71 monster green baja Samba Member
Joined: August 26, 2014 Posts: 1 Location: Tehachapi, CA.
Posted: Thu Aug 28, 2014 11:01 am Post subject: What size tubes are you using? |
Bajatex, I'm looking to build arms for my car and was wondering what size tubes you are running for your arms? |
bajatex Samba Member
Joined: January 27, 2009 Posts: 18 Location: San Marcos, CA
Posted: Thu Aug 28, 2014 11:46 am Post subject: |
JiI wrote: |
I've always wondered when you put the heim joints on the spindles like that, doesn't that severely limit your turning radius? I know if you rotated then 90*, it would limit your travel. Just curious.
Jeff |
With the misalignment spacers and running smaller bolts for the given rod end size, you can achieve up to 35 degrees in each direction. So the upper arm uses a 3/4 rod end and a 1/2 bolt. |
Posted: Thu Aug 28, 2014 11:47 am Post subject: Re: What size tubes are you using? |
71 monster green baja wrote: |
4130 1 1/4 x .120 wall for the lowers and .095 for the uppers. |
metalworxfab Samba Member
Joined: July 30, 2013 Posts: 14 Location: Henderson,NV
Posted: Sat Nov 08, 2014 8:37 pm Post subject: |
What is the shock length you are using? I would definitely be interestedim the CAD file for the plate work, and design the as myself. Is that something you would consider? I have Plasma Cam table |
Posted: Sat Nov 08, 2014 8:38 pm Post subject: |
WaWaZilla Samba Member
Joined: November 02, 2014 Posts: 2 Location: Tri Cities, Wa
Posted: Tue Nov 11, 2014 11:04 am Post subject: |
That is a great design!!! Shock position mostly influences the overall rate (firmness or softness) of the shock, the angle mostly influences the progressiveness of the shock–how the shock changes as it’s compressed. The more the top of a shock is leaned in, the stiffer the shock will feel as it’s compressed. A shock that is positioned fairly vertical, will be linear (i.e. feel the same as it’s compressed).
Any idea what a kit of this caliber would run? |
jg210302 Samba Member
Joined: February 11, 2009 Posts: 17 Location: Huntington Beach CA
Posted: Tue Nov 29, 2016 7:28 am Post subject: Re: Another A arm Baja |
How did this conversion work out? Any updates on a kit? Sorry I know this is an old thread... |
zbug Samba Member
Posted: Sun Dec 04, 2016 12:01 am Post subject: Re: Another A arm Baja |
Ya I was wondering if this guy was still around |
