UK_Monkey Samba Member
Joined: November 09, 2005 Posts: 362 Location: Home of the British Formula1 Grand Prix
Posted: Wed Oct 30, 2013 2:25 am Post subject: Trimming walk thru kick panels - rubber bottoms |
Hi
Does anyone sell pre-cut rubber for trimming the kick panels? I see you can get the floor mat that goes inbetween as a pre-cut item, but can you get matching kick panels?
Also, is there a specific metal trim set for them? Whats the right way to edge them? How does the trim fit?
Thanks for your advice.
_________________ MonkeyDubs!
'64 11 Window Splitscreen 'Devon Torvette conversion'
OG Right-hand drive UK bus!
"I ain't driving no left-hooker, FOOL"
'74 1303 Karmann Cabriolet Beetle
sbs#26 UK Chapter & Slam Virgin |
Posted: Wed Oct 30, 2013 2:31 am Post subject: |
I'm guessing you use this?
PARTITION PANEL SECURING TRIM, secures bottom edge of partition panels to bus, fits bench seat and walk through models (bend accordingly for walk through models), stainless steel, made by Wolfsburg West, fits through 1967. (rivets not included)
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=221853067 _________________ MonkeyDubs!
olliehank47 Samba Member
Posted: Wed Oct 30, 2013 7:46 am Post subject: |
UK_Monkey wrote: |
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=221853067 |
Something to note about the channel. The illustration and description could be a bit misleading because one might think the "U" in the channel holds the panel. It does not. The channel is mounted with the "U" facing downward and the extra vinyl that extends below the panel back and sides is sandwiched between the bulkhead and the flat part of the channel with rivets. The rubber mat is glued to the bottom of the pedestal and the top of the rubber mat fits into the "U". |
Posted: Wed Oct 30, 2013 8:09 am Post subject: |
olliehank47 wrote: |
UK_Monkey wrote: |
And do I buy it and cut it to length? What lengths does it come in?
Also, does anyone do the rubber precut to go around the seat / seatback base? _________________ MonkeyDubs!
NVNATIVE Samba Member
Joined: August 15, 2012 Posts: 135 Location: Henderson, NV.
Posted: Mon Feb 03, 2014 5:23 pm Post subject: |
Newver was answered if someone makes that pedestal mat.....Anyone? _________________ 64' Notch (Notcho)
67' 13 Window Deluxe (Maxwell) |
Jerry Samba Member
Posted: Mon Feb 03, 2014 6:43 pm Post subject: |
I bought my surround mats from Wolfsburg West. They come with enough material to trim to fit. Look for the rivit holes surrounding your seat stands, that will give you a great guideline as to where to install the seat stand garnishing. Hope this helps. _________________ Looking for SO34 parts.
thevwcompound *instagram* |
Posted: Mon Feb 03, 2014 6:57 pm Post subject: |
I've searched ww high and low and can't find the mat I am looking for. Not looking for the mats that are next to the seats over the wheel wells. Got that covered.
I am looking for the rubber material that is at the floor and covers about the last 6 inches of the seat pedestals. It starts on the sides of the seat pedestals and wraps around through the walk thru area around to the back.
Thanks for your help. _________________ 64' Notch (Notcho)
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Mon Feb 03, 2014 7:29 pm Post subject: |
West Coast Classic VW has them
http://www.classicvws.com/eric-1.htm
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Tue Feb 04, 2014 8:24 am Post subject: |
NVNATIVE wrote: |
Thanks for your help. |
Home depot, Orchard Supply should have that ona roll sold by the foot. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Feb 04, 2014 9:18 am Post subject: |
You're both right ^^^. Indeed, West Coast sells the material- and yes, the ribbed rubber "runner" material from Home Depot works and looks the same. In both cases the only thing you lose: color.
Don't panic when cutting the mats into the wraparound shape. Start with rough measurements and make a pattern using magnets and an old sheet.
People only screw this up in two ways: they work too fast, or failed HS Geometry. _________________
EverettB wrote: |
FU#5 |
Lickitysplit Samba Member
Posted: Mon Aug 04, 2014 4:27 pm Post subject: Trim pieces |
Are there any other sources for the trim pieces? WW is out of stock. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Mon Aug 04, 2014 5:52 pm Post subject: |
crofty wrote: |
NVNATIVE wrote: |
Home depot, Orchard Supply should have that ona roll sold by the foot. |
The first photo above is (or was) my bus. That is standard Home Depot runner material with the Wolfsburg West aluminum edge trim. If WW is out of stock, the trim is usually available on the Classifieds listings.
http://www.thesamba.com/vw/classifieds/detail.php?id=1305441
_________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Wed Aug 06, 2014 11:34 am Post subject: Trim |
Ok I see where the trim piece ends, but what holds the rubber from there forward. The picture below is the best I could find but it's not clear as to whether there is a continuation of the u channel welded to the seat pedestal going forward of the trim.
Thanks
Posted: Wed Aug 06, 2014 2:01 pm Post subject: |
There is a factory rolled flange welded to the seat pedestal.
Everett took this photo:
Posted: Thu Nov 20, 2014 3:37 pm Post subject: |
I'm hoping that some one with a walkthru bus can help me out.
I need a guide on how far the slight bend downward is from the end of the trim that touches the flange welded to the seat base.
Unfortunately, I'm missing some guide holes along that section so don't have an original guide to follow.
Thanks for your help. _________________ MonkeyDubs!
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Thu Nov 20, 2014 10:15 pm Post subject: |
Does this help?
Posted: Fri Nov 21, 2014 5:53 am Post subject: |
Awesome!! 7 cms then.
Great stuff. _________________ MonkeyDubs!
Posted: Fri May 01, 2015 2:32 am Post subject: |
For anyone interested in doing this, I've just completed one side.
I bought the seat back covers from Sewfine as part of the interior. The covers were challenging to fit, the passenger side one in particular as the seam was very stiff and it was difficult to get the stitching to run straight. It OK, not perfect.
You can see the stitching isn't so straight in the picture above.
The next big job was to bend the metal trim from WW. Its stainless and a complete PITA. Its hard and difficult to work with, we had to snip it to assist with the bend, panel beat it to straighten it and insert some wire into the trim to stop it closing when we bent it. Of course the wire wont come out, so it means that the rubber has to be trimmed especially in that area.
As its so hard to work with, I ditched the idea of following the original trim line and just made it a horizontal split. Its fine, there are no trim panels going on the back of them as they'll be a camping interior in there coverng the back of both of them anyway
The rubber stand mats I bought are for LHD vehicles, so I had to make a new set using the WW ones I'd bought as templates. It was really hard to get them to sit well around the bend due to the distortion of the trim. It looks a little rucked up under it, but its actually the trim causing a small protusion. Anyway, it can stay. I'm not that anal about these things..
On the whole, I'm pretty pleased with that side and dreading doing the passenger side trim and rubber. _________________ MonkeyDubs!
