johan84 Samba Member
Posted: Sat Oct 26, 2013 2:23 pm Post subject: vw 1303 wrx sti powered 325hp+ project on the road!! |
hello
i though maybe some of you liked my swap
5 years ago i started with a 1972 vw beetle
the plan was to build a fast beetle with at least 300hp
intercooler intake both windows are moved 15cm about 6 inch inside in the rear
outlet is under the little wing on the back
youtube:
http://youtu.be/-2wilTC5Cs0
http://youtu.be/GrFrrbbncL0
http://youtu.be/fae2gHi20fE
http://youtu.be/L1PKfK_BaWE
car spec:
VW 1303 beetle 1972
engine
2002 subaru wrx sti (bugeye model) ej207 sti engine VF35 turbo
engine is stock
ecu: 2002 sti jdm ecu (i used jdm ecu because no need of immoblizer and keys instead of euro models)
ecu is ecutek remapped to 98 oct fuel and runs around 1,5 bar boost
should have at least 325hp+. it is not been on the dyno yet
rev.limit 7800rpm
i can get 120klm (75mph) in second gear
exhaust:
custom made 3" stainless steel with 2 magnaflow 4" mufflers
i'm driving with DB-killers it is now 2 times 2,25"
but it has no influence on the power or spool up of the turbo
but driving without db killers makes it like a rally car sound
there is a youtube link above
gearbox:
porsche 911(964) G50.03 5 speed gearbox incl shifter
that is modified to custom shifting linkage
clutch adapter kit
KEP: adapter kit
sachs stock 911 pressure plate
and high performance 6 puck kep clutch plate
spec can hold up to +/- 850nm
suspension
front: fk-coil overs
944 hubs and brake discs
porsche boxster brembo calipers
custom made steering arms/rods
custom made stabilizer bars(cupstrebe
rear: 944 suspension arms and brake discs
custom made stabilizer bars(cupstrebe)
red9design uniball system
spax-coilovers
wheels/rims: steel rims 16inch rear245/45/16 front215/35/16
pre 65 chrome covers
fenders front fully steel: front widened 2,5cm 1 inch
rear widened 6,5cm 2,5inch
fully roll cage incl doorbars
2 gt3 racing seats
4 point belts
omp steering wheel
2002 sti instrument cluster
boost, oil pressure and oil temp gauges.
and much more
i have to do some little things on the interior
and polish the paint
and i need to make a front splitter
because when doing around 200klm (125mph)
it is getting to search on the road a i need to do little
corrections just like in old porsche
when putting a good splitter underneath
i has to do better and i can test it on the autobahn next year
(i'm from holland and live 15klm from the autobahn ;D )
hope you like it
greets
Johan M
holland |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Oct 26, 2013 2:40 pm Post subject: |
WOW! |
juki48 Samba Member
Joined: March 07, 2007 Posts: 602 Location: Upstate NY
Posted: Sat Oct 26, 2013 5:12 pm Post subject: |
Freakin Awesome! _________________ Riley
74 Ghia 2276 Turbo MSII Extra
67 Beetle in restoration
Manx style buggy 1600 stock |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Sat Oct 26, 2013 5:34 pm Post subject: |
nice job. good to see some more thinking out of the box. |
Posted: Sat Oct 26, 2013 5:38 pm Post subject: |
SweetCars Samba Member
Joined: July 23, 2009 Posts: 219 Location: Dominican Republic
Posted: Sat Oct 26, 2013 6:38 pm Post subject: |
really nice, love the rear windows job (y) |
Posted: Sun Oct 27, 2013 1:16 am Post subject: |
thanks!!
when i have some upgrades and interior done
i will place some more post and pic's |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3439 Location: San Diego
Posted: Sun Oct 27, 2013 8:51 am Post subject: |
What is the sneezing sound the motor makes when you shift? |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Sun Oct 27, 2013 9:02 am Post subject: |
blow off valve _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Posted: Sun Oct 27, 2013 10:20 am Post subject: |
fivelugshortaxle wrote: |
blow off valve |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sun Oct 27, 2013 1:02 pm Post subject: |
Cool what are the vents at the front fenders about? For looks or do they do something? |
Posted: Sun Oct 27, 2013 1:25 pm Post subject: |
dirtkeeper wrote: |
to let the air flow easier out underneath the car that is build up after
the radiator that is under the front bonnet
beetle's have big fenders and at higher speeds above 150klm
air pressure is build up and is not helping the handling of the front wheels |
Posted: Tue Apr 08, 2014 3:34 am Post subject: New video. With new camera |
Made a new vid
Wiht a hd cam
But when i was home again it was on 720p and not on full hd
But still nice to see i think
Next will be on full hd
http://youtu.be/ldYdgGaC22M
It is al most fully done
I bought a kamei spoiler that will be fitted and i have to do an splitter
And then it is 100% ready |
Posted: Sun Apr 13, 2014 7:35 am Post subject: new video sprint 0 to 200 klm |
got new video sprint 0 -200klm
wheelspin in 1 gear and to early to 2 gear but still pretty fast!!
but only the audio is still problem that i need to fix
sorry about that
http://youtu.be/PG10E8_utiI
and a raction video of a mate
http://youtu.be/ri5BRdfaQ1s |
FRNKNSTNGHIA Samba Member
Joined: March 05, 2010 Posts: 411 Location: Kissimmee, FL
Posted: Sun Apr 13, 2014 8:58 am Post subject: Re: new video sprint 0 to 200 klm |
johan84 wrote: |
sorry about that
are your windows open when you a recording? If so close your windows... |
mark tucker Samba Member
Posted: Sun Apr 13, 2014 9:45 am Post subject: |
sweet!! I had thought about doing that to the rear window's just for fresh air.have fun&dont get hurt. |
Posted: Sun Apr 13, 2014 10:10 am Post subject: Re: new video sprint 0 to 200 klm |
FRNKNSTNGHIA wrote: |
johan84 wrote: |
sorry about that
I just got the camera and mic in the cam is not that good and external with is also not i think
I going to look for a different external mic |
Posted: Wed Apr 16, 2014 12:44 pm Post subject: Splitter installed |
Installed a kamei spoiler and made a splitter underneath
For more stable drive at higher speed
Around 180 the car is getting light in the front
When i get enough downforce
I will do a autobahn run soon
Anthonyisawsome Samba Member
Posted: Wed Apr 16, 2014 1:22 pm Post subject: Re: Splitter installed |
That made me smile real big haha. |
