Tonyorlo Samba Member
Joined: June 03, 2013 Posts: 182 Location: Glen dale wv
Posted: Thu Nov 27, 2014 2:17 am Post subject: |
96 Mitsubishi eclipse shifter. It's going to need to be cut down,
Made my own heater channels and a few other patch panels.
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Thu Nov 27, 2014 12:16 pm Post subject: |
Have you checked into the heat yet? I have found that the stock pipes/heat box are way to long and must be shortened a great deal. I have only seen pictures of one set and they did not appear that they would flow well. The guy also had to make a custom box.
I was directed to the new gas heaters but they start at around a thousand dollars US.
Starting to get discouraged LOL |
Posted: Thu Nov 27, 2014 2:36 pm Post subject: |
No I havent, but I'm sure your right. I've never owned a air cooled vw so I have no idea how good it works. With the custom manifolds I'm going to have with the turbo, it's going to be a pain to make heater boxes. I was thinking about using an electric heater with a blower under the dash. I'm sure I can fab something up on the cheap that will work. I actually think I still have a blower from my 914 I can use.
The gas probably works great, but I feel like it could be a fire hazard. I'm sure it's safe though. |
Posted: Wed Dec 03, 2014 5:07 pm Post subject: |
Got the rocker on and lower front fender. The front rear quarter patch is trimmed and ready do go in as well.
Posted: Thu Jan 15, 2015 4:29 am Post subject: |
I have some questions about the beam, I really don't want to start a new thread for them.
I'm going to install the SAW adjusters on them myself, but while I have the beam apart should I replace the needle bearings? If so should I use bushings, ,urethane bushings, or should I put needle bearings back in? If everything still feels ok should I just leave the originals in?
I got the passenger side blasted and epoxy primed. I was going to shoot the underneath of the car with bc/cc to match the rest of the exterior, but I think I have decided on using a por15 paint instead. |
Posted: Sat Jan 24, 2015 3:59 pm Post subject: |
I got the left heater channel and rocker on. I had to make a lot of the sheet metal behind the outer panels because of rust. My car came with some replacement sheet metal, I'm guessing from the mid 90s and it fits great.
I've been fighting some of the metal I got from kgpr.
Posted: Sat Jan 24, 2015 4:22 pm Post subject: |
I have been there. What a great feeling when you get it fixed. |
Posted: Wed Jan 28, 2015 7:05 pm Post subject: |
It definitely is. Ill be relived when all the rust is replaced and its in primer.
Found some rust on the beam, so Ill have to get a replacement. I think Kustomwarehouses rebuilt beam is what I'm going with. |
Posted: Tue Feb 10, 2015 8:59 pm Post subject: |
Got the passenger side rust repair wrapped up and in epoxy primer. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Wed Feb 11, 2015 9:18 am Post subject: |
https://www.google.com/search?q=porsche+901+cable+...mp;bih=762
You asked a question before about the 17"x7.5" rims on my Ghia... I haven't had to shave or roll the rear fender lips - Yet.
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Wed Feb 11, 2015 12:22 pm Post subject: |
Your wheels have a lot of offset don't they? Porsche boxer wheels right?
I'm going to use the chevy 5x4.75 pattern, I have my heart set on these wheels, 15x8 and they have a few backspacing options that I think I can make work.
I'm panning on flaring the fenders.
I did see that cable shifter setup. I'm going to copy this for the transmission end,
http://www.cableshift.com/914/914%20page.html
McMaster Carr carries push pull cables that will work.
I'm tempted to attempt flipping the differential myself to save some cash. |
Posted: Tue Feb 17, 2015 9:04 pm Post subject: |
Got some work done on the nose cone.
c21darrel Samba Member
Posted: Wed Feb 18, 2015 8:23 pm Post subject: |
Well that was the last of the metal I had to replace so it should be smiling. Got it in primer as well. Started prepping the pan for por 15.
Posted: Thu Feb 19, 2015 6:28 pm Post subject: |
I got the top side of the pan wire wheeled and ready for por 15, hopefully I will have the underside stripped and painted tomorrow.
I'm going to have the turbo with efi, so I will need to run a return line, I'm thinking 3/8 supply,and 1/4 return. Should I route the lines through the tunnel like stock? Or have them outside the tunnel? |
Posted: Fri Feb 20, 2015 9:46 am Post subject: |
My wheels are Porsche Cayenne 17"x7.5" with 53ET. They have a deep positive offset -
Here are a few nice examples:
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Fri Feb 20, 2015 6:28 pm Post subject: |
Hmmm, I might be able to fit some corvette 17x7.5s on the car then. Inwas planning on using a 15" wheel with a decent amount of back spacing. I'm planning on flaring the fenders. Id like to get a 225-245 under it, what width tires are you running?
Got the underside of the pan cleaned up. Going to start painting it tomorrow.
Posted: Sat Feb 21, 2015 11:39 am Post subject: |
Tonyorlo wrote: |
Hmmm, I might be able to fit some corvette 17x7.5s on the car then. Inwas planning on using a 15" wheel with a decent amount of back spacing. I'm planning on flaring the fenders. Id like to get a 225-245 under it, what width tires are you running? |
I'm currently doing mockup with 205/50ZR17 tires that were take-offs from my Mazda 5 Sport. Looking to drop to a 205/40ZR17 in front, and possibly go to a 235/45ZR17 in rear. But, I'm working to avoid flaring or cutting the fenders. I have found some 185/35-17's for front if required, but hate the low-profile sidewalls.
Posted: Sat Feb 21, 2015 6:03 pm Post subject: |
If be glad to fit tires that wide under the car, but I agree with you. I don't want tires that low ether. I have a tire sizing tool, I'll have to play with that. My problem is I won't have all the weight in the car when I size them up, so I won't be able to set the ride height to where I want it.
I got the underside of the pan Por 15'd.
Posted: Sun Feb 22, 2015 3:38 pm Post subject: |
Got the other side of the pain painted.
