Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Sun Aug 17, 2014 1:09 pm Post subject: |
goffoz wrote: |
No discernable noise at all from the scoop.
In my case the intercooler fan sound is reduced, inside and outside the van |
A would have a little problem with the extra screws in the body. Rust is a devil. Maybe u could fix it in some way to the original fixing points.
Edit: sorry, was reading ur other awnser after writing this. |
goffoz Samba Member
Posted: Sun Aug 17, 2014 6:13 pm Post subject: |
Passengers die seems to be a go...now to mirror my work
...for the drivers side |
drossen Samba Member
Posted: Sun Aug 17, 2014 7:01 pm Post subject: |
I'd be interested in a full set for an 87 Vanagon, whether I have to bend a bit to fit or not.
Thanks |
Gorge Runner Samba Member
Joined: February 24, 2008 Posts: 199 Location: Portland, OR
Posted: Sun Aug 17, 2014 7:47 pm Post subject: |
These look really nice.
Put me on the list!
Marc _________________ 91 Carat
EJ205 WRX |
angrychicken Samba Member
Posted: Sun Aug 17, 2014 9:02 pm Post subject: |
I'm down and paypal ready! |
'88MoneyPit Samba Member
Joined: August 26, 2013 Posts: 146 Location: California
Posted: Sun Aug 17, 2014 10:04 pm Post subject: |
I'm in for a set with screens
Stephen |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Mon Aug 18, 2014 9:20 am Post subject: |
Corwyn wrote: |
A beautiful design and application, but I'm curious to see the actual performance figures.
As was explained to me by a mechanic who worked on the Vanagon assembly line, the vent design was engineered to draw air OUT of the engine compartment by the wind blowing over the "gills". Pushing air INTO the engine bay is a different approach.
No criticism - that mod piece is a work of art. |
Any more discussion on this? I would also think the air would be meant to flow in, especially with syncros etc. having factory snorkels...does Corwyn's point mean that air would be flowing out of the snorkels rather than in? _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
?Waldo? Samba Member
Posted: Mon Aug 18, 2014 9:29 am Post subject: |
Corwyn's mechanic was just wrong. Use the search a little and you can even find manometer readings at the scoop area and inside the engine compartment. It is irrefutable that when driving at any speed the air flows down the D-pillars and into the engine compartment. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12103 Location: Port Manteau
Posted: Mon Aug 18, 2014 11:19 am Post subject: |
This ^^^ _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Mon Aug 18, 2014 1:16 pm Post subject: |
Andrew A. Libby wrote: |
Oh yeah. And if you prop the license plate door open you'll see a meaningful drop in engine temps at highway speeds. I was only using hacked up cardboard for the scoop extenders but they were mighty effective. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Mon Aug 18, 2014 1:22 pm Post subject: |
Jake de Villiers wrote: |
Oh yeah. And if you prop the license plate door open you'll see a meaningful drop in engine temps at highway speeds. I was only using hacked up cardboard for the scoop extenders but they were mighty effective. |
With the added heat in the engine bay due to the turbo, I had been contemplating spacing the license plate out a half inch or so. Seems like a good way to get some more heat out. Haven't tried it yet though. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Mon Aug 18, 2014 4:28 pm Post subject: |
[quote="tarandusVDub"]
Corwyn wrote: |
Any more discussion on this? I would also think the air would be meant to flow in, especially with syncros etc. having factory snorkels...does Corwyn's point mean that air would be flowing out of the snorkels rather than in? |
My 89 GL 2WD has a "snorkel" on the passenger side.
Don't all 2.1s have an air intake "snorkel" leading to the air cleaner from the vent area?
One more vote for supplying air.. not for drawing air out.. Otherwise you'd be limiting the air intake to the AFM/EFI, as well? _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Posted: Mon Aug 18, 2014 6:29 pm Post subject: |
shadetreetim wrote: |
With the added heat in the engine bay due to the turbo, I had been contemplating spacing the license plate out a half inch or so. Seems like a good way to get some more heat out. Haven't tried it yet though. |
You could also take a chassis punch and put a few holes in the rear valance. Fit some black grommets and they might look almost factory! _________________ '84 Vanagon GL 1.9 WBX
jobenaus Samba Member
Posted: Fri Aug 22, 2014 10:11 am Post subject: |
You could also take a chassis punch and put a few holes in the rear valance. Fit some black grommets and they might look almost factory! |
I put a slit 2 inch piece of 5/8 hose over the top of the licence plate clip where it closes so the door stays open on the top and sides because my temps were always a bit on the high side....it made zero difference. My advice....don't butcher your van with unecessary holes. |
lloydy Samba Member
Joined: September 15, 2010 Posts: 715 Location: cheam surrey
Posted: Fri Aug 22, 2014 12:47 pm Post subject: |
Somehow missed this thread, even though you alluded to it on a post of mine
i'd be interested in a set please _________________ 16" syncro multivan pop top AHU TDI
“Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life.” |
PDX_Greg Samba Member
Joined: August 26, 2012 Posts: 39 Location: Portland, OR
Posted: Fri Aug 22, 2014 1:15 pm Post subject: |
Been following this thread for awhile....would also like to express my interest in buying one of these if they ever go into produciton. _________________ 1987 Full Camper Westfalia, 2.1 WBX |
goffoz Samba Member
Posted: Fri Aug 22, 2014 9:43 pm Post subject: |
Production is happening, I'm spending hours welding up left and right dies in 1/4" plate so I can bang out a dozen pairs,
Also, have improved the screen fitting and the attachments,The scoop will use the stock anchors.2 screws at the top
You'll need some of these...or similar
soon..I want this to be good for everyone
thanks for your patience
As an aside, today running around for a couple of hours in stop and go traffic,
I could watch my IAT's go down 20F every time I got 30mph+
ambient was 96F..30+mph 101F to 110F ..182/190F coolant
sitting at idle (traffic light) 126F..188/197F coolant
freeway temps were lower...cruising(no boost)
Scoop does work |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1348 Location: PNW - its a dry rain.
Posted: Sat Aug 23, 2014 9:58 am Post subject: |
Thanks for ur efforts. Having tried this I can personally attest that fabrication a metal scoop is a lot of work. Thanks much for taking this on for the benefit of the community cause you certainly don't make money doing these small run custom projects! _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2749 Location: San Luis Obispo, CA
Posted: Sat Aug 23, 2014 2:35 pm Post subject: |
keep me on the list of buyers!
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4065 Location: East Kootenay, British Columbia
Posted: Sat Aug 23, 2014 2:53 pm Post subject: |
I do love my Zetec conversion, but have to admit that the extra heat it generates under the engine cover (from the exhaust manifold looping up before it goes down, something I wish Jim would look into changing with a custom manifold)((but that's another thread!)) is a bit of a bother.
Sometimes on long hot hill climbs I'll pull over and open the license plate lid with a bungee cord to let some heat escape. I've even thought about changing the license plate lid to a steel mesh and mounting the plate elsewhere to allow more heat to escape the engine compartment.
I'm thinking that with these scoops and Bostigs new air box setup the engine compartment will stay much cooler and other mods won't be necessary. (although a custom manifold would still be nice Jim )
Keep up the great work goffoz! _________________ Currently:
