Project_dog Samba Member
Joined: June 26, 2003 Posts: 65 Location: Spokane, Wa
Posted: Mon Apr 14, 2014 11:47 pm Post subject: |
Very nice man. Glad to see another spokane guy on there. |
asesapie Samba Member
Joined: March 07, 2005 Posts: 756 Location: Spokane, WA
Posted: Tue Apr 15, 2014 12:51 pm Post subject: |
I'm running a 2" narrowed beam with adjusters up front and Atomwerks 3" drop spring plates in the rear at stock setting. The bug rides really nice with that setup.
I'll never go back to cut spring plates after driving this with drop spring plates. |
Project_dog wrote: |
Are you apart of RCVWclub? What do you drive? |
Posted: Tue Apr 15, 2014 11:24 pm Post subject: |
asesapie wrote: |
Right now I drive a Mazda CX-7. But when it comes saturday Im picking up a 1967 beetle.
What is the RCVWclub? |
Posted: Wed Apr 16, 2014 2:25 pm Post subject: |
RCVWclub.org is the local vw club here in Spokane. Did you pick up the red 67 that was on craigslist here? |
Posted: Wed Apr 16, 2014 2:58 pm Post subject: |
Yep |
Posted: Fri Apr 25, 2014 9:53 pm Post subject: |
So I've been trying to see why by trans grinds shifting into second here and there. I took the shifter off and the shift rod fell down. I thought the shift rod was supposed to be held up by the piece that supports it. I think this could be why my trans is grinding into second every once in a while.
Should the part that supports the shift rod be welded to the tunnel or? |
Posted: Sat Apr 26, 2014 8:12 pm Post subject: |
There is a bushing inside the tunnel and I think there is also a support bracket inside there too. Correct me if im wrong. |
Posted: Sat Apr 26, 2014 9:43 pm Post subject: |
That is the bracket I'm talking about that fell to the bottom of the tunnel after taking the shifter off. That isn't supposed to fall down after taking the shifter off right? It has been a while since I've taken a bug shifter off. I don't see any drill holes for drilling out spot welds or anything. |
pb_foots Samba Member
Joined: April 15, 2010 Posts: 1089 Location: Ben Lomond, CA
Posted: Sat Apr 26, 2014 10:06 pm Post subject: |
yes, the bracket is spot welded to the top of the tunnel.
I had the same thing happen. I used the bolts to hold the bracket in place and then drilled a couple new holes and pop riveted it up.
Once the shifter is back in, the bolts that hold down the shifter will hold the bracket in place. the rivets are only there to keep it from falling down into the tunnel. You could also weld it again, that would be better I suppose. |
Posted: Wed Apr 30, 2014 6:51 pm Post subject: |
What motor do you have? |
