richparker Samba Member
Joined: November 24, 2011 Posts: 6986 Location: Durango, CO
beetleaddiction Samba Member
Joined: October 09, 2003 Posts: 1404 Location: Miami Lakes
Posted: Mon Feb 17, 2014 6:35 pm Post subject: |
richparker wrote: |
I'm sure there is more resistance but I do not notice it at all. What I do notice is the bike being up there. It's like a fin on windy days especially on a strong cross wind. |
great! I am looking into maybe doing this for longer trips, thanks for the info.... and thanks for sharing your roadtrip |
Posted: Sun Feb 23, 2014 8:44 pm Post subject: |
I only drove the bus Monday this week. The exhaust leak was really pissing me off and I didn't want to drive it until I got it fixed. Turns out my beer can repair held up and the leak was coming from where the header bolts on to the #2 exhaust port. Can't believe I missed that, what a rookie mistake .
I pulled the bumper, rear apron and pulled the whole exhaust. I filled the small gap on my ehchanger with metal epoxy. I used a strait edge and was able to spread it in the gap making the tube flush again. I installed all new gaskets and the leak is gone. While things were apart I used paint stripper and a wire wheel and cleaned up the muffler. Then I primed, painted and baked it. Man it looked great when I reinstalled it. After a 30 mile trip the paint had begun to peal on the bend . Oh well, it sounds good. I also pulled the alternater pully and reprinted that, it was pealing bad. Then I rotated the tries and reset the pressure. With 2 recent post about gravel guards I wanted to install mine while things were apart. So I modified my crunched bumper bracket and got the guards installed with all new hardware.
[img]
[/img]
[img]
[/img]
There was noticeable wear difference in the ft and rear tires. Rear on the left ft on the right
[img][/img] _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Desertbusman Samba Member
Posted: Sun Feb 23, 2014 8:50 pm Post subject: |
Wow, how many miles are on those tires? And what pressure had you been running on the fronts and rears? _________________ 71 Superbug
71 Westy |
Posted: Sun Feb 23, 2014 11:22 pm Post subject: |
DBM, how have you been?
5000 miles. I started high on the pressure and worked my way down with the help of the sticky. 40 rear 35 front. I think I'm gonna go a little higher maybe 45/40. I was blown all over the road today with the current pressure and remember it handling the wind better a little higher. Just another thing I can screw with. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Mon Feb 24, 2014 1:17 am Post subject: |
Rich, your choice is like mine, more stable or more frequent tire purchases. The wear on your rear tires is from over pressure. Your first pressures are closer but still even higher than VW specified pressures. But going even higher expect much more rapid wear.
I just looked at the center tread wear pattern on my rear tires and am going to drop the pressure. It's time to experiment more with front pressures as that's more involved with stability issues. I did a 3 or 4 hour drive from Flag to Vegas when the weather service had issued a high wind warning. The direction was from the left front corner and my arms were so sore once I got to the destination.
So maybe planning would be best. Raise the pressure if winds are expected. Lower it and prevent high wear normally. I really like my Kooks and don't want to wear them out. _________________ 71 Superbug
71 Westy |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Feb 24, 2014 4:59 am Post subject: |
richparker wrote: |
5000 miles. I started high on the pressure and worked my way down with the help of the sticky. 40 rear 35 front. I think I'm gonna go a little higher maybe 45/40. I was blown all over the road today with the current pressure and remember it handling the wind better a little higher. Just another thing I can screw with. |
What shocks are you using? _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Mon Feb 24, 2014 7:29 am Post subject: |
Great thread! I enjoyed it over my morning coffee. Keep at it! _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Posted: Mon Feb 24, 2014 7:51 am Post subject: |
richparker wrote: |
KYB gas-a-just on all 4 corners |
The KYB GR2's up front with the gas a justs on the rear give a much better ride with winds of any sort. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Mon Feb 24, 2014 3:17 pm Post subject: |
My current ft KYBs have only been on for about 4 months and somewhere around 3k miles. So I have some time before I need to change them. I will keep your combo in mind for my next set up. Although I really like how the bus handles now. It's great in the wind now conpaired to running "P" tires but we all know how aerodynamic this rigs are and I know no matter what I'll be blown around. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Fri Jan 30, 2015 5:52 pm Post subject: |
2015 trip
Got the bus all loaded up and we are ready for our trip to Tucson. There have been several changes to the bus over the past year and I'm hoping for a good trip. Thanks to everyone who posted on my brake thread, helped a lot. It is dumping snow out right now. We are looking at 100% chance of snow through the night, 100% chance of snow tomorrow in SW Colorado and 100% chance of rain through NM and AZ. We were going to camp in the Salt River Canyon again but it's going to be cold and rainy so we booked a hotel in Show Low for Saturday night and will finish the drive to Tucson on Sunday.
This year I'm hoping for better milage and lower oil temps. Last years trip I only got a best of 17 mpg. Since then I spent a lot of time rejeting the carbs and adjusting the timing. This year I'm hoping for 20+ MPG each tank. Last year my oil temp were 220+. Since then I've had a in/out oil pump to a full flow oil system installed. So temps should stay around 180*.
I will post plent of pics and post often, as always. Thanks for reading. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
airschooled Air-Schooled
Posted: Sat Jan 31, 2015 8:40 am Post subject: |
Awwww yeah! That's way more hardcore than when I leave for a winter trip; gotta pack closed-toed-shoes.
Looking forward to the pics-
www.airschooled.com |
levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Manfred58sc Samba Member
Posted: Sat Jan 31, 2015 11:18 am Post subject: |
Safe drive my friend!! You're showing how it's done!! _________________ Fat chick owner/operator |
Posted: Sat Jan 31, 2015 2:38 pm Post subject: |
What a great drive! The Bone Bus is buzzing right along at 60 Mph with no problems. Oil temp has been sitting right at 160* or so and the heat has been good. We made it to Gallup in just over a half of tank. We are having lunch in downtown Gallup just off Route 66.
Roads were a little hairy leaving this morning but the Hankooks handled just fine.
I should start a bays and state line signs thread.
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Tuna Tim Samba Member
Joined: November 24, 2005 Posts: 181 Location: Saddlerock, Aurora, Colorado
Posted: Sat Jan 31, 2015 6:27 pm Post subject: |
[/quote]
Agreed.
_________________ 1974 Bay
CSII
091
Dual 40 Dells
Unilite
Thunderbird Extractor |
PLF-Blue Samba Member
Joined: October 07, 2014 Posts: 327 Location: Nevada, tahoe, and elsewhere
Posted: Sat Jan 31, 2015 6:37 pm Post subject: |
Nice thread. Sounds like a fun trip.
We are about to embark down that way as the first leg of our cross country trip. Spit out some good "must see's" and good spots to stop for a night or two for us, will ya? No real exact plans, just hitting the road, spring ball, etc.
Good luck out there. Perhaps we will run into you somewhere _________________ ..."I live in my own little world. but it's ok, they know me here." -L. Myracle |
