type1guy Samba Member
Joined: October 14, 2012 Posts: 299 Location: Oakwood, IL
Posted: Thu Jan 02, 2014 7:18 pm Post subject: Reversed beam? |
I saw a rat rod beetle for sale on eBay today that had a reversed beam. How safe can that be? Anyone done this before?
http://www.ebay.com/itm/Volkswagen-Beetle-Classic-...ars_Trucks
Mike _________________ 1972 SB Marina Blue, "Mr. Beetle" (sold)
1972 Standard Baja, "Jack the Dripper" |
1965VWBUGGER Samba Member
Joined: March 10, 2013 Posts: 212 Location: Sedro Woolley, Washington
Posted: Thu Jan 02, 2014 7:29 pm Post subject: |
YIKES!!!!
Looks like a Death Trap to me... _________________ 1965 VW Beetle Project "SIX5BUG" now Zaney"s Rally Racer
2011 VW Golf TDI DSG Malone Stg 1.5 (Traded)
2013 VW Tiguan 4 Mo 2.0 TFSI. APR Stg 1.5. Aka Iggy |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Thu Jan 02, 2014 8:34 pm Post subject: |
when you bend it you can put it back in backwards and hit another curb till its "straight"...I cant imagine what the caster must be |
jhoefer Samba Member
Posted: Thu Jan 02, 2014 8:37 pm Post subject: |
Two problems with that. The trailing arms facing forward can cause poor geometry for ride comfort. Impacts will tend to direct their force directly into the arms and chassis instead of making them rotate. Makes for a harsh ride.
Worse, having the spindles mounted backwards has probably inverted the mechanical trail of the wheels. Mechanical trail is the distance that the center of the tire's contact patch is behind where the rotation (steering) axis of the spindle intersects the ground. It's what makes your wheels want to naturally return to center when moving forward. Think of how a shopping cart's wheels rotate to face the right direction regardless of where they start, same principle. If it's been inverted, the wheels are going to want naturalky go full left or right lock when moving forward, so horribly dangerous. Now it could be possible to keep some proper mechanical trail even with the spindles flipped, but it's impossible to determine from the pictures. I wouldn't touch it without thorough proof that this was correct. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Fri Jan 03, 2014 7:03 am Post subject: |
jhoefer wrote: |
You're talking about caster (caster wheels are on the front of a shopping cart). Yes, the whole front end geometry is screw with the beam in backwards. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Fri Jan 03, 2014 1:50 pm Post subject: |
Joey wrote: |
jhoefer wrote: |
You're talking about caster (caster wheels are on the front of a shopping cart). Yes, the whole front end geometry is screw with the beam in backwards. |
Caster is the angle that the steering axis leans in the fore/aft direction of the car from vertical. Mechanical trail is the distance from where the steering axis intersects the ground to the center of the tire's contact patch. A shopping cart's front wheels have 0 degrees caster but still have mechanical trail. |
Lidpainter Samba Anti-Hero
Joined: January 21, 2004 Posts: 2045 Location: 41.77 | -83.56
Posted: Fri Jan 03, 2014 1:58 pm Post subject: |
jhoefer wrote: |
Joey wrote: |
jhoefer wrote: |
True but unlike this car, I would not be embarrassed if I was seen in public with a shopping cart. _________________
EverettB wrote: |
Thanks, time to bulk up on meat! |
demon1018 Samba Member
Joined: September 12, 2009 Posts: 930 Location: crystal river, fl
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Jan 03, 2014 7:41 pm Post subject: |
While a reversed beam (flipped beam)is not the most common way to extend the front wheels it does work.
Many Volksrod builders go that route. Samba member rgdedge's Volksrod comes to mind..
Ill see if he will add his input as he drives the crap out of his....like most of us Volksrod builders do. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
rgdedge Samba Member
Joined: October 17, 2006 Posts: 862 Location: Seymour, TN
Posted: Fri Jan 03, 2014 8:17 pm Post subject: |
Yes it will work but more to it than just reversing the beam. I have put 30.000 miles on mine. Drives just like a stock bug other than the turn radius. Drive it to all the shows/races, 12 hours to Daytona running the Interstate at 70 mph+ there and back. Been on the Tail of the Dragon(US 129) and won photo of the week. Some people say it's not supposed to be like that while their bug is lowered with crazy camber and a 6-8 inch narrowed beam.
Tim _________________ ()o\|/o() |
Posted: Fri Jan 03, 2014 8:44 pm Post subject: |
^ Yeah!.... _________________ aka Ken {o\!/o}
Usually and often edited |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Jan 03, 2014 11:39 pm Post subject: |
Looks to me like there is enough caster shimming going on with that beam that it probably drives smoother than stock. Looks like a job for a 16 inch steering wheel or a driver with Popeye arms though. _________________
EverettB wrote: |
FU#5 |
casper deuce Samba Member
Joined: August 09, 2013 Posts: 10 Location: Fresno, Ca.
Posted: Sat Mar 29, 2014 4:27 pm Post subject: |
As a newbie to the Volkswagen world, I am quite familier with vintage hot rods. People have been doing this trick for almost 70 years without any problems at all. Look at the front axle with reversed spindles on 90% of the T buckets on the road. I'm sure it's not "proper" but it sure works fine. |
TC/TeamEvil Samba Member
Posted: Thu Apr 10, 2014 2:21 pm Post subject: |
The MGA and MGB both have forward facing spindle arms and rack and pinion. Steering rack might be a good solution on the VW. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Fri Apr 11, 2014 5:23 pm Post subject: |
If he had swapped the right and left spindle so the axle was still behind the spindle steering axis and tilted the beam back far enough so the wheels had enough caster/trail, it should have worked OK. If he did the right left swap, he would have had to cut off and relocate the steering arms to work.
Leading arm suspensions work fine, even off road if they're properly designed, not just trailing arms turned backwards. This is called an Earls Fork, BMW and others used them for years.
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Fri Apr 11, 2014 7:05 pm Post subject: |
jhoefer wrote: |
Joey wrote: |
jhoefer wrote: |
I believe it's called the akerman angle but im not positive? _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
punkabillyvw Samba Member
Joined: November 12, 2013 Posts: 86 Location: Waco Tx
Posted: Fri Apr 11, 2014 7:10 pm Post subject: |
That would be called SAI just got done covering that in my steering and suspension class this week |
Posted: Sat Apr 12, 2014 6:57 am Post subject: |
Caster is the steering axis inclination (SAI) in the longitudinal plane. There is also steering axis inclination in the lateral plane which affects the scrub radius. |
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Sat Apr 12, 2014 3:22 pm Post subject: |
With proper alignment, it works. Simply bolting the entire beam and steering in backwards, not so much. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
sandfreaks Samba Member
Joined: December 15, 2008 Posts: 86 Location: OLYMPIA
Posted: Mon Apr 28, 2014 11:41 am Post subject: |
Following Tims example I have been building a Flipped "Trailing arm" beam. So far other than some minor clearance issues it is working great. Tim took it a step further and relocated his steering to be back behind the beam again.
He didnt just flip the beam. Pretty slick setup. The problem with just flipping the beam is the Ackerman angle is all screwed up creating bad bump steer. _________________ 68 BAJA
67 STANDARD
"Its a VW thing you wouldn't understand" |
