Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Jul 20, 2014 3:35 pm Post subject: |
19super73 wrote: |
I swear I hear you laughing all the way from Oregon.
I will test the TSII that came with it as well, maybe even swap it in just for shits n' giggles. |
It's OK- I'm laughing with you! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
Posted: Thu Dec 04, 2014 3:55 pm Post subject: |
Anyone know the best (read easiest) way to get at the thermo time switch. I replaced the TSII, and the coil as both tested bad, and while it fired up again, it ran and then started missing and running badly, and quit.
FWIW, I scanned and sent Everett the 1974 L-Jet type 4 troubleshooting manual which he posted in the technical section. Wonderful info and it wasn't here before. I have a paper copy of it, and on a CD that another Samba member sent me. The CD mostly had Type 2 info on it, but after searching through it, I found that a copy of the troubleshooting manual had also been placed on it. _________________ 1970 Campmobile [url=https://www.vw-mplate.com/mplate-47260.png]Click to view image[/URL]
1970 Fastback 1600 TL
1971 Doka [url=https://www.vw-mplate.com/mplate-14845.png]Click to view image[/URL]
1973 Super Beetle
1973 Westfalia [url=https://www.vw-mplate.com/mplate-31892.png]Click to view image[/URL]
1974 412 Variant
1975 La Grande Bug
1984 Vanagon |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Thu Dec 04, 2014 4:13 pm Post subject: |
19super73 wrote: |
FWIW, I scanned and sent Everett the 1974 L-Jet type 4 troubleshooting manual which he posted in the technical section. Wonderful info and it wasn't here before. I have a paper copy of it, and on a CD that another Samba member sent me. The CD mostly had Type 2 info on it, but after searching through it, I found that a copy of the troubleshooting manual had also been placed on it. |
A 412 right?..... if the thermotime switch is in the normal spot.....I use a 1/4" ratchet, short 13mm socket and a universal joint to remove the nut.
really the easiest way is to remove the distributor.
The thermotime switch should have no effect on running unless uts leaving the cold start valve on. You can check by just unplugging the plug to the valve. Ray |
Posted: Thu Dec 04, 2014 4:56 pm Post subject: |
raygreenwood wrote: |
19super73 wrote: |
Would a bad one cause stalling? The troubleshooting guide pointed to checking it. _________________ 1970 Campmobile [url=https://www.vw-mplate.com/mplate-47260.png]Click to view image[/URL]
1973 Super Beetle
1974 412 Variant
1975 La Grande Bug
1984 Vanagon |
Posted: Thu Dec 04, 2014 5:51 pm Post subject: |
If you are running and warmed up....and running normally.....that "should" imply that the cold start valve is not injecting....which would mean the thermotime switch is not grounding the connection and everything is normal.
However if its not warmed up...say...stone cold.....the TT switch NOT making ground could cause difficult starting.
Or.....if its NOT cold enough to require the extra fuel from the cold start injector....and the engine fires up normally .....but the TT switch is bad and fires the CS injector....yes....in that, case it can stall. Ray |
Posted: Fri Dec 05, 2014 10:22 am Post subject: |
When I first got the car, the weather was COLD, and it ran well for quite a while. It only started stalling after the weather warmed up (spring and summer), to the point where the time it would stay running, decreased with the higher outside temps. Once they started to fall again, it would stay running longer. When it was the height of summer, it got to the point of not even firing up at all. _________________ 1970 Campmobile [url=https://www.vw-mplate.com/mplate-47260.png]Click to view image[/URL]
1973 Super Beetle
1974 412 Variant
1975 La Grande Bug
1984 Vanagon |
Posted: Fri Dec 05, 2014 10:54 am Post subject: |
Sounds rich. Its common with these to be a hair rich in baseline fuel mixture if you dont tweak the MPS...and in the in-between temps like early spring and late fall....like say...high 40's to 50's.....the intake air temp sensor which was not really the greatest most incremental part.....can cause odd running.
I will have to check my book....but when the car is actually fairly tightly tuned...and it probably was if it came from the Tramster.....the engine liked the intake air temp sensor unplugged seasonally.
Give that a try. Ray |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Jun 12, 2015 11:44 am Post subject: |
Those are aluminum too like the late bumpers themselves? How is your yellow wagon running now anyway? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Jun 13, 2015 9:51 pm Post subject: |
Hey, it ran when I parked it. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat Jun 13, 2015 9:59 pm Post subject: |
But seriously... I'm looking back on all this and remembering that we have really no idea how old the gas was in that thing when you were having the issue. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
