Malocchio Samba Member
Posted: Tue Nov 19, 2013 12:00 am Post subject: Oil filter vs. no oil filter |
I'm surprised this topic hasn't been covered in detail and would like to get some hard evidence in either direction. Obviously, filtered oil is going to provide better lubrication leading to increased engine life, there is no arguing that fact. However, The general opinion seems to be "they don't need that and just drive it" because that's how the factory made it. I can see why some hold the opinion as I have seen 40hp engines in bugs with over 200k on them bone stock. I have also seen teardowns of engines with that sort of mileage and it's astounding the amount of visible wear from scuffing due to unfiltered oil. What that means, irregardless of longevity, is that less parts are salvageable for the next build and that clearances open up faster. Why does this matter? Because this shit costs money and I like to daily drive my shit and would like it to last a long time plus parts are getting more expensive/nla/facing extinction.
Gotta squeeze every last drop outta usage and I'd like to know if anyone has actually built a stock or mildly stock engine with an oil filter, put it through its service life, performed a tear down and noticed a huge difference in the amount of visible wear of any kind. My gut just tells me that engine oil needs filtration and why not go through the trouble to add another 50-100k to a daily driven 40hp or 1600? I usually see filtration on large motors due to the higher stress and no filter on stock motors. Once again, if anyone has any astounding results or a very detailed reason as to why a filter is not needed please share. I'm planning on running a filter like a cb maxi/vw Mexico or a Porsche 356/912 type bypass on my next stock build. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Nov 19, 2013 5:52 am Post subject: |
I have seen it!! Bearings really show the damage from non-filtered!! and don't waste ur money on those 'By-Pass' pump/filter POS ,learn how to 'Full Flow' _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76901 Location: Sneaking up behind you
Posted: Tue Nov 19, 2013 5:56 am Post subject: |
I once had a valve spring break and the pushrod tore up the aluminum rocker dumping aluminum shavings into the case.
The oil filter saved the engine and after replacing the spring and flushing the case, the engine ran for years later. _________________ Glenn
Member #1009
#BlueSquare |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Tue Nov 19, 2013 6:14 am Post subject: |
Ford Motor Company did the testing in the '50's and proved that there was significantly (30% ?) less wear when properly filtered. A bypass filter will filter some of the oil some of the time; wear will happen, just at a slower rate. Glenn's situation might have had a different outcome had the filter not been full flow. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Tue Nov 19, 2013 10:25 am Post subject: |
So with filtration, not only does the engine last significantly longer, but can withstand trauma such as the instance of Glenn's. I didn't know about the ford test and that number would be much higher at the break in period. I have a friend who is adimate about NOT running filters on stock engines because his 40hp bottom end has 200k miles on it. I think it comes down to not wanting to modify the look of a stock 40hp case and he argues that the filter lines decrease overall reliability. He won't sell me a spare engine because he knows I will implement some form of a filtration system which isn't stock. I like the idea of the CB Maxi or VW Mexico because they don't require case altering, have no lines, and look clean. I have heard that the oil passages are small in the CB pump and therefore not well suited for hipo applications. Also, there is no denial that they sit directly in the hot air path of the engine. I think either would work fine. |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Tue Nov 19, 2013 11:46 am Post subject: |
Malocchio wrote: |
So how hot is the air? If it's even somewhat lower than the oil temperature, it will cool the oil. It is not a problem either way. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
slalombuggy Samba Member
Posted: Tue Nov 19, 2013 11:57 am Post subject: |
Filter pumps work just great, so great in fact that VW Mexico put them on as stock equipment and I can't think of much hotter climates than South America. I ran one for years and loved the easy of instillation and the fact I didn't have to do a bunch of machining to filter my engine oil. It's a lot of bunk saying they heat your oil up to dangerous temps.......
brad |
Posted: Tue Nov 19, 2013 12:25 pm Post subject: |
If the air blowing over the filter is 220F it's not going to be heating the oil up at all if the oil is 220F, I think this worry doesn't hold water. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Tue Nov 19, 2013 7:37 pm Post subject: |
Good point about the air temp being equal or less than the oil temp. The filter pumps are cheap too. Can these be run on any type one? |
Posted: Tue Nov 19, 2013 8:12 pm Post subject: |
They won't fit on engines with a competition merged header. Don't know if they will fit on sidewinder style exhausts or not.
brad |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Tue Nov 19, 2013 8:28 pm Post subject: |
Do all the ones that replace the oil pump, go off to the side? Any more compact? _________________ 1958 Karmann Ghia owner |
Posted: Tue Nov 19, 2013 10:03 pm Post subject: |
As far as I have seen they all go off to the right side of the motor and are all about the same size. You can fit a shorter filter on them.
brad |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Tue Nov 19, 2013 10:42 pm Post subject: |
Another option is to run an in/out style pump that CB sells.....
http://www.cbperformance.com/ProductDetails.asp?ProductCode=1798
is a 26mm pump for flat cams _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Wed Nov 20, 2013 7:19 am Post subject: |
slalombuggy wrote: |
brad |
I found out by accident that an oil filter for a 2001 Harley Duece fit and is 50% shorter. I use them all the time now. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
jspbtown Samba Member
Posted: Wed Nov 20, 2013 9:06 am Post subject: |
Quote: |
As far as I have seen they all go off to the right side of the motor and are all about the same size |
I thought it was the left side..... |
Posted: Wed Nov 20, 2013 9:34 am Post subject: |
jspbtown wrote: |
Ya, my other right LOL My goof......
brad |
Posted: Wed Nov 20, 2013 9:37 am Post subject: |
I have the CB one that replaces the oil pump and has rubber lines, barbed fittings and hose clamps, but I'm a little uneasy about the lines. By the time I spend the money to do AN couplings or crimped lines, I could have bought a one piece assembly for cheaper, but I'm concerned about the clearance with my merged exhaust system. _________________ 1958 Karmann Ghia owner |
badufay Samba Member
Joined: December 13, 2010 Posts: 361 Location: Olympia, WA
Posted: Wed Nov 20, 2013 10:28 am Post subject: |
Best solution right here... It's an OE part too. Install this, then run 5w30 synthetic and be on your way
http://vwparts.aircooled.net/OEM-VW-30mm-Full-Flow...15-115.htm
Ben _________________ Current: 1976 VW Bus, 3 spd auto 2.0L FI; 2017 GTI S, 6 spd man; 2017 Jetta SE TSI, 5 spd man; 2006 Golf GL 2.0L, auto
Previous: 2015 Golf S TDI, 6 spd man; 2015 Jetta SE TDI, 6 spd man; 12 Jetta 2.5L, 04 Jetta 2.0L, 02 Golf 2.0L, 98 Jetta 2.0L, 98 Golf 2.0L, 98 Cabrio 2.0L, 95 Golf 2.0L, 87 golf GTI 16 valve 1.8L, 86 Cabriolet 1.6L, 80 Audi 4000 1.6L, 76 Audi Fox 1.6L, 76 VW Beetle 1.6L, 74 Audi Fox 1.5L, 69 VW Beetle 1.5L |
Posted: Wed Nov 20, 2013 11:04 am Post subject: |
Any chance it will fit with a Bugpack merged header? _________________ 1958 Karmann Ghia owner |
