Manxter #127 -Build
Page: Previous  1, 2, 3 ... 5, 6, 7 ... 11, 12, 13  Next
jrailer
jrailer is offline
PostPosted: Sun Nov 16, 2014 2:13 pm    Post subject: Reply with quote
That helps a lot I have been reading the instructions on the air box over and over and still can't figure it out it tells me that there are scribe marks to cut out and I don't see a friking thing
jrailer
jrailer is offline
PostPosted: Sun Nov 16, 2014 2:19 pm    Post subject: Reply with quote
Those mirrors look good I might need to look into those
sbussard
sbussard is offline
PostPosted: Sun Nov 16, 2014 6:06 pm    Post subject: Reply with quote
I notched my hinges into the air box, but only after drilling one hole, then realizing I should have notched it. I used used some resin to fill the misdrilled hole. I'm fairly certain I had to modify the strut support also, but my buggy is in storage as of yesterday and I can't just walk to the garage to check. I think I had to do it the same as you show. I thought I'd remember all the details of building it, but my memory isn't what is used to be I guess.
Scott
Manxter #122
First time, garage built, and living out the childhood dream of owning a life-size Hotwheel!
Check out my build thread-->My Manxter 2+2
dbsmith
dbsmith is offline
PostPosted: Sun Nov 16, 2014 6:15 pm    Post subject: Manxter #127 Reply with quote
Measure 12 times before you drill. The divots in the body are not exactly where the holes go. Make sure to use your template.
Maybe Brad can send some pictures of a finished Air Box..?
Here is today's progress
dbsmith
SoCal
#127 Manxter - 99.5% done....
dbsmith
dbsmith is offline
PostPosted: Sun Nov 16, 2014 6:17 pm    Post subject: Reply with quote
Brad,
The windshield pivot supports are off from side to side on mine also
dbsmith
SoCal
dbsmith
dbsmith is offline
PostPosted: Sun Nov 16, 2014 6:22 pm    Post subject: Reply with quote
Scott,
Storage? Sorry
It was 70' here today
dbsmith
SoCal
sbussard
sbussard is offline
PostPosted: Sun Nov 16, 2014 6:53 pm    Post subject: Reply with quote
yep, storage. I drove it to the underground mine on Saturday. About 20-30 minutes away. It was 30 degrees. Multiple layers, hat, gloves, and seat heaters and I still froze my butt off. It won't be 70 here again until June! I wish.
Manxter #122
sbussard
sbussard is offline
PostPosted: Sun Nov 16, 2014 7:14 pm    Post subject: Reply with quote
Your pivot brackets look off about the same as mine were. I didn't have to grind anything off the driver's side, but I ground quite a bit more off the passenger side.
Did you get the windshield mounted? Those upper 2 holes for the pivot bolts had me all puckered up. I put that off for days after I had it mocked up.
Does the edge of the dash cover the tub edge completely? The point closest to the passenger compartment has a small gap on both sides of the dash on mine. I never could get it just right. I think I see the same in this picture?
https://www.thesamba.com/vw/gallery/pix/1279495.jpg
Looking good!
Scott
Manxter #122
sbussard
sbussard is offline
PostPosted: Sun Nov 16, 2014 7:22 pm    Post subject: Reply with quote
All tucked away till spring.
Scott
Manxter #122
dbsmith
dbsmith is offline
PostPosted: Tue Dec 02, 2014 9:27 pm    Post subject: Manxter #127 Reply with quote
How come it seems like I spend more time picking up my tools and cleaning the garage than making progress? Confused
dbsmith
SoCal
Iguana
Iguana is offline
PostPosted: Wed Dec 03, 2014 4:43 pm    Post subject: Reply with quote
I will get some air box pictures, anything in particular you are after ?
Looking good.
dbsmith
dbsmith is offline
PostPosted: Wed Dec 03, 2014 7:40 pm    Post subject: Air Box Reply with quote
Brad,
Maybe just some finished pictures, so others have a more clear idea of installation techniques.
Thanks.
dbsmith
SoCal
dbsmith
dbsmith is offline
PostPosted: Thu Dec 18, 2014 6:05 pm    Post subject: Reply with quote
Merry Xmas and Happy Birthday to me......
dbsmith
SoCal
jrailer
jrailer is offline
PostPosted: Thu Dec 18, 2014 8:01 pm    Post subject: Reply with quote
Nice Very Happy Very Happy Very Happy I might get my body on this weekend if it's not to cold
dbsmith
dbsmith is offline
PostPosted: Thu Dec 18, 2014 8:17 pm    Post subject: Reply with quote
I plan on painting painting the side bars, rear horn and misc metal pieces this weekend. Got all the welding completed last weekend.
The inside cage will go to the powder coater after Xmas. I'm thinking of a textured black semigloss or satin.
David
dbsmith
SoCal
dbsmith
dbsmith is offline
PostPosted: Thu Jan 01, 2015 6:42 pm    Post subject: Manxter #127 Reply with quote
I was able to get the side bars, rear horn, bumpers and brackets mounted. The lower brackets on the front bumper needed to be bent to fit correctly.
David
dbsmith
SoCal
jrailer
jrailer is offline
PostPosted: Fri Jan 02, 2015 6:59 pm    Post subject: Reply with quote
Looking great
dbsmith
dbsmith is offline
PostPosted: Tue Jan 06, 2015 8:43 pm    Post subject: Manxter#127 Reply with quote
I got the bracket finished for rear view mirror. Map lights and all. Ready to finally powder coat cage..
David
dbsmith
SoCal
TSFR
TSFR is offline
PostPosted: Thu Jan 15, 2015 8:12 am    Post subject: Re: Manxter #127 Reply with quote
If everything works out today, I'm going to be dipping a toe in this pool.
Thanks,
Jeff
Manxter 2+2 #160
dbsmith
dbsmith is offline
PostPosted: Sat Feb 21, 2015 4:19 pm    Post subject: Manxter #127 Reply with quote
MILESTONE TODAY
After 2 years, 4 months and 2 days, I finally finished the installation of the roll cage and body.
Beer time..
David
dbsmith
SoCal
Page 6 of 13
