VWLooseNuts Samba Member
Posted: Tue Oct 08, 2013 7:05 am Post subject: 1956 Jungle Green |
drug home a 56 jungle green oval sunday.
I got an email from a friend that said he knows someone with an oval they are getting rid of. he told the owner that i would be a good person to own it. The owner emailed me and we wenthroughht the details and i told him i wanted it and would come get it from him Sunday. so after a long 500+ mile round trip it sits in my garage now.
as found. been here for 4 years
All tucked in the garage.
All the bits that came with it
Good working 12v tranny. neew seals. new brakes. new tires,
OG 36hp motor. unknow conditions but spins freely
correct H replacement apron
there is a fair amount of rust in the heater channels. both sides need to be replaced. Rust on the bottom of each door and rust in both rear quarters in front of the tires. _________________ Jeremy
www.vwloosenuts.com
www.facebook.com/VWLoosenuts
AlteWagen Troll
AlteWagen Troll
Posted: Wed Oct 09, 2013 7:41 am Post subject: |
anyone have a paint code for OG Jungle Green. or know of a paint color out there that is very close to the color.
any help would much appreciated
thanks _________________ Jeremy
www.vwloosenuts.com
www.facebook.com/VWLoosenuts |
AlanInMass54 Samba Member
Joined: August 29, 2003 Posts: 1070 Location: Massachusetts
Posted: Wed Oct 09, 2013 8:01 am Post subject: |
VWLooseNuts wrote: |
thanks |
Here it is! http://www.thesamba.com/vw/archives/info/paintcodestype1.php
L315! A very nice and not often seen color. |
Posted: Wed Oct 09, 2013 10:00 am Post subject: |
AlanInMass54 wrote: |
thanks |
yeah i should have clarified my question better. I know the paint code as shown in your link. I was more looking to see if anyone has a paint code from a todays paint supply company that matches the L315. I wasn't sure if i could call up DuPont or of the like and tell them i need jungle green L315?? _________________ Jeremy
www.vwloosenuts.com
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Wed Oct 09, 2013 10:27 am Post subject: |
Glasurit got it. Painted my car 21 years ago with Glasurit, people dont think it is that old (and I have never polished it). _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Posted: Sat Oct 12, 2013 5:43 pm Post subject: |
Replace the re apron today. I remove the apron and left the inner structure that the engine seal attached to. the replacement one was not the best and i wanted to keep as much OG paint as i could. took a Little long but am happy with the results
Before
After
www.vwloosenuts.com
Posted: Mon Oct 14, 2013 7:07 am Post subject: |
got the rear all complete. fitted the rear fenders " i know not correct year rear fenders" and installed the deck lid. things line up pretty good.
started in the on the front apron.passengersanger side was hit lightly at some point in its life. I removed the apron and innerwheele weel section. welded a bracket on the front of the quarter section and pitled ip out the best i could. didn't want to weld a right side clip on so i just pulled it out and hammer and dolly it.
Before
After
www.vwloosenuts.com
Posted: Thu Oct 17, 2013 7:23 am Post subject: |
while waiting on the front apron to show up i decided to cleanup the passenger side front quarter to see what the end result will look like.
removed some of the surface rust to get more green to show through. then clear coated it to see how it will look.
I LIKE IT A LOT!!
before the cleanup
after i removed the surface rust.
clear coat results. this is what the car will look like when done.
www.vwloosenuts.com
Posted: Sun Oct 20, 2013 6:56 pm Post subject: |
worked on both heater channel this weekend. passangers side just got some patch work. It wasn't as bad as the driver side.
Passanger side front inner fender repair
Passanger side heater cannel repair
started in on the priver side complete heater channel replacement
got it about 80% complete. got some patch pannle to complete yet.
www.vwloosenuts.com
JWDII Samba Member
Posted: Tue Oct 22, 2013 9:02 am Post subject: |
still winning!! _________________ this space for rent. |
Posted: Sun Nov 03, 2013 6:20 pm Post subject: |
been doing lots of work on the 56. replaced the pan halves. built a set of notched extended springplates. installed the trans and motor. found out the #1 cylinder seized to the side wall at some point. I was told that the motor probably needed rebuilt. Built the front safari window frame. started figuring out the shape rear safari window.
Progress Photos
Got to build the sliders for it so its just propped up for now.
Started shaping hte back to see if i can make the bends before bending up section.
www.vwloosenuts.com
Posted: Sat Nov 30, 2013 4:59 pm Post subject: |
with as many panels i have had to replace. Its at the point where its actually going to get repainted. If all the fenders, hoods and doors where OG then it would stay patina'd.
been doing some work
www.vwloosenuts.com
Erik G Samba Member
Joined: October 16, 2002 Posts: 13278 Location: Tejas!
