Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Thu Oct 23, 2014 11:46 am Post subject: |
Looks good! I'd never feel safe driving around with that fuel pump hanging low. I modified my bracket to hold my ranger pump originally, until i found the fuel injection had been mostly eaten. My dual carbs purr just fine.
Love the car. Keep the throwback pics coming. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Thu Oct 23, 2014 11:48 am Post subject: |
Thanks!
i gotta get the brakes done now before i can drive regularly anymore...blew a rear wheel cylinder and its got no handbrake and a squishy pedal now... but ill be getting those done asap so it can become my reliable commuter and with heat no less! when i do the brakes, ill move the fuel pump. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Nov 03, 2014 12:37 am Post subject: |
Got the right rear wheels off
Then it started raining.
Cleaned it up from the brake fluid from the leaky wheel cylinder.
Go to remove the brake likes and cant find my line wrench...quick run to work to get it out of my toolbox....
Only to snap the hardline in half that goes from the proportioning valve to the soft line....
Get a generic from autozone....8 inches to long. So i put a loop in it carefully.
Get back out from under the car, soaked from the rain. Its dark, where are my new wheel cylinders?
Paid for them and had them ordered, and got everything else, but forgot to go pick them up!
Picking them up tomorrow.
Pics soon:) _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Wed Nov 05, 2014 12:28 am Post subject: |
Got the brakes back together!
Still gotta adjust and bleed it to perfection, but its stopping smoothly now!
Brake lights fixed also, replaced both swithes, hence still need to bleed 3rd time around.....drained my master cylinder swapped them out.
E brake still inop due to mis adjusted shoes, will deal with that later, like, tomorrow. Maybe.
Its officially named Ruby, just thought i would let yall know. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Thu Nov 06, 2014 1:13 am Post subject: |
Got thew brakes sorted! ...mostly....
used a vacuum bleeder to get the air out of the lines...still not convinced i got ALL of it....but the brakes are pretty effective now, and reliable. got the rears adjusted nicely, but its time for new handbrake cables....ones stretched and its not grabbing correctly. works OK for now, but its gonna need em soon.
accidentally slid around a corner going a tad to fast. the rear end went ahead of me for a moment before the front caught up and it straightened out. all safe n sound though. Oops.
next on the list is a new set of wipers....any recommended favorites? or just whatever FLAPS has?
then i need to get some door seals. the back hatch doesnt have a seal at all...thats fabulous when it rains.
ball joins and transmission are my only two other mechanical issues/concerns. both axle seals are shot, and 2nd gear syncro is totally gone. CV boots are all four torn...need new ones of those too.
pics are around, just gotta get em uploaded, and since im currently mid move, thats not going to happen for a while. ill keep the updates coming though! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Thu Nov 06, 2014 1:14 am Post subject: |
Kirk wrote: |
Love the car. Keep the throwback pics coming. |
moved it a up a bit higher. didnt even undo the zipties...just pushed it up over the beam rail. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Thu Nov 06, 2014 6:58 pm Post subject: |
went over to Cheryl's house this afternoon....
we went for a little ride in Ruby and talked for a bit. it was lots of fun (for me anyways ) and i know She had fun riding along in the car with me. next time, your welcome to drive it too Cheryl, I just forgot this time.... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Thu Nov 06, 2014 7:23 pm Post subject: |
heres what i started with on the rear brakes....
replaced:
all 4 soft lines
hard line from proportioning valve to the right rear soft line
rear wheel cylinders
shoes
both brake switches on the master cylinder
generator brushes:
still need:
front pads (about 3-4mm left...)
shocks
handbrake cables
balljoints
tie rod ends
alignment _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22358 Location: Kimball, Mi
Posted: Thu Nov 06, 2014 9:08 pm Post subject: |
You're gaining on it Stuart. It won't be long until it's all good to go.
It's cool that you took the car over to show the PO that yoou're fixing it up, and even took her for a ride in it. Sue and I did that with our T-34 back in 2012. Marilyn was surprised we brought it back "home". _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Dec 27, 2014 7:03 pm Post subject: |
No new updates, other than this is my current daily driver. Desperately needs a rear hatch seal and me to put the screws that hold the computer in place back in and put the panel back on, but i lost the screws....darn it. After that it's door seals and h4 headlights with Hids and a set of vintage foglights.
Also need a new fan belt...and need to tighten the one i have, its super loose and i havent tightened it yet _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Tue Dec 30, 2014 9:54 am Post subject: |
206-841-7324
[email protected] |
Posted: Tue Dec 30, 2014 9:56 am Post subject: |
Google made this awesome video when I backed up my photos yesterday...thought it was pretty cool! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Sun Jan 04, 2015 7:28 pm Post subject: |
Wow, I just read this thread and the story is pretty awesome. We have heard so manny stories of Type 3's that were kept for quite a while in dark oblivion and only to the salvage by a type 3 buff... such as you buddy! And on thing that really really caught my attention is that the Square was first bought by your buddy and then for a while, it was again left hibernating in isolation. And you got it at the right time and right opportunity.
One thing is certain, that Square was destined to be yours, buddy! As we can see, the Square has again seen the light of the day in glorious ways!
Happy vee-dubbinn'....
Dong _________________ '67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20 |
Posted: Sun Jan 25, 2015 7:38 pm Post subject: |
hit n run last night...
ended up being the neighbor and his son hadnt left a note when he bumped it this morning, casue he couldnt see the damage in the dark.
hes being quite nice and very willing to make up for it, so it all is working out, but still annoying _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Tue Feb 10, 2015 7:32 pm Post subject: |
Just changed the oil and adjusted the Idle down a bit. its much happier
also added oil to the air filter...apparently it was empty not anymore! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Mar 01, 2015 1:09 am Post subject: |
This ones got me puzzled....these dont have an idle air control valve do they?
Cold startup:
Jokes wrong video...
This one
Funky idle:
Any thoughts on the bus too would be appriacted tho. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Fri May 22, 2015 7:55 am Post subject: |
so...quick update...
the fuel injection has a mixture issue that I am suspecting is the temp sensor, so its running rich, and rough cold startup, but should have that handled here in the next week or less.
I added front foglights!
(pics later, don't have them handy)
got the front seats out and lubed up, and had the drivers seat repaired (seat rails were busted) but the welds didn't hold because I didn't clean the metal very well, so I gotta redo those again.
more later! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Type 3 66" Samba Member
Posted: Sat Jan 28, 2023 7:45 am Post subject: Re: 1971 Yugoslavia Squareback |
Nice car and story ) |
