stuvy Samba Member
Joined: March 27, 2009 Posts: 45 Location: lethbridge, Alberta
Posted: Fri Dec 13, 2013 9:24 pm Post subject: 1970 squareback, the nameless project. |
I picked up a square many years ago. It sat unattended and alone in a field since 1980. I usually have a name for most of my projects and cars but haven't found a name for this car yet.
Some pictures of it when it was first towed out of the field before being returned for a few more years.
Fairly complete but definitely in need of some serious work. |
stuvy Samba Member
Posted: Fri Dec 13, 2013 9:29 pm Post subject: |
After many years of sitting at the farm I finally brought it home. I started with the fuel system. Had the tank cleaned and new lines and fuel pump, new injector seals, injectors and all that. Under the hood was a ton of mouse houses and poop. Only picture I have left.
I then put brand new callipers, pads, rotors and lines, New wheel bearings and all that jazz. I also did a rear disc conversion and converted it to a Porsche bolt pattern.
17x7.5 et51 Porsche cayenne wheels.
stuvy Samba Member
Posted: Fri Dec 13, 2013 9:35 pm Post subject: |
Then I went to work on some of the interior. The rear deck was rusted bad. So out it came.
Before cutting the floor out I tried to fire the engine. I realized rather quickly that one of the heads was screwed up. Pulled the motor to replace the heads and do so cleanup.
But I have no pictures Of that.
At this point I decided that I won't be happy with a 1600cc engine. Work would be needed to fit something better in the future.
Fix the hole.
Then build a frame.
All covered up and sound deadened.
stuvy Samba Member
Posted: Fri Dec 13, 2013 9:37 pm Post subject: |
I've been busy getting interior progress made while doing this too.
Hand done pinstriping on the glove box.
Steering wheel and new dash board.
stuvy Samba Member
Posted: Fri Dec 13, 2013 9:41 pm Post subject: |
The engine sitting nicely in it's hole.
More interior.
Stinger.
Needs more low.
Blacker out bumper, handles, headlight bezels and all that.
stuvy Samba Member
Posted: Fri Dec 13, 2013 9:44 pm Post subject: |
I have new window runners and have eliminated all the exterior and interior chrome.
The engine is being wired to run off a megasquirt.
I have lots of little touches to add to the car as I keep building it.
I need suggestions for center caps on the wheels, hiding a stereo and speakers and what will finish up the hatch floor nicely. I was thinking cherry hardwood or a street sign. |
GjMan Samba Member
Joined: June 05, 2004 Posts: 822 Location: Grand Junction, CO
Posted: Sat Dec 14, 2013 8:14 am Post subject: |
Great work so far. Your new headliner looks a lot smoother than my first attempt.
Why raise the floor above the engine? Planning a Subaru swap in the future? Which would be cool.
How's the auto trans working?
As to what to cover the raised floor with, depends upon the look you're going for. Since I'm a stock-appearance kinda guy, I'd try to fab a rubber mat similar to what was there originally. Or carpet the whole thing with the stuff I'm using on the floor. |
stuvy Samba Member
Posted: Sat Dec 14, 2013 4:16 pm Post subject: |
The plan is to eventually get a suby back there. As far as the trans goes, I have no idea. I've never had the car run yet. I won't be satisfied until I can burn the tires off in with a nice burnout. |
GjMan Samba Member
Posted: Sun Dec 15, 2013 8:01 am Post subject: |
The auto trans, if in good condition, will work well with a stock or mild engine. With a Subaru engine, probably not well--if you can even find an adapter to mate the two. Actually, mating the auto trans to the Subaru engine would not be difficult. The challenge would be mating the VW torque converter to the Sub crank. And fabbing a proper kick-down linkage. And then hoping the auto can take the Sub's increased power. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Sun Dec 15, 2013 10:28 am Post subject: |
They use the 003 automatic transmission in drag racing VW's, so I think they will handle lots of power. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
GjMan Samba Member
Posted: Mon Dec 16, 2013 8:17 am Post subject: |
Mike Fisher wrote: |
They use the 003 automatic transmission in drag racing VW's, so I think they will handle lots of power. |
Thanks, Mike. I learned something new. Bonus feature is if you can mate the AT to the Sub engine, you don't need to convert the pan to standard. |
stuvy Samba Member
Posted: Mon Dec 16, 2013 10:42 am Post subject: |
Mating the tranny to the subby is easy several companies make adapter kits. Remember this is a super common swap in vanagons. |
stuvy Samba Member
Posted: Wed Dec 18, 2013 8:07 am Post subject: |
Spent the last couple nights in the garage got alot of the wiring taken care. Replaced the fuse panel, got most of the lights working although the brake lights still don't work.
I've noticed on the shift (automatic) there is nothing for the reverse or start switch to contact. Does anyone have a picture of that area of the shifter so I can see what I am missing?
Otherwise its been coming together rather slowly. I hope to have it running for a car show we have in january. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Intrinsic Samba Member
Joined: November 16, 2011 Posts: 262 Location: Clearwater, FL
stuvy Samba Member
Posted: Wed Dec 18, 2013 10:05 am Post subject: |
Mark I haven't even looked at the brake switch. I am thinking I didn't reconnect the wires on the switch, but haven't got the nose back in the air.
Intrinsic that file would be a great help, it would be a nice base map to start with. Thankyou!
Oh and 1 more thing. The bulbs in the fuel gauge are burnt out. No signal light is my main concern. But for the life of me I can't get the bulbs out. Any ideas on replacing them? |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Wed Dec 18, 2013 12:14 pm Post subject: |
stuvy wrote: |
I've noticed on the shift (automatic) there is nothing for the reverse or start switch to contact. Does anyone have a picture of that area of the shifter so I can see what I am missing? |
Here you go -- pay no attention to the loose wires in the pic, they were cut when I got the car. They are for the shift console illumination.
Here's a closer view of the relevant wiring, and the contact mounted to the shifter handle:
And the contacts. The right hand set are the starter contacts; the left hand set are for the reverse lights. The car will only start in neutral:
_________________ 71 Elm Green FI A/T Squareback |
stuvy Samba Member
Posted: Wed Dec 18, 2013 12:27 pm Post subject: |
That is absolutly perfect! I am however missing the contact piece from the shifter. I guess I am going to have to track that down, or maybe fab something. |
Posted: Wed Dec 18, 2013 4:24 pm Post subject: |
I saw this plastic block in the classifieds yesterday -- do you have one of these?
http://www.thesamba.com/vw/classifieds/detail.php?id=1518559
It's from a 73 and is made a little differently, so it might take some modification to fit on your car if you need one. It does have a third set of contacts so the car can be started in Park, though.
Maybe a WTB ad could find you a contact for the shifter handle. _________________ 71 Elm Green FI A/T Squareback |
marchi Samba Member
Joined: August 10, 2005 Posts: 646 Location: Abilene, Texas
Posted: Thu Dec 19, 2013 2:09 pm Post subject: |
I think I have a shifter for parts if you need some, and the block of the 73 ables you to start in park, _________________ I drive my VW or I walk
'70 Squareback
'21 Tiguan (daughters)
SOLD
'69 Fastback (Flamer) |
