Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Tue Apr 22, 2014 10:55 pm Post subject: |
nevadaesh,
Do you have a link to where you bought your RedTek? My browser/internet is going through Italy/Poland tonight and I cannot find a source. From what I'm seeing the last it was available was 2012!
Thanks. Good job on the write up as I'm installing a '90 year AC unit into my '84 and wondering if I was going to keep the plastic housing or modify the wooden shelf space to accept the evaporator and fans. Your pictures helped a lot. |
Terry Kay Banned
Posted: Tue Apr 22, 2014 11:34 pm Post subject: |
RED TEKŪ products are available through authorized sales representatives worldwide. Your local sales representative is knowledgeable about RED TEKŪ products and is waiting to assist you with your purchase or any questions you may have.
Thermofluid Technologies, Inc. will provide field support by way of our professional local Sales Representatives. The following people are available to meet your RED TEKŪ
product needs.
In the United States
Location 1:
P.O. Box 1114
Alcoa, TN 37701
Phone: Toll Free 1-888-676-9380
Local: (865) 983-1633
Fax: Toll Free 1-888-667-0695
Local: (865) 983-0068
Our Sales Representatives are available to assist you for customer calls, training your staff, product forecasting and for scheduling and promoting field clinics. _________________ T.K. |
Posted: Wed Apr 23, 2014 4:57 am Post subject: |
Thanks T.K. |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Wed Apr 23, 2014 12:26 pm Post subject: |
Terry Kay wrote: |
product needs.
Location 1:
P.O. Box 1114
Alcoa, TN 37701
Our Sales Representatives are available to assist you for customer calls, training your staff, product forecasting and for scheduling and promoting field clinics. |
For once (and only once), we Canucks have better availability of a good product up here. Every NAPA outlet, Canadian Tire store, Princess Auto store, etc etc sells the whole RedTek line over the counter up here.
Anybody close to the border should consider buying RedTek up here. _________________ '86 Syncro Westy SVX |
cellerdoor Samba Member
Joined: July 10, 2012 Posts: 403 Location: Fairfax Virginia
Posted: Wed Apr 23, 2014 12:34 pm Post subject: |
I had no issue getting my redtek. Called the number Terry listed, talked to a person about my needs and 4 days later the cans were at my door.
Person I talked to recommended 4 cans of 12a (no sealers or oils). Three would have been cutting it close, and by purging the charge lines first I may have ended up just shy.
Pulling a Vacuum Friday and Charging on Saturday!
Psyched to get this completed. _________________ 1986 Westy |
Posted: Thu Apr 24, 2014 5:27 pm Post subject: |
Pulled a vacuum today with my trusty mastercool 3cfm 75 micron unit and everything appears to be going smoothly.
Got the lines to fit without 90 degree connectors (barely). had to snake the high side line through the coil since my compressor is turned 90 degrees.
Oiled and started up the pump with high and low side gauges open. Supprised to see vapor coming out of the exhaust which was not oily. Wasn't sure if that's moisture or pag 46. Only lasted 30 seconds.
It took only a couple of minutes to peg out the vacuum scale, and I left the vacuum pump running for two hours.
Closed the manifold valves and then shut off the vacuum pump. Two hours later the vacuum is still at 29/30 which is a good sign. I'm leaving it overnight.
If OK, onto charging. _________________ 1986 Westy |
Surferboy120 Samba Member
Posted: Sun Apr 27, 2014 7:08 pm Post subject: |
I cant wait to see the results. I plan to use this DIY as reference for my own rebuild as well. I plan to use R134a though with all new parts on my 85 model westy like you have. I have a Bostig\Zetec swap so a few things different there but should follow the same path as you relatively. Exciting stuff you have done here and I appreciate all that you have posted as it will be a HUGE help.
Thanks again
Thomas |
Posted: Mon Apr 28, 2014 3:27 am Post subject: |
Hit a problem which I started a more specific topic here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=592739
Looks like I have a defective expansion valve, or the method I installed it/insulated it is causing an operation problem.
Right now the system works and is blowing cold air, but it certainly isn't operating in a sustainable way. Have to dig into the expansion valve to test and possibly replace.
Love the Eaton hose system and the entire set up. Held a tight vacuum for 24 hours. Just sucks that one of my new parts may not be up to the challenge. _________________ 1986 Westy |
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Mon Apr 28, 2014 4:55 am Post subject: |
Don't be discouraged, you're doing great.
Might be the tiniest piece of crud got into the line and plugged the valve, you won't know until you take it apart. "So, that's where Uncle Elmo's glass eye went..." _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
LemonCove Samba Member
Joined: July 29, 2010 Posts: 324 Location: Henderson, NV
Posted: Tue May 06, 2014 9:30 pm Post subject: |
Don't laugh but I have already made a word document with all of your images as well. I was super excited to see you had done the AC setup on the Bostig too. All the photo comments helped me a lot. Very much appreciate that. Once I get the parts in for the hose lines I may start a thread to help others and provide any insight I may get from the experience. |
Posted: Fri May 09, 2014 5:54 am Post subject: |
I have all new hoses and EZ clip fittings in, need to wire the trinary switch. Not worried about the fan, but where and which wires did you connect to? I have an idea what I want to do, but would love to get reassurance from someone with a working system.
I have the 4 pin connector from the VW binary switch, 2 red/blue, 1 red/black, 1 red/white. My trinary has 4 wires, 2 blue, 2 black.
My evaporator, only thing not replaced, blew snot for 4 rinses, now clean as a whistle. Used TK's air line antifreeze alcohol, worked great! _________________ ________________________________________
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32593 Location: Reading Pennsylvania
Posted: Tue Mar 24, 2015 6:34 am Post subject: Wiring the trinary switch |
I did wire up the trinary switch successfully! I used led lights via straight pins to tell me when circuits were on. My air conditioning is awesome, so cold I run the fan on 2. I had a temperature probe in the outlet and the lowest it blew was around 45 degrees F.
Dave,
I have leftover binary valve (VW) and cut hoses with fittings if you want them.
You pay the postage and they're yours.
I highly recommend using EZ Aeroquip fittings and hoses, very easy to do, the hoses are smaller in diameter compared to the old ones, and easier to route. Hose can be found on EBay much cheaper than retail. Some fittings can be found, but not at much of a bargain. The install kits on Ebay are very cheap, as is just the crimping pliers. _________________ ________________________________________
Posted: Fri Mar 27, 2015 7:58 am Post subject: |
Transferring some system rebuild information over from the Compressor thread......
http://www.thesamba.com/vw/forum/viewtopic.php?p=7609976#7609976
djkeev wrote: |
dhaavers wrote: |
djkeev wrote: |
...Red Tek functions very similar to R12...
...I am fully confident that the SD5 running RedTek will blow the socks off of any...system using a 30 year old 508 compressor...
...Until someone really smart posts verifiable statistics on WHY the SD7 is better, I'm running the SD5... |
Word that. I'm right behind you, Dave!
I'll be pulling the old hoses this week & use the original fittings to rebuild with new barrier hose.
Flush out the old condensor & evap, drop in the new 508, r/d & expansion valve & I should be
pretty cool pretty soon! I'm budgeting about $750 for all this, not including what I already have
into my service manifold, vac pump & R12a already on hand.
FWIW: My R12a brand is "Envirosafe" < http://www.es-refrigerants.com > which is identical
to RedTek, but was a better price at the time I was shopping about a year ago...YMMV.
Keep cool!
- Dave |
If I may suggest....... Do not yet build your hoses, especially with the existing fittings.
The odds are high that you will need different fittings.
The 6630 compressor, while is piped in the rear as the original is, it uses different fittings.
The replacement 16x22 Condenser probably has different fittings and most assuredly in different locations so length will need to be modified.
The Receiver /Dryer...... You can get the factory unit but......
Keep in mind that as built, your system has ZERO safety shut down devices. No low pressure. Shut off, no high pressure shut off either.
You run the risk of compressor damage or exploding hoses as a result.
I would consider a rec/drier with a trinary switch that you wire into you compressor clutch and into your radiator cooling fan.
If you go this route, you add redundant safety and may need different fittings on the rec/dryer as well.
For the entire system rebuilding let's use the System rebuild thread....... http://www.thesamba.com/vw/forum/viewtopic.php?t=583818&postdays=0&postorder=asc&start=0
Focus on compressor options here.
Dave |
_________________ Stop Dead Photo Links how to post photos
Ghia
Vanagon
Beetle
Posted: Thu Apr 02, 2015 3:41 pm Post subject: |
Gathering parts together as I've figured out the AC wiring, the location of particular components, sizes needed, replacement options, what needs replacing or upgraded, etc.
I am staying with Oring sealing joints when given the option.
In that vein this is what I've ordered for the Early 86 .............
Genuine Sanden SD5H14 Compressor. Modern replacement for the original 508 series.
(I did debate going to the SD7H15 but I don't think it's worth the extra cash for the seven cylinder. It produces a mere .115942028985507% more output that the SD5H15. 138cc vs 154cc )
Vintage Air PN 047000-SUR rear cover "K" rear exit...... $199 plus shipping.
Condenser, Nostalgic Air #54-1622 unpainted....... $89.99 The Aluminum fins on my original Condenser crumble and turn to dust when touched.... Jersey De-Icers at work!
Receiver Dryer, Nostalgic Air # 4-1000 ...... $14.99
Binary Switch, Combined High Pressure and Low Pressure Shut off switch..... Nostalgic Air #119-9900 ......... $9.99.
Screws into Above Receiver Dryer. Will be protected in the LF Wheel Well from Stones Etc. by cutting an old pump Spray bottle to fit over the unit and clamp it on.
Binary Wiring Harness, Nostalgic Air #119-9904 ......... $5.99
Order placed with Nostalgic Air........
Ghia
Vanagon
Beetle
