hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Mon Aug 25, 2014 4:35 pm Post subject: |
I read down through the add, he says that the roof was replaced.
I'll have to do mine, probably in two years. Fortunately I park the car inside, so the roof stays open pretty much all summer. I close it in the winter, but leave it unlatched so the material can shrink without too much stress.
I only open and close it overnight, or if it's raining, when I'm away. |
VWGirl Samba Member
Joined: June 03, 2003 Posts: 2462 Location: Powder Springs, GA
Posted: Mon Aug 25, 2014 4:55 pm Post subject: |
Shop that replaced my top said to just not lower it if it was below like 60f outside. _________________ Without love in the dream it will never come true |
hopkin Samba Member
Posted: Mon Aug 25, 2014 5:39 pm Post subject: |
VWGirl wrote: |
Shop that replaced my top said to just not lower it if it was below like 60f outside. |
Did you have it done locally, how much?? |
VWGirl Samba Member
Posted: Mon Aug 25, 2014 5:52 pm Post subject: |
I had it done locally when I lived in chattanooga Tennessee. They did a canvas top and a nive rear window with double stitching. New headliner and fixed some issues I had with it binding. It was $1000. Not cheap but not bad considering it was full custom..
I have a pic or two of it with the top off somewhere. _________________ Without love in the dream it will never come true |
Gerrelt Samba Member
Joined: December 22, 2004 Posts: 682 Location: The Netherlands
Posted: Thu Aug 28, 2014 1:26 pm Post subject: |
I think $1000 is pretty cheap, you did well!
You can order the ragtop and the needed extra parts on this website:
http://www.ck-cabrio.de/verdecke/cabrioverdecke-von-a-z/vw-kaefer-mexico-1996/
And in parts alone it's over $1000.. Or is that german company too expensive?
@all:
Do your beetles have the plastic gas pedal? If so, how does it hold up?
I was fooling around with the pedal assembly tonight, and I thought about replacing the plastic gas pedal with an metal one.
I have an old assembly too, but I noticed that the metal gas pedal has much more sideways play then the plastic one.
There were other differences too. The clutch pedal on the old assembly didn't have the extra support (a the little arm that touches the firewall when the clutch is fully engaged), and the pedals themself are not welded as good as the ones on the newer assembly.
And the inner clutch arm (the one the cable attaches to) looks stronger too on the newer one.
So I think I will using the newer assembly. _________________ homepage
_________________ |
VWGirl Samba Member
Posted: Thu Aug 28, 2014 1:36 pm Post subject: |
The 1k was only to replace the canvas/window and the headliner. The window busted cause I put it down when it was cold and the headliner had a tear from one of the brackets that had come loose.
The plastic things on the side of mine on the inside are cracked in some places :/
I think it has a plastic gas pedal, I dont really recall. My 98 has almost 100k kilometers on her. _________________ Without love in the dream it will never come true |
hopkin Samba Member
Posted: Thu Aug 28, 2014 3:22 pm Post subject: |
I have the plastic gas pedal and it's in good condition, 95000 km on my Beetle:
VWGirl Samba Member
Posted: Fri Aug 29, 2014 5:07 am Post subject: |
Im not into hacking wiring harnesses... if youre not going to buy the right adapter I would atleast take the wires out of the connectors to put the new obd2 connector on and make it not look like a hack job ... guess it might not really be that simple... thats why I just bought the adapter :/ I dont see why you couldnt leave the adapter connected to run your bluetooth monitor... not really sure what you are trying to monitor though? _________________ Without love in the dream it will never come true |
Posted: Fri Aug 29, 2014 6:18 am Post subject: |
I have no problem with "hacking" into the wiring harnass. I solder the connections and use shrink-wrap to make it look good and solid.
I am never gonna use the standard plug, so it is useless to me, and eliminating it will give me one less connection to go bad.
I think you can monitor engine-temperature. And I could also use it to read error codes. _________________ homepage
_________________ |
VWGirl Samba Member
Posted: Fri Aug 29, 2014 6:22 am Post subject: |
I never understood splicing on cars with these plastic connectors... simply take wire out of connector and put it in new connector... one less splice job to go bad... glad my mexis havent been hacked! _________________ Without love in the dream it will never come true |
Posted: Fri Aug 29, 2014 6:40 am Post subject: |
I agree with you on those blue and red connectors, I don't like those too. _________________ homepage
_________________ |
VWGirl Samba Member
Posted: Fri Aug 29, 2014 6:47 am Post subject: |
Gerrelt wrote: |
I agree with you on those blue and red connectors, I don't like those too. |
No I am talking about what you are doing. No reason to splice wires when its super easy to take them out of one connector and put them in another. YOU are creating a spot in the wiring harness to fail by cutting/soldering/heat shrinking. Its plug and play. No need to create a mess! You should try it sometime! They even make a little rubber piece to fill the holes for spots you dont put wires! _________________ Without love in the dream it will never come true |
Posted: Fri Aug 29, 2014 7:22 am Post subject: |
If the OBD plug I bought can be taken apart, and the connector of the old plug fits into the new plug, then I will certainly do so. But I wonder if this will work.
I've been driving my other beetle for almost 13 years. The harness contains several splices I did they way I described. I have never had a problem with one of those. _________________ homepage
_________________ |
hopkin Samba Member
Posted: Fri Aug 29, 2014 8:01 am Post subject: |
Wiring connections aside, I'm not sure how compatible the s/w is.
I would hobble together something without disturbing the original wiring to test the software and then decide how to wire it. |
VWGirl Samba Member
Posted: Fri Aug 29, 2014 8:03 am Post subject: |
hopkin wrote: |
The cable made for the mexi beetle plugs right in to use standard vagcom software paul _________________ Without love in the dream it will never come true |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Fri Aug 29, 2014 9:53 am Post subject: |
Gerrelt wrote: |
Has anybody tried this? |
I didn't. But I made an adapter cable out of VW spare parts:
1 x three-pin connector shell (357 972 763)
2 x double-ended contact pigtails (000 979 129)
1 x 16-pin DLC connector shell (1H0 972 695)
2 x double ended contact pigtails (000 979 131)
cut the pigtails in the middle, joined them male to female and wired three of the resulting male-female wires it to the connectors according to the 1600i.de diagram.
you can easily make a small adapter plug/socket "box" with the same parts and mount it in place of the dummy plug used to keep the connector at rest. this way the wiring will remain intact. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Posted: Sun Sep 14, 2014 10:57 am Post subject: |
I was working on the front axle, and I was suprised by this:
I had a nut with screw expected as in the old situation.
I like the old situation better, can this be adapted?
Or will the nut-with-screw not fit inside the hub cover? _________________ homepage
_________________ |
hopkin Samba Member
Posted: Tue Sep 16, 2014 7:45 pm Post subject: |
Gerrelt:
The OMNICAR manual shows both setups:
wellcraft Samba Member
Joined: September 12, 2014 Posts: 647 Location: Georgia
Posted: Tue Sep 16, 2014 11:33 pm Post subject: |
GArBa wrote: |
fresh oil and clean injectors... purring like a kitten!
Hi, new to the forum. I just bought a 99 mexican beetle and would like to clean the injectors and would like to know how can this be done.
Thanks. |
