Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
Posted: Thu Feb 26, 2015 6:10 pm Post subject: |
The top section of the boxed frame that runs from front to back had some dodgy areas so I cut it out and made patches. I was able to opsho, prime, and paint the inside of the frame too before I weld it up.
Received my tophats that go under the load bed. Cut away old and fitted these in place. Not welded yet. The quality of these panels is just amazing.
Now that the rear frame section was done, it was time to mount the triangle and get the apron lined up and happy gapped. Thats my new term. I might be losing my mind a little bit.
I had ordered a pair of triangles but later learned that Gerson only really makes the passenger side. This actually worked out great because my driver is not all that bad. So I stole the captive nuts since mine were no good.
Welded them on (you will see a small section of the triangle that is a little crusty that I later cut out. I'll use the gerson triangle to patch it.
I bolted the passenger triangle directly to the apron and it worked out perfect to get the triangle in the perfect spot. I tacked it, and then removed the apron to get some nice solid welds in that 13gauge steel.
Apron fits great! Also started fitting my engine trays to see how they oriented with the apron. I was excited to fit this apron as I purchased it several months ago for a steal.
_________________ Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Thu Feb 26, 2015 6:16 pm Post subject: |
👍 _________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
caseydenise Samba Member
Joined: April 25, 2004 Posts: 1637 Location: The Great Swamp, NJ
Posted: Thu Feb 26, 2015 7:58 pm Post subject: |
You got a happy gap between your ears. _________________ Central Jersey Volkswagen Society - President |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Thu Feb 26, 2015 8:33 pm Post subject: |
Trailbash 2015! _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
Posted: Fri Feb 27, 2015 9:49 am Post subject: |
My single has been under the knife this winter. I do anticipate it being ready for the bash. They could be twins. Just think of it as a little extra motivation. _________________ I will never lie, but sometimes the truth changes.
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Posted: Mon Mar 16, 2015 5:11 am Post subject: |
Managed to squeeze a little time in and work on the boxed frame. Before I could close it up, I realized I had to fab a patch on the left side. See arrows.
Next I could weld in the top sections from front to back.
Next up was the d-pillar, which was completely missing the bottom 10" so I had to use the driver as a reference. To be honest, it took me a while to figure out exactly how it should line up with the frame. Once I had it mocked up I realized the pillar was too short.
So I knew I had to fabricate something to extend it, since Gerson does not make full size pillars for my year truck. As luck would have it the scraps from my c-pillar were almost exactly the same pressing, so I measured a bunch of times and then made the piece.
And finally welded in. If anyone esle is doing this repair its very helpful to have the apron handy to test fit. For me the d-pillar wanted to go too far into the apron opening which would have been big trouble, so just test fit that apron just in case.
Upper triangles are just in place. I need to clean up the metal so they fit nice and tight like factory.
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Mon Mar 16, 2015 9:59 am Post subject: |
That is some project there! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Wed Mar 25, 2015 8:32 am Post subject: |
Red Fau Veh wrote: |
That is some project there! |
I think you're being too nice, its really just an east coast rusty mess!
Welded in the triangles on the passenger side, making sure to weld a captive nut for the tail light ground.
Next I had to extend my corner since the corner I purchased was a wee bit short. The previous owner had riveted a panel and mudded over that and I didn't realize how far gone the corner was when I ordered this panel. So I decided to make it work by adding more metal. You can see a significant dent on the side that I need to dolly out.
Welded in the corner
Battery tray and engine side panel fit really well.
Took a break on the passenger side and decided to do the drivers side while it was all still fresh in my head, lessons learned and all.
Took care of the captive nut on this side too. I copied the original location and ended up using the original nut and bolt.
Test fit the battery tray, triangles, and engine panel. I also marked the areas I need to patch before fitting the corner.
Hipster Cam. Its so dusty when I took this pic that the black and white made it look like smoke.
58deluxerag Samba Member
Posted: Wed Mar 25, 2015 9:41 am Post subject: |
Sweet project!
Nice work _________________ -Corey
'58 Binz
'58 Beetle Ragtop
'65 Sundial |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Wed Mar 25, 2015 9:55 am Post subject: |
Schwing wrote: |
glideking wrote: |
Quality time spent in the man cave!
Kurt
Still dragging that mig around on the floor? |
Yes sir. A cart won't work well in this garage. As you can see its a tight squeeze. |
What you need is to stick a lazy susan on the bed of the single, and jam the welder and tank on that
Honestly, dragging the welder around is a pain, I hear you. There's always and air hose, two other extension cords, and piles of new and old metal to trip over and get tangled up in. At one point, I was so sick of dragging my giant esab around that I hooked up the spool gun, as it has a 20' lead. When you do get around to it, a grocery store shopping cart turns into a welding cart in about 20 minutes. Easy.
I just finished checking out this build from start to finish, man you have brought that back! All of the patches that you've fabbed yourself are impressive, great work. |
Posted: Mon Mar 30, 2015 7:30 am Post subject: |
Thanks Seth and Corey for the comments, keeps me going. Kurth and Seth are both right, I need to make a cart or buy one. Like anybody else time is a limited resource around here with two young kids.
I finished up the honey-do list on Friday and managed to squeeze in some Saturday afternoon vw time, no complaints here!
Had to finish patching up the a-pillar:
Fitted the corner. I have to thank Ken Shapiro for sending me loads of pics of his factory corner. I need lots more replacement steel but when I went to my steel yard they didn't have any scraps big enough. I'll check again this week.
Welded in the Engine Trays. You really have to get the voltage high to lay down some nice welds against that frame. I am vey happy with these.
Bought some jewelry, a one year only engine lid handle. I like original chrome, I did the same thing on my oval. The catch that mounts to the apron is enroute from Wagen Werks so I can make sure everything is closing properly in the rear.
vwbusman66 Samba Member
Joined: May 17, 2014 Posts: 386 Location: Kingsville, MD
Posted: Sat Apr 11, 2015 10:21 am Post subject: |
Im in Bel Air. Its good to see someone else copes with the lovely rust we get here on the east coast! When can I haul my next project over ?
Im eyeing those patina'd gates you have, although I don't have a truck, It'd be nice to acquire all the parts so I can put the parts around me, sit in a 2/3 seat, and make engine noises and feel like Im sitting in one
Regards, James _________________ WANTED: Annis Morrill Corp. dealer information and stuff
1958 L53 Pressed Bumper Panel
1973 Wild Westerner
Click to view image |
Posted: Sat Apr 11, 2015 4:36 pm Post subject: |
The three of us need to get together one day and pose our three Chesapeake buses together. _________________ Looking for a correct 1967 rear seat
