mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Wed Jan 22, 2014 11:39 am Post subject: |
marklapriore wrote: |
there---no beetle muffler!!! |
thank you _________________ regards
Uli
Capriacci Samba Member
Joined: February 15, 2011 Posts: 298 Location: Brazil
Posted: Thu Jan 30, 2014 10:59 am Post subject: |
Mark,
the inner part of the decklid is the same primer (seems lighter in the pic)? And what about the engine compartment? |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Thu Jan 30, 2014 3:04 pm Post subject: |
To answer the earlier question about the primer, as far as I can tell, the primer is just as glossy and durable as the final paint layer on these VW's. Not the same as primers which are used these days.
The buses I've stripped have in this order: steel, thin black layer which I guess is a first surface dip treatment, first primer paint coat, second primer paint coat, body color, then upper body color for two tone buses.
The delivered in primer buses would have the first three layers. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
marklapriore Samba Member
Posted: Mon Feb 17, 2014 4:41 pm Post subject: |
been busy cleaning up the rear end on this one--- should look beautiful when it's all together, taillights, one reflector, big license light...all original, never cut. Amazing to find one this age with it's original taillight holes--!
unfortunately, this one had a damaged corner that someone stripped bare, beat in with a hammer, and slathered some kind of filler over. They never even sanded-- it looked like a cupcake. So I stripped it back down to metal, hammered it straight, and sprayed, it. Also filled in those ugly trailer hitch slots and second reflector holes--
_________________ I'm always home.....I'm uncool |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6601 Location: Downingtown, PA
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2172 Location: Graz, Austria, Europe
Posted: Fri Feb 21, 2014 6:03 am Post subject: |
Quote: |
hammered it straight |
Yeah, that's the tricky bit.
Three words for "eight hours later"
Niiiice... _________________ Founder and Chairman Emeritus, ECMSAS
Posted: Fri Mar 14, 2014 6:31 am Post subject: |
I know this thread is mainly about paint stripping, but I figured I'd post an update on what has been going on with the bus---more than paint stripping.
The driver's side short wall (left hand cargo doors, remember..) was crumpled pretty hard at the lower cargo door hinge. I first tried to bang it out to see if I could get it to a somewhat decent position, but it was way too far gone. The B-Pillar was cranked inward about 5cm, and the rocker panel area of the short wall was patched with 16 gauge plate and an arc welder- so i figured it was best to just trim off the damaged area, get everything straightened out (nice to have nos doors laying around for fitting!!), weld a new section in and spray it to match.
So I fabricated a piece for the side...thought about cutting out the original door hinge area, fixing it, and using that...but in the end, it was easier to figure out how to make the flanged holes. And i think it is nicer--
so- that piece is fitted up nicely-- but not time to weld it in yet-----first I need to deal with the inner rocker, so i can line up the two rockers... which means dealing with the edge of the cargo floor--which means- yeah, you see where this is going. The rust chase never ends....
I did find a little treat hiding down inside the rocker though!
Hope to get back to the paint stripping soon!!! _________________ I'm always home.....I'm uncool |
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Fri Mar 14, 2014 6:36 am Post subject: |
Don't worry about deviating from paint stripping - it is all fascianting to see - thanks for sharing. Is the semaphore still there that that lable fell off?
Dave |
Posted: Fri Mar 14, 2014 6:47 am Post subject: |
bally wrote: |
Dave |
There were semaphores on the bus, albeit not original or correct. They overhung the semaphore slot by a few centermeters--
I think this originally should have had Ribbed SHO's... _________________ I'm always home.....I'm uncool |
bally Samba Member
Posted: Fri Mar 14, 2014 7:20 am Post subject: |
bally wrote: |
Dave |
I think this originally should have had Ribbed SHO's... |
I'd agree with you on the ribbed semaphores, I don't know enought o know if they would have been SHO or another make.
Dave |
blacksheep214 Samba Member
Posted: Fri Mar 14, 2014 11:35 am Post subject: |
Very inspiring! Thank you |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Mon Mar 17, 2014 6:24 am Post subject: |
It's great to se such attention to detail, good work mark! _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
BENTYL Samba Member
Joined: September 15, 2005 Posts: 62 Location: Sweden
Posted: Mon Feb 09, 2015 5:26 pm Post subject: |
I done some research and here some new info about the G logo;
I think "G" is for "Gustavsson" The old owners of AB Omnibus, Örebro
Check this picture;
_________________ To our Split Junkyard--->
What is "BENTYL"? |
GTV Samba Member
Posted: Mon Feb 09, 2015 5:39 pm Post subject: |
Great detective work. I was wondering how this was doing. Any more progress on the bus? _________________ EMPI Power Rules! |
mightymouse Samba Member
Posted: Thu Feb 12, 2015 3:06 am Post subject: |
Yup....watching and waiting. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
patsey77 Samba Member
Joined: October 06, 2011 Posts: 59 Location: glastonbury ct
Posted: Fri Feb 13, 2015 11:28 am Post subject: |
That Bus is in the garage of the world famous Mark Lapriore. Its in the exact same condition as it was last March! Mark has the green light to get it done maybe he can post some pictures when he gets a chance. I do not know what my final plans are for the Bus. The interior and headliner are in great condition its a very solid and original 51 complete, minus the engine. It very well may reside in our Vw Delivery Center next to the Sudfink 50 and 52 Single Cab or I may offer it up. Thanks for the info on the G |
vwdrue Samba Member
Posted: Wed May 06, 2015 7:24 am Post subject: |
Any updates on this bus?
Thanks |
MrEmpi Samba Member
Joined: May 01, 2015 Posts: 9 Location: Vancouver, BC
Posted: Thu May 28, 2015 5:33 pm Post subject: |
This bus is looking very nice!
What a find as well. Please post some more updates! |
