saburu transaxle into aircooled type 1?
Forum Index -> Performance / Engines / Transmissions Share: Facebook Twitter
Dr OnHolliday
Dr OnHolliday is offline
PostPosted: Sat Jan 25, 2014 5:58 pm    Post subject: saburu transaxle into aircooled type 1? Reply with quote
Ok, I havent thought this thru at all, but can a 5-spd suburu transaxle be adapted into a type 1 and hooked up to an aircooled vw?
Pros and cons? Worth the costs?
1965 Type 1 sunroof Baja / over 50k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust
Dale M.
Dale M. is offline
PostPosted: Sat Jan 25, 2014 6:54 pm    Post subject: Reply with quote
Transaxle is behind engine, and its forward mounted (engine) ... Yes there is a gear set (ring and pinion) available from gentlemen in Australia that converts front drive Subie 5 speed to rear engine setup....
And yes its longer than a VW transaxle and will probably interfere with standard torsion bar housing of Type 1...
This is transaxle you would be dealing with....
http://www.thesamba.com/vw/forum/viewtopic.php?t=582986
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
mcmscott wrote:
...... and not keyboard jockeys that just have high post counts
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sat Jan 25, 2014 7:14 pm    Post subject: Reply with quote
Yes it can be done. And no it will not interfere with torsion housing.
Todd of www.subarugears.com website shows the different Subaru transaxle to use.
Todd has a ad on the Samba of what trans and parts he is sells.
He is working on a adapter plate to use a VW engine with the Subaru trans.
I was involved with the building of a Meyers Manx Kick Out SS dune buggy for the Manx Club raffle this July.
We installed one of Todd's Subaru transaxles with his reversed ring & pinion with a 2.5 liter Subaru engine.
I can tell you the trans worked well when I drove it. It was great having the 5speed to use to match the engine torque curve.
The drive flanges he sell for the Subaru conversion uses 100mm CV (type II, IV, Porsche 924).
It does require the use of 15 5/8 CV axles which are a little shorter that stock Bug ones.
Joseph
Fair Oaks/Orangevale, CA
Elrod Racing
Motion Tire Motorsports
Into Volkswagens since 1960
gprudenciop
gprudenciop is offline
PostPosted: Sat Jan 25, 2014 7:22 pm    Post subject: Reply with quote
Problem with the subaru trans is it will slow the revs down to much and probably fry the motor in 5th!(useing aircooled)
Good things come to those that wait! Gooder things come to those that get off their ass and make it happen......
"The Bitterness of Poor Quality Remains Long after the Sweetness of Low Price is Forgotten"
jsturtlebuggy
PostPosted: Sat Jan 25, 2014 7:34 pm    Post subject: Reply with quote
Subaru Gears has 3 different ring & pinion ratios available,
3.90, 4.10, and 4.86
Plus there are different gear sets available for 1st through 5th.
More than enough combinations to come up with something that will work for you.
Plus the rear tire diameter also will determine what RPMs you will be turning at cruising speeds.
Joseph
Elrod Racing
Bones 53
Bones 53 is offline
PostPosted: Sun Jan 26, 2014 8:56 am    Post subject: Reply with quote
What about these? From the picture and description looks like a bolt in
http://www.thesamba.com/vw/classifieds/detail.php?id=1587281
75smith
75smith is offline
PostPosted: Sun Jan 26, 2014 9:14 am    Post subject: Reply with quote
bolt in almost, he hasn't made the adapter for ACVW yet, so your stuck with a subie engine.....
My 1975 Beetle Build Updated 8-21-12
My engine build
mark tucker
mark tucker is offline
PostPosted: Sun Jan 26, 2014 11:19 am    Post subject: Reply with quote
so just ideling with my motor will fry it? or driving around town slowely with vw trans will fry it? lower rpm/less power/less fuell=less heat, but your cooling system needs to be up to the task of cooling the motor nomatter what rpm your running....and the motor also needs to be up to the task asked of it.
Reply to topic    Forum Index -> Performance / Engines / Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
