Steering rag joint donut torque specs.
Forum Index -> Kit Car/Fiberglass Buggy Share: Facebook Twitter
herkster
herkster is offline
PostPosted: Sun Jan 26, 2014 10:13 am    Post subject: Steering rag joint donut torque specs. Reply with quote
Hi All,
What is the proper torque for the steering rag joint / donut on both the steering shaft input (from the steering box) and output to the steering shaft (to the driver) as well as the donut itself?
While we are at it what is the proper torque for the pedal assembly to the tunnel and Master cylinder to the chassis?
Can I find these somewhere? I did a search but didn't seem to hit it.
Thanks,
Herk
didget69
didget69 is offline
PostPosted: Sun Jan 26, 2014 5:20 pm    Post subject: Reply with quote
Short of finding an exact spec in a VW manual, you could look into recommended bolt torque specs based on bolt size & tensile rating... for example:
http://www.dansmc.com/torque_chart.htm
http://www.cncexpo.com/MetricBoltTorque.aspx
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jan 26, 2014 5:24 pm    Post subject: Reply with quote
14ft.-lbs.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $25,000 raised in 2016, hoping for the same in 2017
herkster
herkster is offline
PostPosted: Sun Jan 26, 2014 8:45 pm    Post subject: Reply with quote
thanks!
manxdavid
Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
manxdavid is offline
PostPosted: Mon Jan 27, 2014 6:33 am    Post subject: Reply with quote
TBH I've never ever used a torque wrench when working on VWs. There are only 4 basic torques: just nipped, just tight enough, quite tight and really bl**dy tight... Laughing
herkster
herkster is offline
PostPosted: Mon Jan 27, 2014 7:20 am    Post subject: Reply with quote
David,
I agree but coming form working on aircraft i just want it right too. I don't want any unknown issues popping up after completing the build. It seemingly complicated enough with all the changes we have accomplished.
Vanapplebomb
Vanapplebomb is offline
PostPosted: Mon Jan 27, 2014 9:31 am    Post subject: Reply with quote
When there is no torque specified, I usually just tighten 8mm class 10.9 bolts to around 20-25ftlbs. That is what all the stuff on my steering box is...
1800 Type 4 Berrien 295
didget69
didget69 is offline
PostPosted: Mon Jan 27, 2014 8:21 pm    Post subject: Reply with quote
And, as I posted - at 25ft/lb, you'd be on the high end (recommended 24ft/lb.) of the dry torque spec for an 8mm 10.9 grade bolt... Laughing
There is no magic to torque specs for bolts. Engineering charts for bolt specs can be your friend in a pinch.
Or - as an alternative: an old machinist I worked with in the late Eighties used to say "tighten the p*ss out of it & go a quarter turn more", regardless of bolt size/grade/thread... all jokingly stated, of course.
bnc
Vanapplebomb
PostPosted: Mon Jan 27, 2014 9:33 pm    Post subject: Reply with quote
bnc
Funny story from a few years ago...I really underestimated how tight I was tightening a bolt by hand. Needless to say, I ended up with a wonderful looking bullseye on my forehead. The welt took three days to go down. Scared the living crap out of me when the bolt snapped. Now I never crank down bolts hard without safety glasses.
manxdavid
PostPosted: Mon Jan 27, 2014 11:51 pm    Post subject: Reply with quote
Those bolts are too short friend, they don't extend far enough into the nylon locking disc. There should be one full thread extending out of the nut for it to do its job correctly.
Reply to topic    Forum Index -> Kit Car/Fiberglass Buggy All times are Mountain Standard Time/Pacific Daylight Savings Time
