mlhsquared Samba Member
Joined: October 13, 2008 Posts: 1482 Location: Strasburg, VA
Posted: Sat Feb 08, 2014 5:05 pm Post subject: |
Tonyorlo wrote: |
Can I run the earlier "narrow axles" to run a wider wheel? |
Being that your car is a '74, it has an IRS rear end, so earlier short axles from a swing axle rear end will not work. The IRS is a better setup anyway. _________________ Mike
'67 Ghia Coupe |
Tonyorlo Samba Member
Joined: June 03, 2013 Posts: 182 Location: Glen dale wv
Posted: Sat Feb 08, 2014 5:47 pm Post subject: |
Joe, I would definitely like to see those pictures of the stock cooler. That seems like more work than its worth to me.
I figure it will be easier to do what is proven to work and get the dog house shroud. I will most likely get the scat one and try to source some thermostat flaps.
Mike, thanks for the response. I was thinking I could get the narrow axles to run a wider wheel. I guess Ill rule that idea out lol.
Id like to do some type of flare on the car, nothing too big. Dodge omni fenders look to have a nice small flare, Im not sure how close the wheel well arch is to the ghias though? |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6033 Location: CONGERS, N.Y.
Posted: Sat Feb 08, 2014 8:05 pm Post subject: |
HI Tony here are two, one is a guy from Africa that copied the DTM and used the stock T-4 location
The other looks like a Sharpbuilt with the Porsche fan, but I have seen the Cali style with it also. The are 3 reasons I would think the cooler in the upright fanhousing is better 1- is it is the way VW designed it and after a kizillon years improved it by going to the dog house. 2 is Joe from OP put there and 3 Jake Raby left it there.
That said it was designed for the pancake and that is a great design. Sure it can be done but why reinvent the wheel.
Go to the second page of the link below and got to Arod and Joel's photos.
Arod and Joel
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=20 _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Posted: Sun Feb 09, 2014 10:43 am Post subject: |
Joe I agree with you, why try to re invent the wheel. That shroud looks nice, but that's a lot more work than I want to do.
Ive been contacting local machinists and none know or care to to know anything about vws. I'm a Chevy guy at heart lol, but I'm tired of that being all anyone works on. I guess I will buy the rotating assembly from John at air cooled, I wanted to re use the crank and rods, but Ill pay more to have them shipped out and re conditioned than to just buy ones all ready done. |
Posted: Wed Feb 12, 2014 5:02 pm Post subject: |
What's needed to be done to fit 914 brakes to a ghia? It looks like the front caliper isn't any different than a ghia's, but what about the rear caliper? I haven't pulled the brakes off the ghia to compare yet.
I've got an original dog house fan shroud on its way, I've given up on fiberglass cyl covers, it's going to take more time than it's worth to finish them. I put a wtb add on here and have had a few people contact me with some shrouds for sale.
I've been spending some time ready about oil pumps. There's a lot of opinions out there about what's the best oil pump. The cb dry sump system looks nice, but I'm afraid to take the plunge on it. |
Posted: Fri Feb 14, 2014 11:35 pm Post subject: |
That's probably what I'll do. Ideally, it would be nice to be able to get pads at a local shop if needed. Maybe I should look into 944 rear brakes? I don't know much about their parking brakes though. |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Sat Feb 15, 2014 1:25 am Post subject: |
Tonyorlo wrote: |
I think I was reading in the Baywindow section about them using 944 brakes on the front and I think rear |
Posted: Sat Feb 15, 2014 5:48 am Post subject: |
djway3474 wrote: |
Man that would be great to run them front and rear, I need to read more up on the fronts. I think the whole rear suspension from the 944 bolts up. I just don't know what it does to the track width. It be nice to find a write up on the fronts.
Edit:
http://vdubengineering.com/technical/porsche-brake-conversions-2/ |
Posted: Wed Feb 19, 2014 9:43 pm Post subject: |
After looking into it a little deeper, I don't think its what I need. Vented front and rear rotors are overkill for that little car. The rears are easy, but the fronts require some machine work to the spindle.
I got my 2 sets of type 4 cyl tins and dog house shroud today. |
Posted: Mon Jul 14, 2014 6:08 pm Post subject: |
I haven't been on here for awhile. I finally got my garage finished, I have some down time so I decided to tear into the ghia. I'm working the dents out and I got the body off of the pan. I don't have an air compressor in the garage yet so I am limited to what I can do. Here's a few pics
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Mon Jul 14, 2014 8:30 pm Post subject: |
I have a 3 car garage, but may now have garage envy. |
Posted: Tue Jul 15, 2014 5:09 am Post subject: |
I worked out of a 2 car garage for years so this was a nice upgrade. Too bad it's full of cars which makes it a pain to work in. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
Posted: Tue Jul 15, 2014 5:47 am Post subject: |
Tonyorlo wrote: |
You're killing me here, how big is it ...? |
Posted: Tue Jul 15, 2014 8:41 am Post subject: |
Haha I guess I shouldn't complain about it being full. Its 36 x 28 with 14 foot ceilings. The plan is to get a 4 post lift eventually.
My ghia came with a few patch panels, but I want to put the earlier lower rear quarters on. Do all the Vw stores carry the same sheetmetal, or is one better than the other? |
Posted: Tue Jul 22, 2014 6:55 pm Post subject: |
I have a few places on my car that I wont be able to make a patch panel for with the tools that I have. I will probably have a hard time finding them.
I need this panel for both LH and RH.
I figure Ill put a wtb add and see what happens. Im looking forward to seeing the car in primer now. |
c21darrel Samba Member
Posted: Thu Jul 24, 2014 7:39 am Post subject: |
I tried making the rear panel below the tail light, but I don't have the skill or tools to do it. The front doesn't look as bad to make. What year is your ghia? Is the holes for the bumper original that small? I searched for parts cars, but I must of used the wrong terms. Thanks for posting that! |
