earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sun Oct 19, 2014 6:27 am Post subject: |
1967250s wrote: |
I also came across a sticker on the back side of the door:
Detail. If anyone can translate, that’d be great!
Quote: |
Took awhile to get this, quite the challenge, yet the translation is not quite correct.
Who a stranger may not prove to be friendly; which was probably never used in a foreign country while traveling.
Friedrich Rückert (1788-1866), German poet and translator- Knew 30 languages!
Probably more correct is; Who is a stranger may not be friendly,
The second one goes like so:
The youth require the intelligence, the wisdom, but do not have it,
Finally it comes to the Aged, but they use/benefit from it not
http://en.wikipedia.org/wiki/August_Silberstein |
Cool, two stickers. How close in production date are the two westys?
Were they both Tourist delivery buses? |
jjjjack Samba Member
Joined: August 08, 2005 Posts: 1013 Location: Gainesville, FL
Posted: Sun Oct 19, 2014 11:42 am Post subject: |
zuggbug wrote: |
jjjjack wrote: |
zuggbug wrote: |
OUTSTANDING! I love the sticker on the door.
cant wait to check this beast out at Bulli |
Just realized I wasn't getting notices from your '56 thread. Looking great! Hope you can make it to BB with yours....it'll be the year of the Westy |
Not much happening with it at the moment, life has a way of consuming bus time.. |
I feel ya on that one Paul!!!! _________________ Jack Stenner
1959 Mango Westfalia SO-23
1953 Porsche 356 Coupe
IG:j.stenner |
Posted: Sun Oct 19, 2014 11:45 am Post subject: |
1967250s wrote: |
Thanks, I like that second one better now
1967250s wrote: |
By the way, absolutely incredible job on the paint stripping, can you describe the complete method? I saw you used acetone, but how did you scrape off and remove the top coat? Steel wool, sandpaper, what? As for time, how can you price an original paint job? Now if we could just get original cellulose? laquer? paint. |
Thanks. The top coat that had been applied to my bus was reactive to Acetone, while the factory paint wasn't. I used a spay/mist bottle to apply the acetone and either a 0000 steel wool pad or plastic razor blade to remove the paint. 90% of the time, the best bet was the plastic razor. Work from the top, down, so the runnoff works for you, loosening the paint. It takes practice, after doing anything as long as it took me, that happens For detail areas, I'd saturate a wad of paper towels and clamp it to the area to loosen the paint.
HTH _________________ Jack Stenner
IG:j.stenner |
Posted: Sun Oct 19, 2014 11:55 am Post subject: |
zehbeh wrote: |
Thats how I would traslate the first one:
Who doesn't like to be friendly to a stranger, has probably never travelled to a foreign country himself. |
Ah, like that better for the first one, too. Thanks!
Sure would be interested to know if anyone else has found embedded poems?
I probably won't get to it for a while, but I'm wondering what's behind the other cargo door _________________ Jack Stenner
IG:j.stenner |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Tue Oct 28, 2014 4:02 am Post subject: |
Count down to Bulli! Still waiting on my paint. Supposedly it will be ready Wednesday. In the mean time there is plenty of work to do. The only area where there was previous bodywork was at the forward, lower cargo door hinge. Evidently it was smacked long ago. They probably did their best with the parts available at the time, but the bolt retainer was missing and they had through bolted the hinge into the fender well. The metal was stretched and cracked to the point were the best fix was to cut it out.
Hinge area exposed:
Removed:
Weld in:
A little grinding:
First coat of etching primer:
Other than that, I've been pushing out little dings and dents on the rear, finished prepping the popouts for paint, etc. Since I essentially only have this weekend and a couple of days next week before I need to leave for Bulli it won't be "finished"...more of a work in progress. Next up is to push/pull out the dents on the nose. If I can smooth that up reasonably, get the popouts installed, paint/install the bumpers, and paint the dogleg before Thursday of next week I'll be happy There will still be a lot of other work that needs to be done, but I'm not going to rush it. _________________ Jack Stenner
IG:j.stenner |
Posted: Tue Oct 28, 2014 4:43 am Post subject: |
go jack go...you can do it. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Wed Oct 29, 2014 8:02 am Post subject: |
Just got back from the paint store. Ouch...here's what $1500 worth of PPG Concept, color matched Mango (1gal), Seagull (1gal), Beige (2qts. Westy interior color) and Silver White (1 qt.), with reducer, hardener, blender looks like:
IG:j.stenner |
grailoc Samba Member
Joined: March 25, 2004 Posts: 1441 Location: FRANCE and now QUEBEC city
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Wed Oct 29, 2014 9:45 am Post subject: |
Friedrich Rueckert is my home town poet. _________________ regards
Uli
Posted: Wed Oct 29, 2014 9:55 am Post subject: |
grailoc wrote: |
I would be interested about the formula about interior beige specifc to the westie's? |
They didn't note any mix specs on the can, just labeling it "Custom Formula" They matched it to the paint brushed onto the inner cargo door. I haven't had a chance to check it, yet, though. Trying to get the popouts painted today so they'll have plenty of time to dry before reassembly. _________________ Jack Stenner
IG:j.stenner |
Stocknazi Samba Member
Posted: Wed Oct 29, 2014 5:08 pm Post subject: |
jjjjack wrote: |
I have some questions for the experts:
3. I can see Seagull underneath the repaint on the tent mount towards the top. So despite the lack of Seagull towards the bottom of the mount, I'm assuming they should be Seagull:
Thanks! |
Is this true of all subhatch Westys?
I saw that the tent mounts on Greg's 56 were painted dove blue as well.
My mounts appear to have been painted silver, similar to earlier tent poles.
Also, are the bolts holding the mounts to the roof og? _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Thu Oct 30, 2014 2:25 am Post subject: |
StockNazi wrote: |
jjjjack wrote: |
3. I can see Seagull underneath the repaint on the tent mount towards the top. So despite the lack of Seagull towards the bottom of the mount, I'm assuming they should be Seagull: |
My mounts appear to have been painted silver, similar to earlier tent poles. |
Interesting. I don't know. Your bus is earlier, right? Maybe a change? Maybe someone with early Westy experience will chime in....
StockNazi wrote: |
Also, are the bolts holding the mounts to the roof og? |
They don't appear to have ever been removed, and based on every thing else I've come across on this bus (other than engine), I'd be extremely surprised if they weren't og. _________________ Jack Stenner
IG:j.stenner |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Thu Oct 30, 2014 3:44 am Post subject: |
jjjjack wrote: |
StockNazi wrote: |
jjjjack wrote: |
StockNazi wrote: |
They don't appear to have ever been removed, and based on every thing else I've come across on this bus (other than engine), I'd be extremely surprised if they weren't og. |
The tent brackets on Jacks bus look all original to me. I think they are usually painted, but like anything Westfalia there are exceptions. The brackets on my blue '55 Campingbox are painted silver, but I am not convinced that bus has ever been to Weidenbruck. The back of that bus is not painted tan either. I have also seen some hardtop So-42s with unpainted brackets, can't recall a '58 like yours Doug, but I haven't been looking for that - maybe ask Lind what his '58 has. |
Spotmatic Samba Member
Joined: October 28, 2014 Posts: 63 Location: Dalfsen, The Netherlands, Europe
Posted: Thu Oct 30, 2014 5:28 am Post subject: |
velvetgreen wrote: |
I thought the sticker was a factory sticker - but the first quote appears to be some sort of aphorism about life- no I don't German I cobbled this together
"Who a stranger may not prove to be friendly,
Friedrich Rückert
(1788 - 1866), also known as free mouth Raimar, German poet, poet and translator of Arabic, Hebrew, Indian, and Chinese poetry
It's rather like this (loosely translated):
He who is not friendly enough to show a stranger the way
Probably has never travelled in foreign countries himself. |
bubba Samba Member
Posted: Thu Oct 30, 2014 5:52 am Post subject: |
jjjjack wrote: |
grailoc wrote: |
They didn't note any mix specs on the can, just labeling it "Custom Formula" They matched it to the paint brushed onto the inner cargo door. I haven't had a chance to check it, yet, though. Trying to get the popouts painted today so they'll have plenty of time to dry before reassembly. |
A lot of paint shops will not get out that formula... they want people to come to them and buy the paint.. You have to ask them.. some give it up..
I will check my bus for the poems! _________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
