OldSlammers Samba Member
Joined: January 29, 2014 Posts: 18 Location: Reno Nevada
Posted: Wed Jan 29, 2014 3:30 am Post subject: 2276 Build! |
Last summer I had a 1915 in my Karmann Ghia. After a show the engine took a big shit. Turns out I broke a crank! Now I'm on a bigger and faster engine a 2276.
This is what I plan on running
My old AS41 case
82mm CW Crank from CB
CB 5.5 VW Journal Rods
New AA 94's (My old 94's barley have any ware, could I still use them with a stroker?)
Engle FK Series Cam (Not sure which one? FK87?)
CB Lifters
Heavily Port my 042 headswith 42x37.5
Scat 1.4 Rockers (Depending on cam)
44 Webers
1 5/8 merged exhaust
10.5:1? I want the compression a bit high. Weekend driver/Strip
I had my case sent out to Brotheres VW
Linebored, stroker clearance, full flowed, welded the center main (spread), decked case. |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Wed Jan 29, 2014 6:47 am Post subject: |
What cam was in the 1915? Did you like the powerband? The FK87 will make power to somewhere around 7500-8,000rpm if everything else is right (I think the 44's may hold it back), but at the expense lower end and midrange power, where you'll be 95% of the time on the street. Unless you're very dedicated and have close ratio gears to keep it in the powerband (and spend a lot of time at the track), it won't be a very fun car to drive. An FK8 (6500 peak)or even FK10 (7,000 or so) will allow you to drive the thing all over the place. Even though the 94's don't have much wear, the pin height is wrong and will make for an extremely wide engine with an 82mm crank, so a stroker p/c is in order. I would keep the compression down to about 9.25-9.5 for the FK8 and a half point higher for the FK10. You could run it a little higher, but you may not find it worth it for the extra little bit of power gained; you'll have to be spot on with the tune all the time and 1 bad batch of gas could spell disaster.
As usual, just my 2 1/2 cents (I'm Canadian, eh). Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Jan 29, 2014 7:28 am Post subject: |
You'll need "B" set of pistons and cylinders. With the 5.5 rods, you'll need to shim a bit as with a normal 5.4 rodded -82 stroke you get a little negative deck ( sticks out past at TDC). Id go with a FK10cam, but make sure you get those 042s really ported out to get the most out of it and the higher duration from the cam. An FK8 would be a great cam if you decide to leave the heads as is. FK87 requires a bit more CR and better flowing heads. Good choice on lifters and good choice on rocker assemblies. 10.5 can work very well with that cam. My take. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Wed Jan 29, 2014 7:36 am Post subject: Re: 2276 Build! |
Use a 86C or FK45-46. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Wed Jan 29, 2014 8:01 am Post subject: |
Curious, what crank were you running in your 1915? |
zac_atac44 Samba Member
Joined: September 18, 2011 Posts: 269 Location: Tennessee
Posted: Wed Jan 29, 2014 11:02 am Post subject: |
What kind of Crank did you have that broke? |
Posted: Wed Jan 29, 2014 2:37 pm Post subject: |
ALB wrote: |
As usual, just my 2 1/2 cents (I'm Canadian, eh). Al |
I had an Engle 110 in the 1915, I kind of like the FK8. I ran 9.5 in the 1915 thought I'd up it for a stroker. And for the p/c's that's what I've been reading for a stroker. I'll probably end up saving them and building a 2nd motor. |
Posted: Wed Jan 29, 2014 2:38 pm Post subject: |
zac_atac44 wrote: |
The crank was a stock German 69mm. Revving over 6k got it to snap |
77charger Samba Member
Posted: Wed Jan 29, 2014 4:56 pm Post subject: |
More than 6500rpms is going to need forged pistons _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
Bugboy209 Samba Member
Posted: Wed Jan 29, 2014 7:38 pm Post subject: |
I see you picked up a set of AA pistons I would recommend you save up your $ and get some mahle stroker p's&c's the AA's are nice and pretty but that's about it sell the AAs _________________ Ai Dos Mio...D.B.K!!! (o\ ! /o) |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Wed Jan 29, 2014 9:05 pm Post subject: |
77charger wrote: |
More than 6500rpms is going to need forged pistons |
Why? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Bugboy209 wrote: |
I see you picked up a set of AA pistons I would recommend you save up your $ and get some mahle stroker p's&c's the AA's are nice and pretty but that's about it sell the AAs |
Posted: Thu Jan 30, 2014 12:05 am Post subject: |
bugguy1967 wrote: |
Bugboy209 wrote: |
Why? |
The casting is horrible and it also shows in the price
Invest in mahle the best you can get I put a set in my 1641 and my 2276 _________________ Ai Dos Mio...D.B.K!!! (o\ ! /o) |
Posted: Sun Feb 09, 2014 10:00 pm Post subject: |
jfats808 wrote: |
You'll need "B" set of pistons and cylinders. With the 5.5 rods, you'll need to shim a bit as with a normal 5.4 rodded -82 stroke you get a little negative deck ( sticks out past at TDC). Id go with a FK10cam, but make sure you get those 042s really ported out to get the most out of it and the higher duration from the cam. An FK8 would be a great cam if you decide to leave the heads as is. FK87 requires a bit more CR and better flowing heads. Good choice on lifters and good choice on rocker assemblies. 10.5 can work very well with that cam. My take. |
So I narrowed it down to the 5.4 Rods, but I am still deciding on a cam. Right now it's the FK10 or the FK87 the heads are going to be heavily ported. I've been reading on the forums about someone who has a set up similar to the one I'm going to build but drove it daily for 3 months. I'm not trying to drive it daily. |
Posted: Mon Feb 10, 2014 7:38 pm Post subject: |
bugguy1967 wrote: |
77charger wrote: |
Why? |
Stronger is the main reason the AAs are great for no turbo set ups where rpms are kept under 6500.I know a few builders who have used them also with no probs on motors set up for peak power under 6500.
I am using them in my 2275 right now i had mahles but for my build my keep it under 6500rpm.Money was tight at rebuild too and i needed new cylinders so i figured i would try the AAs out.The mahle pistons i had are still good so i just put them away.But for the price of vw stuff these days its going to be cheaper to go watercooled next time. _________________ Click to view image
2275 built by me
Posted: Tue Jul 29, 2014 8:43 am Post subject: |
Basically went an entire different direction with this build. I acquired a t3/t4 turbo and a hideaway turbo header for dead cheap in my local area for under $150, the turbo and the header basically brand new. Still going to be a stroker but running boost. Any recommendations on cam and CPR? I've heard people running 8-8.5 CPR with a fk8 but I'd like to keep it around 7.5:1 for more boost. What carbs should I run? I'm not really interested in going EFI, I have kadrons on hand but not to sure on them. What do youngish suggest? |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Jul 29, 2014 9:05 am Post subject: |
Call Vw paradise or Ron Lummus for a turbo cam. I believe the big boys are running a fk44/45 profile on a 112-114 CL _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
RoadRacer Samba Member
Posted: Tue Jul 29, 2014 4:22 pm Post subject: |
Another vote to lose the AAs, mine ended up costing me about $4,000:
_________________ 1969 Formula Vee, modified to have fun as a TT car.
2276cc, boat tailed case, Ultra Wedge Ports, 11.5:1, 7.5 lb. fly wheel, 48 IDFs, Crank Triggered, WebCam 86C, 1.4:1 rockers, Oberg filter, AJ SpeedShift sequential shifter, 4 Piston Wilwoods |
Chip Samba Member
Posted: Tue Jul 29, 2014 6:14 pm Post subject: |
OldSlammers wrote: |
The fk8 is a great turbo cam. 86b is another good one. I have a Paradise Motorsport grind in mine now, its huge, probably only drives decent because of the efi.
I think 7.5:1 is not wise. I would go more compression and less boost. compression is gonna give the motor power when not on boost. High boost creates heat before air enters the combustion chamber. While it is cool to say that you can run 15psi on pump gas, you will have a pig to drive around town, that only wakes up when your foot is buried. VS a 9:1+ setup that runs maybe 10psi but makes the same power, and gets out of its own way while not boosting.
Want best of both worlds? Buy squishies. |
58ragman Samba Member
Joined: September 29, 2014 Posts: 404 Location: OC to ontario
Posted: Sun Sep 18, 2016 4:01 pm Post subject: |
RoadRacer wrote: |
never ever use AA products regardless how many wins or loses they got proof in the pudding garbage parts is an expensive list that goes in the trash |
