mkriglet Samba Member
Posted: Mon Mar 03, 2014 8:16 pm Post subject: |
1/4" press-on to NPT 90° at the tank. Cant remember if the threads are 1/4" or 3/8". |
Posted: Mon Mar 03, 2014 8:27 pm Post subject: |
These are the guages and valves that I have. I'm not 100% sure where I'm going to mount them yet.I do have an Empi guage panel that mounts under the ashtray that they may end up in. I dont want to cut the car to install them. |
Posted: Mon Mar 03, 2014 8:34 pm Post subject: |
Here is one of the front air shock connections. I ran my air lines inside of 3/8 vinyl tubing anywhere it looked like they would be chaffed from vibration. I dont want to be stuck somewhere with a hole in my airline. |
Posted: Mon Mar 03, 2014 8:37 pm Post subject: |
The pump is mounted with stainless hardware. The wires and air lines are run into the car and are secured under the passenger footrest. |
Posted: Mon Mar 03, 2014 8:41 pm Post subject: |
Here is the pressure switch and relay with the footrest removed. |
Posted: Mon Mar 03, 2014 8:44 pm Post subject: |
If you need any other specific pics just let me know. |
Lucky Lager Samba Member
Posted: Mon Mar 03, 2014 9:00 pm Post subject: |
mkriglet wrote: |
Oh man great pics - those connections are so nice.. I may order those. Great pics - thanks so much for the time you spent getting those for me.
That color on your bug works soooooooo good! I can't wait to see your build continue
Thanks again I appreciate it !!! _________________ In the wild, health care is, Ow, I hurt my leg. I can't run. A lion eats me. I'm dead. |
Posted: Fri Apr 04, 2014 3:33 pm Post subject: |
A bunch of parts came in from Wolfsburg West, Fast Fab,J-bugs, and Crutchfield.I need to get moving on it now. |
Posted: Fri Apr 04, 2014 3:36 pm Post subject: |
Posted: Fri Apr 04, 2014 3:38 pm Post subject: |
Sand blasted the tank, and getting the rest of my parts ready for paint. |
Posted: Fri Apr 04, 2014 3:42 pm Post subject: |
Posted: Fri Apr 04, 2014 3:44 pm Post subject: |
Getting the air ride control panal ready for paint. |
grandpa pete Samba Member
Project_dog Samba Member
Joined: June 26, 2003 Posts: 65 Location: Spokane, Wa
Posted: Sat Apr 19, 2014 10:24 pm Post subject: |
Great looking build. |
Posted: Sun Apr 20, 2014 5:16 pm Post subject: |
You wont regret replacing the wiring harness. Well worth the money. I bought mine from WW. |
Posted: Sun Apr 20, 2014 5:17 pm Post subject: |
Posted: Tue Apr 29, 2014 6:18 pm Post subject: |
Started working on assembling the doors.Its not as bad as I thought it would be. I did find the outer scraper on the drivers door had a bad spot on the rubber and would not have prevented water from leaking in. I didnt see it till after it was installed. So I had to removed it and order another new one. Lesson learned...always check the parts you order as soon as they arrive.I had ordered the door rebuild kits a year ago so its out of any warranty. |
Posted: Tue Apr 29, 2014 6:24 pm Post subject: |
going together smoothly. |
Posted: Tue Apr 29, 2014 6:31 pm Post subject: |
Started breaking down the seats for paint and new covers.
Posted: Wed Apr 30, 2014 6:14 pm Post subject: |
installed the front turn signals and headlights. The front fenders are aftermarket so it was a challenge getting the headlights straight. |
