Sat Sep 24, 2016 5:26 pm Post subject: Re: Had some time for my '58 low light today |
Porschedave wrote: |
...I used the drawings from Evil Fiz to check the dimensions (there were a couple of small differences, like the position of the seat rails but over all a good match). |
Post, or PM me, the dimensions in questions so I may amend the drawing. If you found any other differences beyond the seat tracks please include those as well. The more samples we get the better resource it will be.
We're all in this together,
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Fri Sep 30, 2016 5:09 pm Post subject: Re: Had some time for my '58 low light today |
Hi Folks
A couple of short notes. I cut away all of the rotten pan material and today the freshly sand blasted core came back looking absolutely beautiful. And as a bonus they were able to remove that incredibly stuck choke cable. John told me that they tied the pan to one forklift and the end of the cable to another. They then slowly pulled the cable with the one forklift until it popped out - I've included a picture of it - as you can see it is now very long. I have no ideas why it was stuck but am very pleased and thankful to John and Randy at B & W for going the extra distance for me. Now I blow on some epoxy primer and prep the new pan halves to weld them in place.
Bobnotch Samba Member
Posted: Sun Oct 09, 2016 7:55 am Post subject: Re: Had some time for my '58 low light today |
So today I welded the new pan halves in place.
It's Canadian Thanksgiving so I'll wait until later in the week to fix and install the seat supports.
Then maybe I'll get back to the body itself.
Dave |
Hi Dave, the pan is looking really good. I may have missed it, but where did you get the pan halves? Looking forward to seeing more progress as you continue to move along on this project.
Your buddy's Porsche turned out fantastic. Great job on that. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Oct 09, 2016 9:08 am Post subject: Re: Had some time for my '58 low light today |
Hi Bob
Hey, it was great to hear from you. The pan halves came from Cal Imports, located here in Vancouver but I think they were fabricated in Europe. The fit was not too bad although some reshaping was required. The seat rails are in mixed condition, but I should be able to repair and weld them in place this week along with the jack inserts and the metal work on the pan will be done. At that point I can bring the shell back to the garage (it's still in storage at my friend Gerry's place) and get to work on it.
