sbussard Samba Member
Joined: April 19, 2011 Posts: 432 Location: Pittsburgh, PA (near enough)
Posted: Sun Oct 12, 2014 5:30 am Post subject: |
Ah, I think I figured out what I'm seeing in the pictures. I must have missed the fuel line replacement thread. I wish I knew this trick before I did mine. I replaced the entire old line, reattaching the new to the same points as the old. What a pain.
Your build is moving right along. You'll be driving soon! _________________ Manxter #122
First time, garage built, and living out the childhood dream of owning a life-size Hotwheel!
Check out my build thread-->My Manxter 2+2 |
Posted: Sun Oct 12, 2014 5:48 am Post subject: |
jrailer Samba Member
Posted: Sun Oct 12, 2014 11:26 am Post subject: |
looking good dave don't worry about 154 just think of 127 its coming along great you have done a lot |
dbsmith Samba Member
Posted: Sat Nov 01, 2014 1:16 pm Post subject: Manxter#127 |
Body and lift kit on.......
_________________ dbsmith
SoCal
#127 Manxter - 99.5% done.... |
Posted: Sat Nov 01, 2014 1:42 pm Post subject: |
Looking good I still need to get tires on mine so I can get it home and get going on mine. Why did you put the body washers on the top? |
Double post
Posted: Sat Nov 01, 2014 1:44 pm Post subject: |
Damn phone triple post
And one more |
Iguana Samba Member
Posted: Sat Nov 01, 2014 8:33 pm Post subject: |
Looking good, should be ready for the 1st Manx Club Trip next year
What is the plan for barwork ? Did you cut the side rails to suit the lift kit ? Rear Yoke ? |
Posted: Sun Nov 02, 2014 7:32 am Post subject: Manxter #127 |
Body washers on top... To be different.. Used on the bottom too.. I couldn't find any 3 1/2 " button head bolts, so I used a grade 8 bolts and instead of just a fender washer, I figured the body washer would give it some extra support . Saw it on another buggy and thought why not. .
The rear horn is extended and the side bars just need the welds grinded. I'm going to add some tabs to support the flex conduit for the electrical. The main roll bar needs the bungs welded in for the seat belt supports, mirror bracket and clamp fabricated for steering column.
When I bleed the brakes for the first time, to get all the air out of the system, I made a cap with a fitting and hooked up my air compressor hose with about 5 psi and slowly pushed the air out. Seem to work fairly well. Not too much pressure as I didn't want to blow up the reservoir.
Also fabricated the back of the Manxter emblem on the rear bumper to use as the 3rd brake light and running light. Needs to be blasted and painted. Ordered the LED lights and need to find a red lens.
David
SoCal
Posted: Sun Nov 02, 2014 5:35 pm Post subject: |
Here's how she sits today..
David _________________ dbsmith
SoCal
Posted: Mon Nov 03, 2014 9:32 am Post subject: |
nice that thing is going to be a monster with the bigger tires |
Buggy Brian Samba Member
Joined: October 26, 2006 Posts: 308 Location: Yulee, FL
Posted: Mon Nov 03, 2014 12:08 pm Post subject: |
Bookmarked, since I'll eventually be doing a Manxter Build, and a lot of this stuff applies to my Manx build I'll be doing soon, but I'm cheating. Having a lot of it farmed out. _________________ -(Loretta) Manx # M2940D910E on customized 1970 chassis by Joescoolcustoms
-(Scarlett) Manx Resorter #12 (R0012B931S) on 1969 chassis.
-Original Home built buggy that started all. I learned to drive in it back in 1985.
Manx Club Member # 4436
Check out my Loretta here: http://www.manxclub.com/forum/viewtopic.php?f=65&t=3365Manx
Scarlett is getting a Makeover! http://manxclub.com/forum/viewtopic.php?f=82&t=3745&p=24983#p24983 |
Iguana Samba Member
Posted: Mon Nov 03, 2014 1:26 pm Post subject: |
Sweet, it is starting to look like a buggy now.
Did you grind down your hardtop mount tabs ? If not make sure you grind the corners off before you paint your cage so the windscreen can sit back far enough. |
Posted: Mon Nov 03, 2014 2:26 pm Post subject: |
are you talking about the front edge or just the outer corners? this is good stuff to know |
Iguana Samba Member
Posted: Wed Nov 05, 2014 12:21 am Post subject: |
jrailer wrote: |
Outer corners.
When you sit the screen on you will see where it hits you need to grind it down so it lets the screen go back correctly to the top of the front hoop. Of you don't then it will make life hard to get it correct and seal it onto the roof section as well as align the bonnet. |
nightmanx11 Samba Member
Joined: November 15, 2007 Posts: 549 Location: Downstate Illinois
Posted: Wed Nov 05, 2014 9:38 am Post subject: |
When I built my Manxter, kit #10, I followed Bruce's instructions and everything fit like a glove. The only modifications were when we mounted the side pods, we had to lightly grind on the body edge to get the matching contour for the pods.
Perhaps in the 10 years of using the mold there have been some changes in dimensions due to cleaning & mold repairs.
Joe |
Posted: Mon Nov 10, 2014 6:28 pm Post subject: Manxter #127 |
Ok, I think I'm going to dry fit the dash tub, windshield and top before I paint the roll cage.
I just want to make sure the clearances are correct on the windshield. The sides should be centered on the cage with about 1/4"-1/2" clear at the top bar. The windshield bolts just to the dash tub and NOT to the body.
I'll make sure to grid the top support on the cage to allow the windshield a better fit.
Sound correct? _________________ dbsmith
SoCal
Posted: Mon Nov 10, 2014 7:26 pm Post subject: Manxter #127 |
No it's not going to be a monster buggy. Let's just say it's sporting work boots instead of high heels. _________________ dbsmith
SoCal
Posted: Tue Nov 11, 2014 8:54 am Post subject: |
David,
I would definitely dry fit the windshield before painting the cage. I only had to grind the passenger side tab on the roll bars, the one the bolt goes through to secure the front of the roof, the hinge point. If I didn't grind it away, the windshield surround would not have sat back as far as it should have, would not have wrapped around the top of the roll bar enough. I tried to detail my experience in my build thread, but it's difficult in typing, versus just doing. The hinge point tabs on my roll bar were not symmetrical, and I didn't notice this until after I had the roll bar powder coated and bolted in place, while attempting to fit the windshield.
Your build is coming along great, looks really nice!
Scott _________________ Manxter #122
