Barn Find THING, Full Restoration, 27,000 Original Miles.
Page: Previous  1, 2, 3 ... 6, 7, 8 ... 11, 12, 13  Next
panorama
panorama is offline
PostPosted: Fri Feb 20, 2015 12:15 pm    Post subject: white paint... Reply with quote
very nice job and very nice white paint... congrats... what did you use ( paint ) ?
randybriscoe
randybriscoe is offline
PostPosted: Fri Feb 20, 2015 3:26 pm    Post subject: Reply with quote
I'll have to talk to the body shop to find out what brand paint they used. Using Semi-Gloss paint is something most body shops try to talk you out of.
panorama
panorama is offline
PostPosted: Fri Feb 20, 2015 3:33 pm    Post subject: it was just curiosity Reply with quote
don't worry , mine is becoming white too, you can see it on my pics profile, but your white is pretty nice.
congrats and long second life to our things...
randybriscoe
PostPosted: Fri Feb 20, 2015 10:12 pm    Post subject: Reply with quote
In spite of another horrible winter here in Chicago, work continues, albeit slow.
randybriscoe
PostPosted: Fri Feb 20, 2015 10:14 pm    Post subject: Reply with quote
New OE engine mounts.
randybriscoe
PostPosted: Fri Feb 20, 2015 10:16 pm    Post subject: Reply with quote
pre-fitting everything, CLICK TO ENLARGE
oscarsnapkin
oscarsnapkin is offline
PostPosted: Sat Feb 21, 2015 3:52 am    Post subject: Reply with quote
All your amazing/difficult work will be so worth it, as you'll be awarded with a killer Thing. I love your pictures as well.
- 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind."
randybriscoe
PostPosted: Sat Apr 25, 2015 4:34 pm    Post subject: Reply with quote
Time to install the the shift rod, and the bushing it rides in. CLICK for Larger image.
randybriscoe
PostPosted: Sat Apr 25, 2015 4:39 pm    Post subject: Reply with quote
This is how we installed the bushing. This is a spare bushing support bracket, not welded into the tunnel, just to show how it fits.
randybriscoe
PostPosted: Sat Apr 25, 2015 4:42 pm    Post subject: Reply with quote
You have to imagine this happening inside the tunnel. First we positioned the bushing and the steel ring, inside the tunnel, as shown.
randybriscoe
PostPosted: Sat Apr 25, 2015 4:45 pm    Post subject: Reply with quote
Next we inserted the shift rod through the front access panel. You have to get a good look in there, and see the path. I was able to just use my hand/arm to guide it all the way to the bushing.
randybriscoe
PostPosted: Sat Apr 25, 2015 4:51 pm    Post subject: Reply with quote
Just forcing it through.
randybriscoe
PostPosted: Sat Apr 25, 2015 4:53 pm    Post subject: Reply with quote
randybriscoe
PostPosted: Sat Apr 25, 2015 5:00 pm    Post subject: Reply with quote
Fully inserted! Now to access the rod, you have to reach through the shifter hole, and the hand brake hole, to continue to move it toward the transmission. I had to use pliers until I could reach it from the rear access panel. I got caught up in hand brake guide tubes a couple of times, before I got it right.
randybriscoe
PostPosted: Sat Apr 25, 2015 5:03 pm    Post subject: Reply with quote
Here's that goofy rear attachment piece. It came apart easily, and was in good shape, so we just cleaned it up and put it back into service.
randybriscoe
PostPosted: Sat Apr 25, 2015 5:06 pm    Post subject: Reply with quote
Here's the shift rod, back in position and attached to the transmission.
randybriscoe
PostPosted: Sat Apr 25, 2015 5:10 pm    Post subject: Reply with quote
The last piece of this puzzle is the special screw that holds the transmission shift rod, to the coupler/shift rod. This is the original screw, cleaned up. Some people replace it with other fasteners.
randybriscoe
PostPosted: Sat Apr 25, 2015 5:13 pm    Post subject: Reply with quote
Here's the other end, just waiting for the stick shift assemble.
JayC
JayC is offline
PostPosted: Mon Apr 27, 2015 7:00 am    Post subject: Reply with quote
Looks great so far! I'm looking to forward to seeing you put the stick shift back in. Getting the shift lock out plate right and the gears going smoothly seemed to be a challenge for (at least). It took quite a bit of fiddling to get everything lined back up again.
jay
randybriscoe
PostPosted: Mon May 11, 2015 8:11 am    Post subject: Reply with quote
I'll do some detailed shifter pics soon. Found a near mint, original EMPI shifter kit in the car.
Page 7 of 13
