TheStanfordWagen Samba Member
Joined: October 06, 2013 Posts: 99 Location: Dresden, Ohio United States
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Jan 27, 2014 11:37 am Post subject: |
no, the first is just a cover to lay over top of the original.
don't cheap out on this, buy the best you can as fitment is an issue with the cheaper ones and some of the other ones also
research what is the best now. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Mon Jan 27, 2014 11:49 am Post subject: |
how do i mount a dashboard, my 68 is has a bare dash right now. _________________ 1968 Type 1 - Royal Red --- Built: September, 1967
1600 Single Port Engine - F1950480 (VW Exchange) Made January 16th, 1970
113-905-205K
Solex 30 PICT-3
Fahrgest.-Nr. 118096544 |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Jan 27, 2014 1:27 pm Post subject: |
You'll need a proper replacement dash pad then like the second link, not just a quick tart up cover like the first one. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Mon Jan 27, 2014 1:28 pm Post subject: |
Does it have the extra holes for the padded dash to mount? I ask because if it was an unofficial import of a Non-USA model, some models still had the bare dash in 1968.
Cmontoya9 Samba Member
Joined: August 15, 2012 Posts: 162 Location: Santa Fe, NM
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Jan 28, 2014 10:32 pm Post subject: |
Please don't go the way of civic government (lowest bidder) when it comes to your dashpad. you'll hate yourself when your glove box won't open all the way, your radio bezel won't anchor properly, the edge curl, etc. The PO of my '71 went the MAM way- and it's horrible. _________________
EverettB wrote: |
FU#5 |
Hnoroian Samba Member
Joined: October 27, 2013 Posts: 535 Location: Bakersfield
Posted: Wed Jan 29, 2014 12:40 am Post subject: |
I'm debating on buying a replacement like the one mentioned but I also would like the dash smooth with no switches (relocated disccretely under the dash, no glove box, just the speedo. I'm curious on how well they are made ($250 good)...? |
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
camit34 Samba Member
Joined: January 14, 2006 Posts: 1567 Location: Commerce City CO
Posted: Wed Jan 29, 2014 2:11 am Post subject: |
The dash in my '68 was trashed. I just pulled it off and welded up the holes that where used for the mounts and once a respray was done it looked much nicer all metal and the same color as the rest of the bug. Just a looks thing that is a "to each there own" type of deal. _________________ In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD) |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Wed Jan 29, 2014 3:31 am Post subject: |
CIP1 also does a replacement padded dash - I'm keen for feedback on quality too as I need one for one of my projects (RHD) |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Sun Apr 20, 2014 7:43 pm Post subject: |
I want the best regardless of cost. Why is Wolfsburg, at $275 the best? _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Tazzilla Samba Member
Joined: September 22, 2008 Posts: 174 Location: Nampa, Idaho
Posted: Sun Apr 20, 2014 7:58 pm Post subject: |
I bought this one and found fit and quality very good. My vents are shown installed wrong they are now correct. I am also painting glove box door black for a more sleek look. Only down side was there is no hole cut of for the E-Flasher knob. easy fix here is some before and after shots I will have it completed as soon as my bug gets back from having the motor and trans rebuilt
https://www.airheadparts.com/vintage-vw-parts/dash...3857051-as
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Sun Apr 20, 2014 8:26 pm Post subject: |
Personally I tried a cheaper version, that even claimed that it was OEM. It had a VW logo on it but it was crap. The dash from Wolfsburgwest was far superior. Better fit and finish. It looked far closer to original than any other I've seen.
-jeffrey _________________ Der Kleiner Kampfwagens |
JDGas Samba Member
Joined: June 23, 2004 Posts: 1233 Location: Escondido
TX-73 Samba Member
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Sat Jul 19, 2014 3:14 pm Post subject: |
Does anyone know why WolfburgWest has a separate part number for the 71-72 supers? I emailed them and they did not reply. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
banditwolf Samba Member
Posted: Sat Jul 19, 2014 3:58 pm Post subject: |
theKbStockpiler wrote: |
Does anyone know why WolfburgWest has a separate part number for the 71-72 supers? I emailed them and they did not reply. |
73 -79 supers use a different pad.
I think the 71-72 are the same as a standard. _________________ 1973 Super Beetle l 1981 Trans Am |
