notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Sun Jul 07, 2013 2:49 pm Post subject: |
If you want your bus to retain any kind of value - like as close to a stock presentation as possible then don NOT use Rhino coat or any kind of rubberized coat for the fiberglass top. Im pretty sure it would look decent but at the end of the day it will look like bed coat on your top Im sure it would ad some unwanted weight as well depending on how thick it was put on.
Fiberglass is easy to fix. Bondo makes a kit that would do that corner in a snap. If you dont want to do it then find a body guy to knock it out. You can go as far as to find a boat place that will re-glass it all for you. Gell Coat. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
MonkeySee Samba Member
Posted: Tue Apr 15, 2014 8:50 am Post subject: |
All good advice. . |
highlandmurf Samba Member
Joined: April 08, 2010 Posts: 296 Location: Hudson Valley, NY
Posted: Thu Aug 21, 2014 8:50 pm Post subject: 1974-79 Westfalia Pop top Hardware list |
Thanks to this site, and this thread, I did a nice job on my pop top refresh, if I do say so myself. Pics to come.
In the meantime, I just wanted to throw up some useful info:
*Oh, and the lock/star washers for the luggage rack bolts are also not on the list
I found Fastenal to be a good place to get fasteners in small quantities.
Anyone got a spec on sheet metal screws for the luggage rack? _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
Manfreds78bay Samba Member
Posted: Fri Aug 22, 2014 12:15 pm Post subject: |
Yes, this thread was a great resource. You have a lot of choices. You can spend a ton of time painting and sanding and you will get great results. Or you can do what I did, and do some sanding paint and be done and get pretty good results. My bus will never by a show winner, so I more or less just want to preserve it and not restore it. Used a power sander and bought the highest quality outdoor white paint I could find from Home Depot and just rolled it on.
Before:
After:
Before:
After:
_________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
TXBONE Samba Member
Posted: Sat Aug 30, 2014 9:06 pm Post subject: |
Good info here. _________________ Full of energy. Always need to be surfing, riding motocross or riding BMX etc...... I shape and surf retro finless wood surfboards called Alaia's. If your interested and want one made for your bus or wall, let me know.
"Goldy" OG 69' CAMPMOBILE |
Posted: Sun Aug 31, 2014 7:22 am Post subject: |
What about replacing the wood? Getting the proper curvature and all.
Or did I miss that somewhere? |
Posted: Sun Aug 31, 2014 9:00 am Post subject: |
Hey all, just a couple of pics of my pop top refresh.
I went with Interlux Bright sides boat paint, because I wanted to get a good primer coat on the top. I had previously power washed it, revealing a lot of rough fibers.
Three coats, took about a quart and a half of paint, and a quart of primer.
I regret using a nappy roller for the primer, it went on too heavy and required a lot (10-12 hours) of sanding. The finished surface was really nice though. filled in all fibers.
I am very happy with the finished product.
Here is the before and after. (roof rack is still primed in this shot)
Between the paint, primer and fiberlass repair, I think I was into it for about $130
Here are a few pics of a crack i repaired using a west system 101 repair kit and some fiberglass cloth.
(I would source these online, The cloth is also available at autobody shops for a lot less than a marina would get)
Westy Sticker location for the perfectionists
Thanks again for all the great advice. _________________ 1976 Westy Marigold Yellow
2.0 stock FI
My M-Plate |
Dub Owner Samba Member
Posted: Wed Oct 22, 2014 2:34 am Post subject: |
MonkeySee wrote: |
i could use this info right about now. please share your expirence _________________ 66 bug future lifted full body
67 bug collecting one year only parts
69 westy RUSTY is now my DD
71 411 one owner all original flood victim
74 412 slowly putting back together
78 Champagne II sunroof
85 Vanagon previous DD |
tomkiwi Samba Member
Posted: Sat Oct 25, 2014 3:44 pm Post subject: |
peaceful warrior wrote: |
Here is a good canvas installation article from VW Trends. I have it in a Higher res. version if anyone needs it emailed.
BTW, in my experience, using a pneumatic stapler makes the job so much easier, but then if you don't start the canvas correctly, they are a biotch to pull out....
Here's a link to the article on the VW Trends website if anyone's looking for it.
http://www.vwtrendsweb.com/tech/0404vwt_westfalia_canvas_camper_replacement/ |
Posted: Fri Oct 31, 2014 7:04 am Post subject: |
thanks _________________ 66 bug future lifted full body
HerrFink Samba Member
Joined: November 14, 2013 Posts: 24 Location: United States
Posted: Tue Dec 09, 2014 5:49 pm Post subject: Walnut shell for stripping fiberglass prep for restoration |
I'm about to get my bus bead blasted and the shop suggested walnut shell blasting the fiberglass top and then i'll put new epoxy prime and then gelcoat on anyone try this and have good results or else know if it is overkill or otherwise? _________________ -1971 Bay Window Westfalia PopTop Purchased and first registered & Sold in CA in 1970. |
Our79Westy Samba Member
Joined: August 08, 2012 Posts: 97 Location: Bronson, FL
Posted: Wed Apr 01, 2015 1:09 pm Post subject: here's what I did |
This is a very useful thread, thank you everyone. I referenced it before and during my 1979 campmobile poptop restoration/refresh. Not only did I paint my poptop white (and glow in the dark rustoleum), I installed a solid headliner over the flaking flocking. You can check it out on my thread here.
http://www.thesamba.com/vw/forum/viewtopic.php?t=620475
What did you use to seal the mounting hardware bolts penetrating the fiberglass poptop and body?
And of course, Good luck on yours! _________________ 1979 Westfalia DELUXE 2.0 FI manual
Mexican beigeutiful and mostly original.
See the most up to date status of Constance on YouTube
https://m.youtube.com/channel/UCvO1ZedS22IepvvRYaTxiPQ
My 1979 Westfalia Campmobile's sundry Tales of Constance
http://www.thesamba.com/vw/forum/viewtopic.php?t=620965
1990 Vanagon, Red, Driven 70,000 miles till sold. |
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Thu Apr 02, 2015 8:14 am Post subject: |
I used rubber washers on most bolts to keep water out, worked well during heavy rains last year.
Unrelated, but I'm trying to install my new canvas from bus depot (the BD brand) and am finding the rear is INCREDIBLY tight trying to screw the bottom retainer strip. I have to use all of my power to stretch it far enough and am worried it'll rip.
Any advice? The top took a couple tries but looks well aligned (went to all corners with only slight pressure). _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Posted: Thu Apr 02, 2015 5:46 pm Post subject: polishing poptop hardware, whatidid. |
Try a search using tight canvas, from what I've read it could be anything from the wrong one to a bad batch. Good luck in the fitment and someone should hopefully have a trick fix to your conundrum.
hey BusterBrown,
BusterBrown wrote: |
Seeing as how I received so much in the way of information from this thread (before doing my own canvas replacement), I figured now that I'm done, I can at least try and give something back. So here goes...
I also removed the top's latching hardware, and the long square steel reinforcing bar, in order to have room to work up there. Removal of this hardware also provided the opportunity to clean them up and re-paint them, as well as clean behind them. 32 years of dirt and debris accumulation can add up
The moment of truth. All in, and all done. How's it going to look? Nothing left to do but push that top up...
These pieces of the top's hardware were wire brushed, and repainted with an aluminum-silver spray paint:
This is what the metal surfaces looked like before repainting:
Any other approaches you guys/gals have taken to cleaning/refinishing this interior hardware?
Well, now that that's done, I can reinstall the upper plywood platforms, the upper cushions, and the cabinets.
I say it's ready to go camping. Don't you think? |
Awesome info, pictorial and of course campmobile. Incredible thanks for sharing and yeah, beautifully camp ready!
Would it be to much of an imposition to ask advice for 2 things please?
1. How is your painted hardware holding up?
I watched my inlaws shine the aluminum on their 18 wheeler and trailer and was able to obtain almost mirror like surfaces when I wet sanded mine with 800 followed by 1000 grit, followed by cleaner wax, followed by marine polish as shown in the pictures below. And
2. what did you use to seal the various body and fiberglass penetrating bolts?
New rubber gaskets for the luggage rack not squished too much? (Bentley section 1, page 41, fig. 7-46 and also recommends replacing the lock nuts and lock washers page 39, Fig. 7-39.) Or reused the OG, stuff?
Thanks again for your excellent documentation and advice.
here are some pictures of the process...which is also a great resistance workout!
Works on the jalousy, windows too.
Let your inner shine out _________________ 1979 Westfalia DELUXE 2.0 FI manual
Posted: Fri Apr 03, 2015 9:40 pm Post subject: Re: polishing poptop hardware, whatidid. |
Our79Westy wrote: |
Did a search with those key words and found that it is meant to fit ultra tight, so I took another try today since it was warmer out and was able to muscle things into place.
My tip for others doing their canvas, wait for heat! The plastic on the bottom becomes very rigid, and the tack strip shatters when you try and staple it below 10C. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Fri Apr 03, 2015 10:00 pm Post subject: Re: polishing poptop hardware, whatidid. |
If you're going for factory correct, all of the aluminum pieces on our westy's are galvanized and should have that dull galvanized finish and shouldn't shine like chrome.
I've used some aluminum and galvanized paints that get the color and sheen damn close and they last but, you don't get the proper pattern that hot dip galvanization creates so, it's not "correct". _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Sat Apr 04, 2015 5:43 am Post subject: careful what you shine |
Keith,
Thanks for the knowledge, I was wondering why all the aluminum looked so dull and agree that those concerned with factory correctness should consider this during their refresh.
Could you please quantify your statement "and they last". Have you had to or What is your repaint/refresh rate? 5 years, 10 years? Got pictures?
After spending so much time refreshing my poptop fiberglass I was not satisfied with that dull, galvanized look of the mounting hardware. Aluminum has great corrosion resistance and should be alright by itself being washed and waxed periodically with the rest of the bus.
I include a link immediately below on the corrosion properties of aluminum and appropriate choice of fasteners to minimize galvanic corrosion, pitting and failure.
http://www.aluminiumdesign.net/design-support/aluminium-corrosion-resistance/
Without starting a new thread on why they did what they did...hmmm.... I figure the factory galvanized the aluminum to extend the life of these components in the "wettest" most corrosive environments. But again, for my purposes the Shiney waxed natural aluminum oxidation layer is much more visually appealing and possibly easier to restore than repainting as I intend and hope to enjoy the fruits of my labors for decades to come and will let you know how it stands ttot, (the test of time).
Soo, after you painted your hardware, what did you use to seal your poptop bolt hole and bus body penetrations when you put it all back together?
And did you reuse your OG (Original German) nuts and bolts?
Keith and everyone, thanks again for your advice, comments and constructive criticisms. _________________ 1979 Westfalia DELUXE 2.0 FI manual
Rumdum Samba Member
Posted: Sat Apr 04, 2015 7:32 am Post subject: |
Referencing the bottom right portion of the pic, I'm wondering if everyone's top fits that snug on the back and back corners? Mine is the same. Seems it would pinch the seal too much as its only that snug in the corners and back. I was thinking my top was a defect over time and was considering adjusting so there's a little gap there like the rest of the top. But after seeing this pic, I'm second guessing myself. Maybe it's suppose to be like that? Also I would like to note that my PO used rivets on the back to hold seal in place which contributed to me thinking it was a defect. Thoughts? Adjust or leave as is? _________________ 1975 Westfalia Campmobile
CB Performance Dual IDF Weber 40
- jetted and optimized by Aircooled.net |
Posted: Fri May 08, 2015 8:40 pm Post subject: |
I shimmed my hinges up a half inch in the back with plywood.
You have to account for the wood thickness when installing the canvas.
But, honestly I do not think that it made much of a difference at the rear corner.
In fact, the repair pic above may be with the shim in place.
http://www.thesamba.com/vw/forum/viewtopic.php?t=552568&highlight=
2.0 stock FI
My M-Plate |
