bart1 Samba Member
Joined: January 08, 2011 Posts: 12 Location: Hamilton, AL
Posted: Fri Jan 17, 2014 4:12 am Post subject: |
I love them all. I only have a 166N and 190L. The 168N looks like a great unit, would love to add one of those to the garage. And the cabinet is fantastic too, of course. Again, all very nice! |
bart1 Samba Member
Posted: Fri Jan 17, 2014 4:14 am Post subject: |
Posted before on here, but here is my Assistent, with added Fostoria lamp and Craftsman vise. Handy little cart.
Dutch79 Samba Member
Joined: October 21, 2013 Posts: 70 Location: Nederland
Posted: Fri Jan 17, 2014 4:49 am Post subject: |
bart1 wrote: |
I can buy more items of the 166/168 if I would have the space. They're pretty cheap over here. Too bad shipment is so expensive otherwise I would buy another one for you |
bart1 Samba Member
Posted: Fri Jan 17, 2014 6:31 pm Post subject: |
I come to Germany every summer, just no good way to bring one back. Maybe we can find one and work out a shipping deal |
tomas persson Samba Member
Joined: December 09, 2002 Posts: 220 Location: Sweden
Posted: Sat Jan 18, 2014 12:47 pm Post subject: |
Here you have a picture of my key...the one you miss.
Posted: Sat Jan 18, 2014 2:09 pm Post subject: |
Okay, thanks! I think I have to let the new one rust some time to make it look old like this one |
Posted: Tue Jan 21, 2014 11:52 am Post subject: |
Well, today I called the lock smith to check if the work on my lock/key was ready, but it turned out that the missing parts in the lock could not be replaced, so they couldn't help me
So, I bought a blank key that fitted the lock and had a vintage design.
I customised the lock and key, so the key can be used as a locking knob. The disadvantage is that the key cannot be removed and will stay permanently in the lock. That's also an advantage because the key cannot be lost again!
mac_intosh Samba Member
Joined: December 27, 2011 Posts: 146 Location: Remscheid, Germany
Posted: Tue Jan 21, 2014 1:14 pm Post subject: |
Good point! |
Posted: Wed Jan 22, 2014 11:42 am Post subject: |
New sliding rails are on their way from Germany to replace the worn out/broken ones on the drawers of my Hazet 168N:
Jacco Verveer Samba Member
Posted: Thu Jan 23, 2014 12:55 pm Post subject: |
nice wall cabinet!! regret not buying one |
Posted: Fri Jan 24, 2014 8:10 am Post subject: |
So, next was the 168N. The sliding mechanism of the rails of one drawer was missing, so that drawer wasn't sliding smoothly and also dropped out of the Assistent
Is received 4 pairs of which I already replaced this worst drawer.
Stuff needed (grinder, rivet pliers and rivets 4mm):
Old and new!
Posted: Tue Jan 28, 2014 3:18 pm Post subject: |
Started the renovation of the '76- Hazet 152.
Removed a couple of stickers to reveal the original color:
And also found a sealed plastic bag with (probably) the original lock and 3 keys for the front lid:
It says 'SUL'. Familiar to anyone?
Next thing is rust removal. I decided to bring it so a company that has a acid tank. The only way to remove the rust on the inside, because the drawers are welded and cannot be removed. |
Posted: Fri Jan 31, 2014 6:58 am Post subject: |
Got the table top toolbox back from the company.
It was treated as follows:
-Bath with hydrochloric acid (de-rusting)
-Powerwashed with water
-Bath with phosphate solution (rust prevention)
The result :
The drawers are now opening easier and the complete inside is derusted and treated to prevent for further oxidation. This was the only way because (like said before) the drawers are welded and could not (easily) be removed.
Now it needs to dry for a couple of days (takes a while with the cold weather at the moment). |
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Fri Jan 31, 2014 7:44 am Post subject: |
FYI: Oxalic acid is used for rust removal. That's what is in naval jelly and similar products.
Hydrochloric is very strong and can over etch the metal.
A pro knows when to yank it out, a DIYer may ruin the piece. And you don't want it on your body, you'll get burned.
Oxalic acid is cheap, if you can't find it labeled as that, it's sold as deck brightener. Mix a saturated solution and soak your pieces in it. Won't hurt you if you splash yourself, and almost impossible to over soak anything.
Good luck! _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
Posted: Thu Feb 20, 2014 7:57 am Post subject: |
First picture of the finished restoration of the Hazet 152:
The front lid needed welding due to the bad condition, but was too unpratical to use on my workbench, so I decided not to restore/use it on this toolbox. |
Posted: Fri Feb 21, 2014 8:20 am Post subject: |
...and moved it to my workbench (together with a Heuer vise and Creusen grinder):
Posted: Fri Feb 21, 2014 11:54 am Post subject: |
Amazing job again. Never thought that it would look so good again!
Respect |
Posted: Fri Feb 21, 2014 12:15 pm Post subject: |
Thanks. Would like to do a similar restoration in the future.
If you have another interesting item for me in the future, let me know |
Posted: Tue Feb 25, 2014 7:45 am Post subject: |
Gave the Hazet 100 also a good clean inside and put it up on the wall. Man, it was dirty after a life of 62 years
