oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Wed Jan 29, 2014 3:17 pm Post subject: |
Oh, yeah...hated to drill into fresh paint. The GoWesty bracket kit comes with "rivet-nuts", my first time using these to install a captured nut behind a body panel (WHAT will they think of next?) ..I got an education on these at a local fastener store (they know I'm a mechanical "rube" but they talk to me anyway.) Check out at all the other great posts. My post and pics on page 11..I don't know how to reference it..But, really I just followed everyone else and that seemed like the best way to secure it using the GW brackets and fasteners...all the best |
Gruppe B Samba Member
Posted: Sat Feb 01, 2014 10:19 pm Post subject: |
Just installed a 10'x6.5' on my 1985 Westy using 3 Gowesty brackets.
Pretty easy install, did not flatten the brackets, just bolted the two brackets together at the top using carriage bolts and lock nuts and used a spacer and 1/4" joint connector nuts for the side facing the poptop with countersunk bolts on the awning side.
These are joint connector nuts (home depot has them)
The nuts that hd sells has an allen head on the back to hold (doesnt allow the bolt to go all the way thru)
Using 3 Gowesty brackets does have problems. The drip edge on the 1985 has a slight arc or bend somewhere because I could get the center and front bracket to attach but the rear bracket was too far back by about 5mm to fit in the groove. I ended up putting some force on the rear of the awning and it popped in but I think that the front awning now needs a little persuasion to fully close. To fasten the awning to the brackets I used the allen bolts provided and just drilled new holes at the bottom of the aluminum brackets into the awning bolting them together (only the front and back awning).
For those who bought the awning but did not yet open it, there is an awesome stainless hardware kit under the foam cap at the front of the awning. I didnt find it until install and had replicated everything that was supplied from home depot.
I'm heading to Moab on Monday so I'll post pictures there. Way too cold here in Canada right now |
SCP_Austin Samba Member
Joined: November 04, 2009 Posts: 366 Location: Tacoma, WA
Posted: Tue Feb 18, 2014 2:19 pm Post subject: |
Shameless plug...
PM if anyone is looking for a 10 ft blue fabric awning. I got a Fiamma on my recent acquisition of syncroness. I know there are some Seattle guys out there who might be interested.
I already did the brackets as shown in the thread. _________________ #leftlanelife |
SteelB12 Samba Member
Joined: December 21, 2010 Posts: 591 Location: Central Virginia
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Sat Feb 22, 2014 7:04 pm Post subject: |
I'd start with 2. I used 3 on my first awning, but they fit no problem. These take more mcgyvering and may not be needed. I was thinking a short skinny piece of aluminum or a 90 degree piece from HD might fit either in the rail or under the rail and clamping onto it would spread the load somewhat. The welded extensions obviously are stronger but this might help and requires no welding. With a 10' awning I would think you will want to use the provided screws that go into the pillars for extra stablility. That would probably be enough on it's own and seems to be what most fiamma people do. So far with the 8' I am only using 2 brackets and havent' used the piller screws, but may. |
shizzon Samba Member
Joined: July 25, 2006 Posts: 596 Location: Boulder, CO
Posted: Tue Feb 25, 2014 9:26 am Post subject: |
Has anyone purchased the 11 1/2 ft x 6 1/2 ft. awning?
Any thoughts on the two different geometries (10x8 vs. 11.5x6.5)? _________________ 1989 Bostig Syncro Westy |
Posted: Tue Feb 25, 2014 9:43 am Post subject: |
I don't think there are any 10x8's left. The 10x8 patio awning is not the same as the Camp Out case awning. There is only one 11.5 x 6.5
If anyone is passing through Elkhart IN, here is another great close out deal (they only have 11.5 footers). Probably a better awning and the same price, just no shipping. Maybe that's why they have some left. These have not been made in at least a couple years.
http://www.factoryrvsurplus.com/products.php?product_id=1521 |
Zero419 Samba Member
Posted: Wed Feb 26, 2014 5:15 am Post subject: |
I just ordered the GW awning mounts.
21.00 shipping _________________ 1987 Westy Auto Bostig 2.0 Ztec |
NxNWesty Samba Member
Joined: September 21, 2012 Posts: 34 Location: Seattle
Posted: Mon Mar 17, 2014 11:13 pm Post subject: |
Finally got around to installing my awning 10' 6.5'. I used washers as spacers between the GW and awning bracket.
The bolts were pretty close to the pop top seal, so I cut them down, now there is plenty of clearance. Forgot to grab a pic with the top closed.
I cut down the corners of the GW bracket, and drilled holes into the awning bracket to put the bottom bolts.
I only used two brackets and it feels steady both awning extended out, and in. _________________ 1985 Westfalia '92 EJ22 KEP Adapter |
Posted: Tue Mar 18, 2014 7:00 am Post subject: |
Zero419 wrote: |
21.00 shipping |
they just had a 15% off deal yesterday. Off course I forgot to order mine yesterday _________________ 1987 Westy |
Posted: Tue Mar 18, 2014 10:19 am Post subject: |
I have the awning brackets bolted to the GW brackets now. I used the low profile fasteners pictured above.
I used a large nut for a spacer on the bottom.
Now I have to attach them to the van and then attach the awning to the brackets. _________________ 1987 Westy Auto Bostig 2.0 Ztec |
Posted: Tue Mar 18, 2014 5:15 pm Post subject: |
I got it mounted to the van and it looks great. Now I just have to bolt it to the brackets.
I assumed it would stay fairly level while winding it out, instead it drops down at such an angle that I had my wife hold it up untill fully deployed with legs. Is this typical? _________________ 1987 Westy Auto Bostig 2.0 Ztec |
Posted: Tue Mar 18, 2014 6:09 pm Post subject: |
This is about how I set mine up. But mine is the shorter one so it goes up quicker.
Anyway looks like they have a different market in Germany.
Posted: Tue Mar 18, 2014 6:27 pm Post subject: |
Aha.
Thanks. _________________ 1987 Westy Auto Bostig 2.0 Ztec |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Wed Mar 19, 2014 11:22 am Post subject: |
yeah I've been a fairly carefully with mine...concerned the the weight might snap a hinge if winding out too far without the leg support.
Speaking of leg support, somehow that german woman really makes setting up an awning seem like a naughty activity. _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Thu Mar 27, 2014 6:57 pm Post subject: |
My 10' Faux-Fiamma is still in the garage in its shipping box. I have been considering how to mount it as I want and need to keep the Thule Racks installed. Currently the big knob on the Thule Rack is right in the way, not to mention the cross bars "may" be sticking out too far and may cause the Faux-Fiamma to interfere with the slider.
What I'm thinking of doing is removing the knobs, cutting a piece of box tubing to fit vertically between the gutter mount and the cross bar. (Illustrated in yellow, red indicates the future Faux-Fiamma installed)
The vertical tubing would have a hole drilled in the outside large enough to place a nut inside to replace the big knob. (Nut illustrated in green)
Once I replicate that on all 4 Thule mounts, I could screw the factory Faux-Fiamma mounts directly to the square tubing. Due to the curvature of the side of the van, I thought perhaps a washer or two could go between the square tubing and the Thule mount on the front and rear locations, as needed.
The only question still unanswered is if I would have to cut the cross bars off to mount the FF high enough. My short rack mounts don't leave much room. I think this mount adaptation would give me a very sturdy base.
Thoughts, concerns, alternate ideas?
_________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Posted: Sat Mar 29, 2014 3:05 pm Post subject: |
So today I trial mounted the 10' x 8' burgundy model to my Westy.
It fits fine and is a nice awning.... but I already had an awning (albeit smaller) that I liked and though this was a great deal I was thinking I'd like it a lot more than my current awning. Turns out that my current awning gives me about 1 to 2 inches of additional headroom and at 6' 4" that makes a difference to me. The Aleko awning rubs my head and my current one doesn't.
So I've decided to stay with my current awning and sell this one with the GoWesty mounts at my cost.
Edit: The awning is sold. It went to a Baywindow Bus so I still have the three GoWesty brackets available. I'll put them in the classifieds.
Ad for brackets is here:
http://www.thesamba.com/vw/classifieds/detail.php?id=1621393
Thanks. _________________ Dave O
The Western Syncro build
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Sat Mar 29, 2014 3:35 pm Post subject: |
davevickery wrote: |
I call tucking _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9800 Location: Mt Lemmon, AZ
Posted: Sat Mar 29, 2014 4:36 pm Post subject: |
TequilaSunSet wrote: |
I call tucking |
Posted: Sat Mar 29, 2014 5:22 pm Post subject: |
I call tucking |
ha, yer right...just saw the adam's apple @ 0:25! _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
