ipis Samba Member
Joined: November 18, 2008 Posts: 92 Location: granada
Posted: Sun Dec 15, 2013 4:41 pm Post subject: Engine ct1600 t3 into type 3 squareback , is posible is same |
I have a question, is equal to or support one ct t3 volkswagen engine 1600 with one of type 3 squareback? I can put it? That recomendáis me? |
Slow 1200 Samba Member
Posted: Mon Dec 16, 2013 2:11 am Post subject: |
no |
ipis Samba Member
Posted: Mon Dec 16, 2013 3:12 pm Post subject: |
Why? , and the block? And i Put my pieces is valid? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Dec 16, 2013 3:25 pm Post subject: |
Your English is hard to understand ipis. Maybe you could type it up in Spanish and use a translation application to translate your Spanish to English? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
ipis Samba Member
Posted: Mon Dec 16, 2013 3:46 pm Post subject: |
hi mike such these, tell me that the engine will not be valid, but the engine block and? and I put all of mine? is very difficult to find a squareback engine |
Posted: Mon Dec 16, 2013 3:55 pm Post subject: |
notchback,fastback,squareback engines are all the same and will interchange if that is what you are asking? _________________ https://imgur.com/user/FisherSquareback/posts
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Dec 16, 2013 4:29 pm Post subject: |
ipis wrote: |
Is this a swing axle or IRS car? What year? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
ipis Samba Member
Posted: Tue Dec 17, 2013 1:47 pm Post subject: |
my car is a 69 year squareback is a second series
And the motor of adaptar is this
CT 039746 |
ipis Samba Member
Posted: Tue Dec 17, 2013 1:59 pm Post subject: |
And this si my motor
Posted: Tue Dec 17, 2013 7:12 pm Post subject: |
Your new motor looks like a bus or 411/412 engine? They will fit in your squareback with some work/welding etc. Read Nate's thread below from the beginning for some ideas.
http://www.thesamba.com/vw/forum/viewtopic.php?p=6984238#6984238 _________________ https://imgur.com/user/FisherSquareback/posts
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Tue Dec 17, 2013 7:16 pm Post subject: |
I don't think its a type 4 engine, looks similar but not like a type 4 as I know it. Tin ware is not whats normally on the type 4 neither is the weird manifold/carby setup that this has. Is that a bus 1600 engine? |
Posted: Tue Dec 17, 2013 7:43 pm Post subject: |
vlad01 wrote: |
It's way too small to see clearly, but it does look like a Type 4 or 914- 912E setup. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vlad01 Samba Member
Posted: Tue Dec 17, 2013 8:00 pm Post subject: |
vlad01 Samba Member
Posted: Tue Dec 17, 2013 8:04 pm Post subject: |
google'd
nah definitely a 1600 bus engine. So that mean he can use the long block?
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Tue Dec 17, 2013 11:28 pm Post subject: Re: Engine ct1600 t3 into type 3 squareback , is posible is |
ipis wrote: |
If it helps other people reading this thread - I read this as him trying to install a T3 engine into a Squareback.
T3 = 3rd generation of Bus = Vanagon engine.
But I'm not sure that is a Vanagon engine? _________________ How to Post Photos
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 479 Location: Australia
Posted: Wed Dec 18, 2013 3:56 am Post subject: |
CT it's type 1-based, but with inbuilt oil filter and hydraulic tappets, heads are notoriously weak, cylinders are one-offs too, most people just use regular type 1 heads and p&c's when they rebuild the engine
to use it in a type 3 you would need to use all the type 3 tinware from your original engine, but I'm not sure at all about the interference between fan housing, oil filter and engine support bar
and now in spanish for the OP
el motor CT está basado en el tipo 1, pero con filtro de aceite incorporado y taqués hidráulicos. las culatas són muy frágiles, los cilindros son específicos también, la mayoría de gente utilitza culatas y cilindros normales de tipo 1 cuando rehacen el motor
para usarlo en un tipo 3 necesitarías usar todas las chapas de tu motor original, pero no estoy nada seguro de la interferencia entre la carcasa del ventilador, el filtro de aceite y la barra de soporte del motor |
ipis Samba Member
Posted: Wed Dec 18, 2013 4:49 am Post subject: |
more thanks for the info
muchas gracias por la info me ha servido de mucho |
