Bleyseng Samba Member
Posted: Fri Jan 24, 2014 3:34 am Post subject: |
makin' boost wrote: |
GeorgeO. wrote: |
My question is how is the steering assembled? |
It is a rack and pinion steering box, that, I was told, bolts right up to the existing shaft.
I have also heard that the Bay bus's have a plastic "bearing" top and bottom on/in the steering shaft that can become worn over time.
Anyone with experience on this ?? |
It's not plastic is a metal bushing that wears out due to lack of grease. This is why most Buses have sloppy steering.
I think the Red 9 front end is awesome and a vast improvement over the stock setup. I wish I had the $$ for it but a stock setup in spec along with good shocks and a heavier front sway really are pretty good. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Fri Jan 24, 2014 5:21 am Post subject: |
Bleyseng wrote: |
GeorgeO. wrote: |
I think the Red 9 front end is awesome and a vast improvement over the stock setup. I wish I had the $$ for it but a stock setup in spec along with good shocks and a heavier front sway really are pretty good. |
I concur. If you must have a 'Race Taxi' Bus, then perhaps the double-wishbone setup makes sense if you're going to use it in that context. I would be content with keeping the Bus between the lines on the Interstate, but that's more my use case: Go a long, long way and not fuss and spend money like water. If Red9 products were available in the USA (even on a 100% upfront commissioning basis) I'd consider it for the 'set and forget' factor. But they aren't so I'm going to conserve my capital for the many other things I must cope with keeping a 40 yo mule on the road, with dwindling parts supply or parts available that are made out of pressed cheese in slave labor states.
M _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .81 4th
Click to view image |
makin' boost Samba Member
Joined: July 15, 2013 Posts: 17 Location: Pac Northwest
Posted: Mon Feb 03, 2014 6:56 pm Post subject: |
Back to the top ...................
No one on the West Coast with one of these ??
Some local feed back sure would help. |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Thu Feb 06, 2014 8:42 pm Post subject: |
There is one of these on the west coast, and it is on ebay. I asked the seller and he says it is complete. Someone should grab it, before I do.
http://www.ebay.com/itm/Red-9-Design-VW-Volkeswago...7675.l2557 _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
nynone4 Samba Member
Joined: August 09, 2004 Posts: 299 Location: Central Illinois
Posted: Fri Aug 16, 2019 7:09 am Post subject: Re: Red 9 Design front wishbone suspension |
Resurrecting a thread from the past...
Anyone else that's been running one of the RED9 double wishbone kits longterm care to comment on their experience? I'm looking seriously at putting one of these on my '70 crew cab... but am curious about others' longterm experience with the quality and rack and pinion setup. Still love it? Would you go back to stock?
I need to contact Red9 also to see if my existing Wagenswest babystang disc brakes will mount onto the spindles they use. _________________ >>Looking for any and all Vic Williams, Peoria Illinois dealership items.<< |
