1975 914 2.0 Master Cylinder replacement, What should I do?
LevisJeanz
LevisJeanz is offline
PostPosted: Mon Dec 16, 2013 12:03 pm    Post subject: 1975 914 2.0 Master Cylinder replacement, What should I do? Reply with quote
I have a 1975 914 2.0 that I converted to carbs. The brake master cylinder dumps about 1-2 tablespoons of fluid when the brake pedal is pressed. I obviously need a new MC. I want to upgrade to the 19 mm MC and there are two options. I could spend $260+ and buy the porche OEM equivalent by ATE or spend $60 - $90 on a cheaper variant from URO. I don't know if I want to skimp out on the braking system because it could save my life and all.
What are your recommendations? Has anyone been using the URO equivalent?
Thanks,
-Levi-
Dlee6204
Dlee6204 is offline
PostPosted: Sun Dec 22, 2013 6:17 am    Post subject: Reply with quote
I've been using the URO MC for quite a few years and many miles with no problems.
germansupplyscott
germansupplyscott is offline
PostPosted: Thu Dec 26, 2013 10:21 pm    Post subject: Reply with quote
Dlee6204 you've gotten lucky. i would not touch URO brand anything on a mission critical part. the quality of URO brand parts is inconsistent. that's a tactful way of saying something else.
SL
lonewolfe
lonewolfe is offline
PostPosted: Fri May 16, 2014 8:17 pm    Post subject: Which brake master cylinder Reply with quote
I would definitely spend the money and either get a stock 17mm or upgraded 19mm ATE master cylinder. The 19mm is considered an upgrade but the funny thing is that they are less expensive than the stock 17mm master cylinders. I would't take a chance on any other brand than ATE. You never want to take a chance with your brakes to try saving a few $$$$.
If you hear these words then get out of the way, "Hey Ya'll, Watch this!!!".
