Wiring loom details
beetleseb
beetleseb is offline
PostPosted: Tue Nov 26, 2013 3:29 am    Post subject: Wiring loom details Reply with quote
Hi Guys,
Firstly, I realise that several people make good wiring looms but I enjoy making them and have found several sources for the components.
The cars a june 1950. Sadly the whole loom was removed before I bought the car.
I have found this link which is a great help for the main loom
http://www.historicvws.abelgratis.com/technical/wiring_looms/split_main_loom.htm
But wondered is anyone had similar details for the front.
Also wondered if anyone knew when they went from cloth outer to PVC outer?? I know the wires should be cloth covered but when did the outer change?
Lastly does anyone know the colour of the thicker dynamo cable (6mm dynamo to battery) and if its orange does anyone have a source for it?? Can only get a few colours that thick unless I order 100m
Seb
Wanted - OG 50 split bug door panels, brown mats and old running boards
splitjunkie
splitjunkie is offline
PostPosted: Tue Nov 26, 2013 5:14 am    Post subject: Reply with quote
The wires changed from Cloth covered to PVC before they switched from the cloth looming. My Oct '51 has PVC wiring with cloth loom except for the harness that goes to the hi beam switch. It is PVC wiring and loom and the loom has Siemens printed on it.
Chris
beetleseb
PostPosted: Tue Nov 26, 2013 5:40 am    Post subject: Reply with quote
Hi
Cheers dude. Good to know.
I assume my wiring should still be braided. Anyone know for sure? My pod had some remnents of braided cable but who knows for sure if it was OG to the car!
Any more info greatfully received
Seb
splitjunkie
PostPosted: Tue Nov 26, 2013 5:54 am    Post subject: Reply with quote
Your car should have the cloth covered wire with the cloth braided loom around the harness.
Chris
beetleseb
PostPosted: Tue Nov 26, 2013 5:57 am    Post subject: Reply with quote
Cool, thought so
Just need to double check the colour of the 6mm wire that goes from starter to dynamo.
And if anyone has a front loom to measure I would be greatful. Although I can build it in situe and do it that way
Thanks
Seb
aa390392
aa390392 is offline
PostPosted: Tue Nov 26, 2013 10:56 am    Post subject: Reply with quote
I'm not certain whom does cloth wiring for older VW's but this is a great source for those that are interested..... http://www.ynzyesterdaysparts.com/electrical/
56oval
beetleseb
PostPosted: Tue Nov 26, 2013 4:32 pm    Post subject: Reply with quote
Cheers
Useful company but way too far from me!!
I'm happy with the main loom and the lower front loom for the main lights but would love some info on the upper front loom.
I can chase a few of the wire but without an old loom to copy its a little complex. The closest thing I have to a template is the photo on the zarwerks website Embarassed
A list of whats in the loom would be great, an idea of dimensions would be amazing! Anyone got an old one to measure
Seb
johnshenry Premium Member
johnshenry is offline
PostPosted: Tue Nov 26, 2013 4:53 pm    Post subject: Reply with quote
I have been making split harnesses for 10+years now. As posted previously, Cloth on cloth would be correct for 1950. As for the battery positive cable, the documentation for 1950 (see the wiring page in the the tech section) calls for black. in '51 it specifies "Black or Red". I sell both, but most people want red.
As for the dimensions of the upper front, below is a partial paste of a spreadsheet that I use to record dimensions. Of course this only gives you wire length, not loom exit location. I have built up a large collection of original harnesses over the years, from '46-'53, as well has Hebs and convertibles, and dimensions I have are very accurate.
I assemble upper fronts on a "nail board" and I do not presently have the harness diagrammed in electronic format that shows wire branch exit locations. I have it "on my list" to do one day, but don't presently have it done. Hopefully the table below is of some use to you.
Also note that 20 gauge wire is not available in cloth from my suppliers and it is the nearest AWG equivalent to 0.50mm^2 wire. For these, I use 19guage.
John Henry
'57 Deluxe
'51 11E Standard Sunroof (PhotoBucket resto pics)
aa390392
aa390392 is offline
PostPosted: Tue Nov 26, 2013 5:41 pm    Post subject: Reply with quote
Of Course impeccable work, I misread you were looking for suppliers of cloth wire mybad Embarassed
56oval
beetleseb
PostPosted: Wed Nov 27, 2013 1:11 am    Post subject: Reply with quote
Hi
Suppliers are always useful. Even if for others and not me.
John. That's amazing and very kind of you to share. I can happily go from there and use the car as the peg board for that upper front.
Thanks again!
Seb
beetleseb
PostPosted: Wed Nov 27, 2013 2:19 am    Post subject: Reply with quote
For any other UK guys I find autosparks.co.uk have most in stock at good prices. They also offer a branding service.
A quick price up reveals you don't save much! Unless like me, you like making looms then buy johns!
