vw7266 Samba Member
Joined: April 28, 2004 Posts: 3038 Location: the point, ohio
Posted: Tue Sep 16, 2014 7:09 am Post subject: |
Less talk more action
Gunldesnapper Samba Member
Posted: Tue Sep 16, 2014 10:37 am Post subject: |
Interesting..........keep us informed! _________________ 1990 Vanagon Carat "Pig"
USN RET |
Vanagon Nut Samba Member
Posted: Tue Sep 16, 2014 11:14 am Post subject: |
Boss! _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Tue Sep 16, 2014 4:04 pm Post subject: |
Bravo. 140/140 is a nice powerplant. _________________ Peace, Regis |
DAV!D Samba Member
Joined: September 10, 2013 Posts: 979 Location: EL CAMINO
Posted: Tue Sep 16, 2014 4:37 pm Post subject: |
vw7266 wrote: |
Yea mine would be done already but I took a long road trip instead, it was just too hot in FL so I had to go lol.
I have all the parts to do the swap once I head back to FL this winter, so mine is still a go. I will say I met a guy in Austin that is a member here but never publicly posted his swap. He installed a 2.2 ecotec in his westy and he's getting 28mpg. It was a very quality install as well.
It was just random luck I ran into another guy that had already done it. Nice to find someone else that had it done and also nice to see another working on it. Is yours a 2wd by chance? I think being mine is a Syncro, I think it will fit under the deck lid.
I think it's one of the best engine choices out there in regards to inlines. Way better engine than the Fords they use in the Bostigs.
Mine in a 2.5 from a Saturn Sky so it's a bit more HP and torque vs the 2.2, so should be interesting. It is almost 200/200 torque/hp
This is how mine sat before I wrapped it up to head west.. it's the VVT and has drive by wire so no more throttle cable. Also has a complete billet bottom end so it can be supercharged or turboed if I really wanted to.
_________________ 86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion |
vw7266 Samba Member
Posted: Tue Sep 16, 2014 6:04 pm Post subject: |
ill post more pics when i get it home was cheaper/easier to pay my local shop to build the mounts for me since they manufacture the mounts and flywheels in house. Its in a 2wd a syncro would clear i think i was originally doin this for my syncro but sold it and had this 86 without a motor |
DAV!D Samba Member
Posted: Tue Sep 16, 2014 6:59 pm Post subject: |
vw7266 wrote: |
Yea I was gung ho working on mine but when I ordered the adapter plate it took, it 4 weeks to show up. While waiting I ended up finding a Westy that needed a motor..
Long story short the Syncro's 2.1 ended up in the Westy and one thing led to another a month later I was leaving for a long road trip with my ecotec conversion on the back burner till this winter.
As far as motor mounts. My 2.4 came out of a RWD car, so I'm using the stock Sky mounts with welded on adaptors on the stock VW mustache bar.
Out of curiosity what did you do on your wiring harness? I hand traced 90% of the harness with a few pin layout diagrams I found. My next step was to figure out what I had to keep..
I may however just bite the bullet and buy a harness from one of the stand alone guys being I have to have the computer reprogrammed anyway. They just cost a lot more than I'd like to spend.. _________________ 86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion |
vw7266 Samba Member
Posted: Tue Sep 16, 2014 7:23 pm Post subject: |
Same shop doin my mounts redoes the harndess I think its costing me like 250 for the harness |
mekanism Samba Member
Joined: June 19, 2013 Posts: 94 Location: San Diego, Ca
Posted: Fri Sep 19, 2014 11:45 am Post subject: |
What's the reason for the ECU reprogram for this swap? Is it like the Zetec where the chipped key needs removal? |
vw7266 Samba Member
Posted: Wed Sep 24, 2014 8:20 am Post subject: |
Just to give you an idea of how much it sticks up
Posted: Wed Sep 24, 2014 8:25 am Post subject: |
vw7266 wrote: |
Is this with the Ecotec's crankshaft in the same position height wise in the chassis as the WBX? _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
insyncro Banned
Posted: Wed Sep 24, 2014 8:35 am Post subject: |
As shown above the engine will need to come up higher....as Christopher made reference too. |
Posted: Wed Sep 24, 2014 9:29 am Post subject: |
That's damn close! Looks like you might be able to get away with fabbing up a curved piece of sheet metal to cover it so you dont have to raise the whole lid. Nice work!
So is it possible to run the stock ecu on this setup? I'm curious to see if this is a viable swap for us Cali dwellers. |
geodude Samba Member
Posted: Wed Sep 24, 2014 11:15 am Post subject: |
I seriously looked into the Ecotec engines for a swap, but dropped the idea because I'm in CA and the evap system uses a vacuum system to detect leaks. The reason this is important is the system monitors the pressure in the fuel tank and the evap control system to look for leaks. The vacuum systems are calibrated to the size of the fuel tank and monitor the fuel level to calculate the expected pressure and a code is thrown if the pressure doesn't meet the expected range. You put this system on a vehicle with a different fuel tank and it throws a code for evap leak. You throw a code and you don't get through the referee. The reason the 1.8T can be legally installed is that most European manufactures use a pressure test. A small airpump builds up pressure in the system and the computer looks for a decrease in pressure over time. This is insensitive to fuel tank size and shape, so you can put it in the van and it won't throw codes if the system is tight. So my understanding is for CA you need an engine from a European, Chrysler, or some of the Asian manufactures (Mazda?). Ford, GM, and most Asian brands use the vacuum system. _________________ 1988 GL Camper
1991 Multivan — the basket case |
Posted: Wed Sep 24, 2014 11:25 am Post subject: |
Oh that sucks! Thanks for the info. I was really hoping to figure out a way to get an I4 besides the 1.8T into a cali van legally. California is basically forcing us to use other loopholes.
I'm still researching whether or not all of the vehicles that come with an Ecotec use the passkey system, and how to bypass it. This would be a very inexpensive swap if you can just use the oem ecu, wiring, and if using an engine from a RWD vehicle weld the mounts to a vw mustache bar. |
DAV!D Samba Member
Posted: Wed Sep 24, 2014 8:53 pm Post subject: |
mekanism wrote: |
The engine is the same, regardless if it was from a front wheel drive or rear. The block has the engine mount holes for either. The only difference is which mounts were used and the exhaust manifold.
As for the ECU, it's the anti-theft key deal that has to be removed. You can mod a stock harness, but it's sort of a figure it out yourself due to this engine coming from so many different cars with different harnesses.
You can however buy ready to go ECU/ stand alone harnesses in the $800-$900 range.
This is the engine height of the guy I met that had already installed a 2.2 in his Westy. He claimed to get 28mpg out of his.
Posted: Wed Sep 24, 2014 9:00 pm Post subject: |
DAV!D wrote: |
mekanism wrote: |
You can however buy ready to go ECU/ stand alone harnesses in the $800-$900 range. |
Yeah I realize the blocks are the same for all vehicles but since your engine is from a RWD it makes fabbing the mounts and exhaust a bit easier right?
Also, forgive me for all of the bench racing, just really curious about this swap. |
DAV!D Samba Member
Posted: Wed Sep 24, 2014 9:04 pm Post subject: |
mekanism wrote: |
DAV!D wrote: |
mekanism wrote: |
Not really tbh as the mounts are not identical on either side, so you still have to custom build them. One thing that is nice though is the drive by wire throttle. It means no broken throttle cables or tricky set ups. _________________ 86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion |
Posted: Wed Sep 24, 2014 9:11 pm Post subject: |
DAV!D wrote: |
mekanism wrote: |
Oh man, that is really tall! No way to get it lower? I guess the Ecotec has a much thicker head than the Zetec? |
vw7266 Samba Member
Posted: Wed Sep 24, 2014 9:25 pm Post subject: |
id lke to see how he has his coolant routed to his over flow tank... |
