cellerdoor Samba Member
Joined: July 10, 2012 Posts: 403 Location: Fairfax Virginia
Posted: Mon Feb 03, 2014 6:36 pm Post subject: Stereo Wiring Decoding |
I'm replacing my stereo and speakers and have all of the components out and a pile of spaghetti sticking out of the receiver hole and need some help confirming my assumptions.
The PO had put an alpine deck in probably 15 years ago (kept original speakers) and whoever installed it spliced and soldered the alpines harness wires into the westy wiring prior to the blocks, but left the blocks in place.
Luckily the alpines harness is using the standard colors so I matched up the codes to what its attached to on the westy and generated this chart:
Speaker wires are easy, but had three questions:
1. The alpines red ignition and yellow battery wires are connected to two red wires that come from each side of the westy's dash. Im guessing the alpine is splicing into a power wire that also feeds other downstream power needs (original power wires, where radio is always on battery regardless of key position). Is this correct?
2. The alpines black ground wire is connected to two brown wires, once again one from each side of the dash. I'm assuming that the alpine was splicing into a ground run that continues to other grounding needs. Is that correct?
3. The westy had two blue/white wires that terminate in the westy block together, one from each side of the dash. These are not connected to anything from the alpine harness. Not sure what their purpose was.
My plan is to cut the westy harness blocks and wires off where the old alpine's wires are currently spliced into them, then butt splice the westy's wiring directly to my new pioneer deck's harness wires (per the chart).
Does this seem to be the way to go? Anything about this seem drastically wrong? Any input would be appreciated. _________________ 1986 Westy |
Dampcamper Samba Member
Joined: October 07, 2013 Posts: 788 Location: Rainy Portland, Oregon
Posted: Mon Feb 03, 2014 8:08 pm Post subject: |
OK, working backwards on your list:
Blue/White is shown as the wire to the high-beam indicator in your instrument cluster (taps off the fuse for one side of your high-beams), I am not aware of any other factory uses for that color wire but then my experience is with older vans. Do you have a driving light setup that might be using this wire to power a relay?
Volkswagen uses Brown as the color for ground wires. Some after-market electronics use Black as the color for ground wire. '86 has a couple of different wiring schemes where the radio is tapped from a circuit that feeds interior lights (from fuse S-3). Are the "taps" at factory connectors? If so you should be good to go.
Fuse S-3 is fed from the "30" wire, unswitched battery power, always on.
On my radio, the YW wire was battery and the RD wire was switched to power the radio on and off. I added a "Radio" dash switch to allow radio operation without ignition being on. I also power the radio off of the AUX battery now so I don't run the cranking battery flat.
If you go getting creative on your power wiring just make sure you use all fused power sources, we've seen some meltdowns caused by unfused wires grounding out: http://www.thesamba.com/vw/forum/viewtopic.php?t=580316 Note this problem was a bad install by a PO and the van has been properly repaired. |
Posted: Tue Feb 04, 2014 4:34 am Post subject: |
Thanks Damp,
As far as I know (and have all the repair records) there have been no modifications to the vehicles wiring from stock except for this alpine receiver hack in. Radio will play even when the keys not in so its directly wired to the starting battery.
I haven't traced the wires back to the fuse panel yet but plan on doing so shortly to see where this red power and brown ground set up leads to. The van does have power side mirrors but crank side windows.
Still perplexed about the existing blue/white wires since they do nothing radio-wise but come into the westy radio block and leave in the same port, basically twisted together.
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Tue Feb 04, 2014 5:36 am Post subject: |
My guess is external power amp.
The yellow B+ is normally key on. Red B+ is always on, no key needed.
By connecting them together, radio is always on, no key.
Tape the wires to prevent shorting them out. _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
LemonCove Samba Member
Joined: July 29, 2010 Posts: 324 Location: Henderson, NV
Posted: Tue Feb 04, 2014 8:36 am Post subject: |
As I recall (don't have Bentley with me), the blue/grey (look carefully) wires are dashboard illumination. I'm guessing that the stereo is daisy chained . . . . one wire comes from some bulb on the dash harness (heater controls?), and one wire goes to the next bulb on the harness (cig lighter?). _________________ '88 Bostig Westy |
Posted: Tue Feb 04, 2014 10:04 am Post subject: |
LemonCove wrote: |
As I recall (don't have Bentley with me), the blue/grey (look carefully) wires are dashboard illumination. I'm guessing that the stereo is daisy chained . . . . one wire comes from some bulb on the dash harness (heater controls?), and one wire goes to the next bulb on the harness (cig lighter?). |
So would the original stereo that came with the vehicle have a separate illumination feed that's not present in the alpine, and the PO just bypassed it by joining them together? makes logic sense but I cant imagine the original stereo had this. _________________ 1986 Westy |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Tue Feb 04, 2014 1:02 pm Post subject: |
LemonCove wrote: |
This is my recollection as well. The grey/blue stripe wire is connected to the light switch rheostat output (which means its useless for any other purpose but dash lights). I tapped into this wire to illuminate my voltmeter and oil pressure gauges. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
kamzcab86 Samba Moderator
Posted: Tue Feb 04, 2014 1:23 pm Post subject: |
cellerdoor wrote: |
So would the original stereo that came with the vehicle have a separate illumination feed that's not present in the alpine |
Yes. That plug is laying idle in my van. Most, if not all, modern receivers have power-on lighting, unlike the original VW Heidelberg receivers. _________________ ~Kamz
2016 Golf GTI S
Posted: Tue Feb 04, 2014 3:34 pm Post subject: |
My Alpine (2012) has an orange wire that connects to the dash lighting.
Quote from Alpine manual, "This lead may be connected to the vehicle's instrument cluster illumination lead. This will allow the backlighting of the (Alpine Head unit) to dim whenever the vehicle's lights are turned on." _________________ '88 Bostig Westy |
Posted: Tue Feb 04, 2014 7:05 pm Post subject: |
That's clears that issue up. Thanks everybody for your help.
Makes me want to run the receiver from its own battery power feed and ground and not splice into the lines in the dash, and then jump that over to an aux battery in the future. _________________ 1986 Westy |
Posted: Tue Feb 04, 2014 8:05 pm Post subject: |
cellerdoor wrote: |
Makes me want to run the receiver from its own battery power feed and ground and not splice into the lines in the dash, and then jump that over to an aux battery in the future. |
I believe the most important thing will be to compensate for the Vanagon's lack of an accessory position on the ignition switch by coming up with an alternative. Most stereo's today put quite a drain on the battery if they aren't triggered to go into standby mode.
As has been mentioned here, you could just put an on/off toggle in series with the accessory trigger wire to your radio, or instead, you could wire that connection into the key-in wire off of your ignition switch, or you could wire up a hybrid that incorporates both ideas.
Mine is the hybrid, wired to turn on the radio when the key is in the ignition, and I have a switch on the dash where I can play the radio while parked (without putting the key in the ignition). _________________ Tim Potts
'74 Jeep CJ5 |
Posted: Tue Feb 04, 2014 8:26 pm Post subject: |
re: Blue/White wires, yeah, I had my head under the dash and as others said thereis grey/blue used for dash lamps and under there it looks like blue/white. So that is probably your dsh illumination after the dimmer. Some radios can connect to it and some (like my Pioneer) just blast you out with full intensity all the time.
I just added a FLAPS rocker switch in an unused switch position in my dash so I don't have to use the key for tunes. Radio is fed from AUX battery. |
