nate93460 Samba Member
Joined: April 25, 2012 Posts: 35 Location: Santa Ynez CA
Posted: Tue Nov 19, 2013 11:25 am Post subject: "Best" quiet muffler upgrade for a Type 2? |
anybody have any recommendations on the most unobtrusive yet quiet muffler for a type 2? looking at options for my 56 single cab. the engine will be a mild 1776dp. i"ve been looking at Empi "GT style" exhausts, particularly the GT single tip. anybody running one? |
porscheforu Samba Member
Joined: November 02, 2009 Posts: 35 Location: Sun Valley, ID
Posted: Tue Nov 19, 2013 3:25 pm Post subject: |
I'm running an Empi single tip with my 1641 and it has a nice sound. Not objectionable at all. The only problem I encountered was that the muffler comes in contact with the bumper. Not sure how to cure this. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Nov 19, 2013 3:46 pm Post subject: Re: "best" quiet muffler upgrade for a type 2? |
nate93460 wrote: |
are you worried about the neighbors? in a single cab the exhaust is really not that noticeable? _________________ regards
Uli
Posted: Tue Nov 19, 2013 7:56 pm Post subject: |
I'm currently running an old (rusty) beetle exhaust on my 1500sp, which isn't overly loud, but I'm afraid it is going to restrict a 1776. I like the look of the stock type 2 muffler, but again, not sure it would work well on a bigger engine. |
kingodirtp3 Samba Member
Joined: December 07, 2007 Posts: 1062 Location: Monterey CA
Posted: Wed Nov 20, 2013 6:46 pm Post subject: |
the best performing exhaust in a 1 3/8ths header with either single quietpac or hideaway with a mild 1776dp type of engine. using bigger pipes will loose low end torque. the 4 to 1 collector will give the best savaging and power. the turbo tuck isn't that loud, quieter than the single quietpac which isn't that loud either.
the empi mufflers that just have 2 pipes into each side of the center muffler with either a single tip or 4 tip are almost as bad as stock. |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
BryanM Samba Member
Joined: June 14, 2002 Posts: 4212 Location: Concord/Charlotte NC
Posted: Wed Nov 20, 2013 8:06 pm Post subject: |
X2 on vintage speed exhausts _________________ -Bryan
Motorwagen LLC
Concord NC |
Posted: Wed Nov 20, 2013 8:23 pm Post subject: |
the vintage speed is very nice. but like A1 and a couple of other exhausts option out there, they are way too expensive. their performance isn't better enough to qualify spending that much. a 1 3/8ths header and turbo tuck is less that $200 and will give the best performance/cost ratio. if you're low then get a steel plate welded to the bottom of the collector and have a custom muffler ran like I did. once I finished the custom stuff it was up to around 300, still cheaper than VS and A1.
just please no empi gt 4 tip or single tip exhausts, they are as bad as stock. |
Posted: Wed Nov 20, 2013 8:29 pm Post subject: |
depends on the carbs, cam, and head work. if its a mild 1776 then using ur stock heater boxes and 1 3/8ths header is ok, but if its a wild 1776 like 120 cam, big valves, and weber 40s then you'll need 1 1/2 merged header.
are you lowered? if lowered and u have the money then vintage speed or A1 is very nice. if you don't have the money then get the stuff I listed below and have a muffler shop weld a 1/4 strip of metal to the lowest part of the collector because you may scrape it.
basic header
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DD%2D2031%2D10
turbo tuck
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DD%2D2556 |
67_SO42 Samba Member
Joined: August 27, 2006 Posts: 668 Location: Oslo, Norway via Arizona
Posted: Thu Nov 21, 2013 12:09 am Post subject: |
I have said items in my shopping cart... got any pics of your setup before i pull the trigger? _________________ 58 Binz DC #151 "Nacho"
61 Norwegian, bug "Greta"
65 Swedish, Westfalia 400 trailer "Melania"
57 Binz scooter “Micha” |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
Posted: Thu Nov 21, 2013 9:11 am Post subject: |
67_SO42 wrote: |
I have said items in my shopping cart... got any pics of your setup before i pull the trigger? |
Just know that you will have to remove that muffler to adjust valves. The finish will also not last on the header or muffler, unless you spring to get them ceramic coated. Which by the time you do all that you're getting close to pricing territory of a vintage speed that will last a lot longer and give more ground clearance if your bus is lowered... |
Posted: Thu Nov 21, 2013 10:17 am Post subject: |
the header/muffler will last if you coat it with peanut oil every couple days for a couple months. once the oil burns into the exhaust it will last a long time. I've had mine going for 5 years now. peanut oiled it and I sometimes give it a coat of 2000deg exhaust paint.
use the copper gaskets so when you take off the muffler you wont have to buy a new gasket.
still less than half the price of the VS or A1 stuff. |
Posted: Thu Nov 21, 2013 10:21 am Post subject: |
I got a 20 muffler cherry bomb or turbo hush type from autozone, then got some nice 2 in mandrel bend tubes from summit and a 3 bolt flange and took it all to a local muffler shop and they welded it up for 75. I dont have to take off my muffler to adjust the valves. I paid around 300 total for this set up. no rust holes just, just light surface rust. |
Posted: Thu Nov 21, 2013 10:23 am Post subject: |
just be sure to sand off the paint the exhaust come in and give them a good coat of 2000deg paint, once the paint has been cooked on you can either spray them again or start coating with peanut oil. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Thu Nov 21, 2013 10:39 am Post subject: |
You'll get what you pay for!
Ceramic coating will make it last longer than without it, but eventually it will start rusting here and there. The header system is not a part that normally gets "buffed and waxed" every time you wash your bus. So with the road dirt and the weather it gets pitted. Quality of build is where it's at, though.
Here's an example of "lipstick on a pig".
_________________ Some people are so busy being clever they don't have time enough to be wise. |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Thu Nov 21, 2013 12:36 pm Post subject: best" quiet muffler upgrade for a type 2? |
Vintage Speed and A 1 are both excellent (I have both) but neither are quiet. A regular 4 into 1 with a single quiet pack (regular or tucked) are the quietest option after stock bus muffler. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2821 Location: Centennial, CO
Posted: Thu Nov 21, 2013 1:05 pm Post subject: |
I had an empi single quiet pack to start out and eventually put on a Vintage Speed lowered exhaust.
Do yourself a favor and save your pennies and get the Vintage Speed. It is an investment that you will be glad you got. |
pyrOman Fire Master
Posted: Thu Nov 21, 2013 1:16 pm Post subject: Re: best" quiet muffler upgrade for a type 2? |
Teeroy wrote: |
Vintage Speed and A 1 are both excellent (I have both) but neither are quiet. A regular 4 into 1 with a single quiet pack (regular or tucked) are the quietest option after stock bus muffler. |
True that! But again, quality is where it's at! I too got tired of buying cheap assed mufflers every six months because they either broke or just plain desintegrated. The sidewinder plus stainless MONDO muffler in the Dormy was indeed way to loud, specially fresh in and on a cross country drive! So I "capped" it with a spark arrestor.
On the Plump Truck, after attempting to buy a "cheap" muffler and finding out they are now over $100, decided to make my own! Went to Peep Boys and got the smallest they had for $30 and hacked it into existing pipes.
Here's the old muffler showing cracks, leaks and if you look closer, it's all "swelled up":
The new beefy $30 one!
(Note the EMPI one showing its rustosis)
I am currently considering installing a quieter muffler onto the sidewinder collector. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Teeroy Samba Member
Posted: Fri Nov 22, 2013 8:30 am Post subject: "best" quiet muffler upgrade for a type 2? |
The Vintage Speed I have (lowered bus Sport muffler) is not real loud, and does not drone at all like some of the Mondo mufflers do. I'm very happy with the quality and fit. _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
electronictofu Samba Member
Posted: Wed Apr 15, 2015 4:12 pm Post subject: Re: best" quiet muffler upgrade for a type 2? |
[quote="pyrOman"]
Teeroy wrote: |
I am really interested in what you did here. I have the A1 Sidewinder kit, stainless steal. The exhaust fits great and looks good, the muffler it came with sits a tad lower than I thought but that's not an issue, this thing is LOUD loud. Did you weld on another tip or just get a totally different muffler? If I can mod this thing it'd be great, to quiet things up... |
