schwim Samba Member
Joined: May 18, 2008 Posts: 271 Location: Western NC, USA
grandpa pete Samba Member
schwim Samba Member
Posted: Wed Nov 13, 2013 5:14 am Post subject: |
Not speaking of the bend in the rod for e-brake clearance grandpa, but the orientation of the cup in relation to the dimple. My cup sits at 1-1:30 when the dimple's at 12 as you sight down it.
I have searched a lot. I can't find a single mention of what I'm asking about. Either I'm using the incorrect terminology, or what I'm asking is oddball.
A pic or confirmation would be greatly appreciated. _________________ Zippy the Wonderbug's achingly slow meandering toward roadworthiness |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Wed Nov 13, 2013 10:07 am Post subject: |
schwim wrote: |
A pic or confirmation would be greatly appreciated. |
I've searched the gallery with no luck. However, there appears to be a few in the classifieds - you might try contacting a seller.
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
schwim Samba Member
Posted: Wed Nov 13, 2013 12:06 pm Post subject: |
Culito wrote: |
http://www.thesamba.com/vw/classifieds/search.php?...ch[/quote]
Thanks very much for the suggestion, Culito. I also had no luck in the gallery but hadn't thought to use the classifieds. I wrote an email to the gent selling the 60 shift rod. If mine's indexed incorrectly, I'll pick his up as a replacement. _________________ Zippy the Wonderbug's achingly slow meandering toward roadworthiness |
offshores Samba Member
Joined: February 08, 2012 Posts: 1085 Location: So Cal
Posted: Wed Nov 13, 2013 1:17 pm Post subject: |
On my ’65 the shift rod is a bit different along with coupler, but if it had a twist like that it would throw things off. Also, the Bentley manual mentions checking for “wear and twists” in the shift rod. The ball socket part up front needs to be strait up for neutral and the indent coming from the transmission shift lever should also be straight up in neutral. Insert your current rod and coupler and only one of those will be straight up. Not sure about your year, but my guess is it’s twisted. Curious to hear a definite answer though. |
schwim Samba Member
Posted: Wed Nov 13, 2013 1:25 pm Post subject: |
offshores wrote: |
Year is 59. I'm really hoping you're right. It will explain why I have to offset my shift coupler to be able to get all gears. I have to tighten the detent screw to one side of the dimple to get it in alignment. _________________ Zippy the Wonderbug's achingly slow meandering toward roadworthiness |
spicetraders Samba Member
Posted: Thu Dec 12, 2013 2:23 pm Post subject: |
I just pulled my 59 pan shift rod. What a bear to get out. But it also has some issues at least from what I read in Bentleys as stated previously rod has a bit of an zigzag in it.
With this being in a shortened 59 pan on a fiberglass dune buggy it is hard to know what is right to a normal full size, i would still think straight is right.
Looking at the pin dent vs the pipe elbow I see a very slight shift to toward the 1 o'clock spot but very slight.
_________________ -
If you don't like what I say well to bad, just skip to next post.
I guess my logic and yours just don't match.
This is not E harmony here. |
schwim Samba Member
Posted: Thu Dec 12, 2013 3:13 pm Post subject: |
I was just in www2.cpi1.com. Searched for shift rods.
Seems that the early beetles have a bent rod to clear the brake tubes. There must also be a good working bushing inside the tunnels just be hind the shift hole. CPI1 has most of these parts on sale for the holidays so I am just going to buy a new bushing, coupler, and rod so I have a clean set up.
Looks like for a 59 beetle they have three choices so I am buying the one closest to my length.
I also like the weld in length adjuster listed in CPI1 make it nice to get things twisted just perfect and exact length for clean shifts.
A log of good info over in the samba kit/fiberglass forum on shift rod. _________________ -
jhoefer Samba Member
Posted: Thu Dec 12, 2013 4:17 pm Post subject: |
schwim wrote: |
The shift rod cup, shift rod dimple, and transmission hockey stick dimple are supposed to be all in a straight line and vertical when in neutral.
Is the dimple on the transmission side (on the hockey stick) vertical or rotated when in neutral? Does it have more than one dimple, perhaps on the bottom? Are any of the dimples actually drilled all the way through?
My guess is that you have mismatched parts in the car and someone has tried to correct it. See: http://www.thesamba.com/vw/forum/viewtopic.php?t=507557 and http://www.thesamba.com/vw/forum/viewtopic.php?t=418580 and http://www.thesamba.com/vw/forum/viewtopic.php?t=319586 |
2nd67 Samba Member
Joined: August 09, 2013 Posts: 204 Location: high desert ca
Posted: Thu Dec 12, 2013 5:48 pm Post subject: i just installed on my 67 |
and definitley 12/12. i cant imagine how pissed someone must have been trying to get reverse?. somehow the trans must have been stuck in a gear so that the back side of the rod was held stationary while someone on the shifter was giving it everything they had!. |
schwim Samba Member
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Fri Dec 13, 2013 10:11 am Post subject: |
schwim wrote: |
I can't imagine how it got twisted.. |
Well, it IS straight, and it shouldn't be... so it probably happened whenever it was messed with.
Not much help from the factory parts manual (May 1960 edition) from which I extracted this excerpt:
Posted: Mon Dec 23, 2013 8:29 pm Post subject: |
I got my new rod in for my 59 if you need a picture. Definite wave in the rod, and the line is straight from cup to detente. Price was right for a nice clean rod, bushing, and weld in end adjuster. _________________ -
EVfun Samba Member
Posted: Mon Dec 23, 2013 10:12 pm Post subject: |
I just grabbed a '69 rod and put section of pipe into the hole (later models didn't have the dimple.) the cup is about 10 degrees clockwise when the rod was horizontal. I would guess the older rod had the same slight rotation between the cup and coupler ends. They generally use the same aftermarket shifters.
A 1959 Bug won't have a shift rod bushing. The old Bugs had a rolled steel hanger that doubled as a bushing and a leaf spring to push down on the shift rod to prevent rattles. I would say the old system is superior, so unless the steel bushing is worn out I'd wouldn't replace it with a newer hanger. _________________
Wildthings wrote: |
schwim Samba Member
Posted: Tue Dec 24, 2013 7:56 am Post subject: |
EVfun wrote: |
A 1959 Bug won't have a shift rod bushing. The old Bugs had a rolled steel hanger that doubled as a bushing and a leaf spring to push down on the shift rod to prevent rattles. I would say the old system is superior, so unless the steel bushing is worn out I'd wouldn't replace it with a newer hanger. |
So we have one positive that it's 12-12 and one positive that it's 10 degrees off. That's pretty fantastic
My rod has the bend for the e-brake. It also has a totaled bushing still on the rod up at the front(it wasn't functioning when I purchased the car). The shifter was so tight, I figured that mine was of the style that didn't use the bushing and that the bushing found by the shift cup meant that I had a replacement rod.
Since I have the same number of people that are positive that it's got no twist as those that are positive it does, and still not a single picture to compare, it looks like I'm just going to have to bite the bullet and spend the money to get one to compare it to. I can always sell it back off to recoup the investment. _________________ Zippy the Wonderbug's achingly slow meandering toward roadworthiness |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Tue Dec 24, 2013 8:37 am Post subject: Shift Rod |
OK, This is the best I can do, I went out to my shop and squared up the Shift Rod with the slot in the front cup and went to the coupler end & found center, this is what I came up with. This Rod came out of a working, Shifting fine Bug. For reference the center of the Dimple looks to be 1mm off center towards the drivers side. To bad you didn't live closer, you could swing by and take it home with you. Hope it helps.
schwim Samba Member
Posted: Tue Dec 24, 2013 9:54 am Post subject: |
Wow, that's absolutely fantastic! Thanks so much! It looks like when the cup and dimple are at 12, the bend for the e-brake is rotated to about 4 o'clock. Would you say that is right? If so, this will help me figure out which end I've got the issue with.
Can I ask what year this rod came out of?
Thanks again so much for taking the time to set this up and take some pics. It's incredibly helpful of you. _________________ Zippy the Wonderbug's achingly slow meandering toward roadworthiness |
Posted: Tue Dec 24, 2013 10:45 am Post subject: |
schwim wrote: |
Since I have the same number of people that are positive that it's got no twist as those that are positive it does |
and the fact that yours is twisted and doesn't shift properly would lead me to believe that it shouldn't have a twist. Also, the Bentley warns of checking for twists. Sounds to me like you've finally found an answer. Hope it does solve your problem. |
