Dynamite_Goat Samba Member
Joined: March 24, 2007 Posts: 135 Location: Julian, CA
Posted: Thu Nov 27, 2014 7:49 am Post subject: |
richparker wrote: |
Brian wrote: |
those are some pretty shoes there. Whats the combo? |
15" Benz rims and KOs. Those ain't no Graibbers.
After all the failed attempts with the radiator in that location with subie swaps. It will be intresting to see how hot it gets.
You build is rad and I hope the best for it! |
Thanks. I learned a lot from others on the radiator set up. We'll see how it works once I get it out of the garage. Those are actually 14" Vanagon wheels with BFG A/T tires. |
GMATech Samba Member
Joined: September 03, 2012 Posts: 220 Location: South East Pennsylvania
Posted: Thu Nov 27, 2014 11:46 pm Post subject: |
Very nice. Sounds like you've got the wiring all figured out, but if you run into anything with the GM side of things I can help. _________________ 77 westfalia vr6 project
72 standard beetle project - for sale
ASE Master Tech since '03 A1-A9 L1 L3 G1
PA safety and emissions inspector
General Motors guru |
Posted: Tue May 12, 2015 7:11 am Post subject: |
Got a few miles on the road and the bus runs great BUT. . .the radiator is coming out of the engine compartment and going underneath. . . .
I simply can't get enough air flow through the engine compartment to keep it cool, even with the dual electric fans. If I run the fans as pullers, they turn the engine compartment into an oven and the intake air temperature goes off the charts. If I run the fans as pushers, the IAT stays low but the fans are completely inefficient and can't keep the motor cool - even with the battery tray cut out to allow additional airflow.
I do think that these issues could be resolved with various air scoops, vents, etc. but I'm heeding the advice of others and bailing out on this before I have hundreds of hours wrapped up in R&D on something that just isn't that necessary in the whole scheme of things. Plus it'll be nice to have that space back for my aux battery. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5778 Location: Los Alamos, New Mexico
Posted: Tue May 12, 2015 8:19 am Post subject: |
Dynamite_Goat wrote: |
I went with a 2.4L Ecotec VVT out of a 2008 Cobalt. Thought about the Subaru, but I'm already familiar with the GM stuff and really like this motor. I'm also shooting to make it California smog legal and figured I would have a better chance with this motor. |
I thought that California frowned on other-than original stuff in the engine room. Will it even be possible to make this smog-legal in CA? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Tue May 12, 2015 8:55 am Post subject: |
jtauxe wrote: |
I thought that California frowned on other-than original stuff in the engine room. Will it even be possible to make this smog-legal in CA? |
Yes, if you do your homework. OBD1 is pretty easy. For OBD2 you need to have all emissions systems in place and all of the readiness tests working. This basically requires transplanting the entire fuel and emissions system from the donor car. I'm ready to go - just need the blessing of the smog referee once I can get it to run cool.
For all the negative myths perpetuated on the internet about California, it's actually pretty simple if you just follow the rules. Once you get past the smog stuff, no annual safety inspections is a nice bonus. |
