airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12688 Location: on a bike ride somewhere
Posted: Wed Feb 10, 2016 3:27 pm Post subject: Re: Road trippin to Tucson! |
richparker wrote: |
He seemed concerned about it over heating and wanted to turn it off to let it cool in between runs. |
This always cracks me up. Once I saw an AZ smog ref put the giant fan in front of a bug for emissions testing. You know, to keep airflow going over that there radiator in the front.
I mentioned this to Rich earlier, but I'm curious to hear comments from more modified-engine folks on why his powerband is so similar in shape to stock regardless of the cam and induction choices. The torque and horsepower peaks are in nearly identical spots, albeit much higher.
Robbie
47hp all day long. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
obieoberstar Samba Member
Posted: Wed Feb 10, 2016 6:03 pm Post subject: Re: Road trippin to Tucson! |
Might have to look up that dyno you have used. It appears to be less than 10 miles from me. Never had the bus on a dyno before.
The whole attitude of the town has changed for the better with these temperatures. January was cold for us folks in Tucson. Still was able to ride the motorcycle to work all winter though.
Enjoy your stay and safe travels. |
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1183 Location: Dallas, GA
Posted: Wed Feb 10, 2016 7:17 pm Post subject: Re: Road trippin to Tucson! |
asiab3 wrote: |
Robbie
47hp all day long. |
My thoughts (as one of those modified engine folks)... The reason peak tq and power speeds are where they are on Rich's engine is due to breathing. He's got nearly 2.2L of displacement, but it's coupled with what I'm assuming is unported 044 heads, a very mild cam (with respect to engine size), and a pretty small header and stock heater boxes. Nothing wrong with that, but it will limit how much power the engine makes as RPM increases as airflow is limited. All that's said, he's got a lot of meat where it's needed. Looks like a great match for a daily driver westy.
With some port work, more exhaust, and a venturi change, I'd bet it would pull quite a bit more RPM and make more power (even with the 110).
Nice work Rich! Enjoying the pics of the trip! _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
Tcash Samba Member
Posted: Wed Feb 10, 2016 8:06 pm Post subject: Re: Road trippin to Tucson! |
Ran across your run with your old engine two years ago to the month.
2/14
richparker wrote: |
115? Damn that's high, my 2109 only put out 68 hp with 89 FPT at the wheels at 4k in 3rd. I'm gonna have to bring my 2175 to the Dyno now...
Doesn't look like they strapped it up to good, musta been a bit scary. My westy strapped to a 4 wheel Mustang Dyno in Tucson, AZ in Febuary '14.
2/16
richparker wrote: |
Alright alright alright...the run on the dyno was awesome!!! This morning I went back to the sport tuner shop, PSI and put my bus back on their Mustang Dyno. The operator called it the Heartbreaker, cause it measures the actual weight of the vehicle and applys a drum brake to simulate real world driving. He ran it two times up to 4800 each time. The bus held together and the Numbers were good!
75 Hp with 107 FPT. Looks like peak performance is at 4400 rpm and it drops off after that. I have a video, I gotta figure out how to post it.
richparker Samba Member
Joined: November 24, 2011 Posts: 6936 Location: Durango, CO
Posted: Wed Feb 10, 2016 8:34 pm Post subject: Re: Road trippin to Tucson! |
asiab3 wrote: |
Robbie
Robbie, it's not regardless of cam & induction choices. But because of those choices that the Peaks are where they are. A radical cam and/or 48mm carbs would alter all of the above instantly.
Hotel Congress
_________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Thu Feb 11, 2016 10:06 pm Post subject: Re: Road trippin to Tucson! |
You have there an awesome journey. My family and I will also do a road trip this coming summer. We are planning of going, from Luzon, to Visayas, Boracay, Cebu, Bohol, then, to Mindanao. Although summer is hot here in the Philippines, nevertheless, we are looking forward to doing it! Keep posting your adventures and the pictures! Thanks. _________________ '67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20 |
Posted: Thu Feb 11, 2016 11:52 pm Post subject: Re: Road trippin to Tucson! |
richparker wrote: |
asiab3 wrote: |
Robbie
Robbie, it's not regardless of cam & induction choices. But because of those choices that the Peaks are where they are. A radical cam and/or 48mm carbs would alter all of the above instantly. |
That makes sense to me now. Before your dyno posts, I would have guessed that the 110 cam would produce its peak HP higher up the range and be less useful down that low. I think, because of all my keyboard warrior knowledge of performance engines, I assumed that cam was much further from stock.
Keep up the good trip. Buddy and I will be there in spirit!
Posted: Fri Feb 12, 2016 6:09 pm Post subject: Re: Road trippin to Tucson! |
Thanks DONGKG, I always love being out on the road with my family. We are creating family memories that none of us will forget.
Robbie, I'm super bummed we're not gonna hook up Sunday for breakfast. So, I'm just gonna have to tell you how good the food was. . Send me your PayPal so I can get money to you for that VS exhaust. I'd like to get it before my bus goes back into the shop next month.
We've just been kicking it the desert for the last two days, nothing too crazy. Took the boy to a city park yesterday morning and had a great lunch at Linda's Mozic Cafe, seriously good Mexican food. Last night we drove 45 min cross town to my buddy's for dinner. Good times and great Vietnamese food, then a 45 drive back to the Cubes (where we are staying). Good friends, good food and 1.5hrs driving in the bus! Today we hit the Reed Park Zoo, which is always a blast. Lil P. ran around all crazy like and loved the animals. After that we had lunch downtown at La Cocina, which is a great little outdoor spot. It hada nice atmosphere, good food, a nice bar, cool shops and Lil P. had a blast. Sounds like we are going to go to Worm Town tonight to do some last minute shopping before we hit the road in the morning. We'll be said to leave Tuscon but it's nice knowing our next visit is only 12 months away... _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Manfred58sc Samba Member
Posted: Sat Feb 13, 2016 2:32 pm Post subject: Re: Road trippin to Tucson! |
Safe travels! _________________ Fat chick owner/operator |
camit34 Samba Member
Joined: January 14, 2006 Posts: 1567 Location: Commerce City CO
Posted: Sat Feb 13, 2016 7:35 pm Post subject: Re: Road trippin to Tucson! |
Manfred58sc wrote: |
Safe travels! |
X2 Be safe out there!
Great fun watching your travels and hoping I'll get my Bus up and running some day soon to do the same. _________________ In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD) |
Posted: Sat Feb 13, 2016 10:23 pm Post subject: Re: Road trippin to Tucson! |
doublea_ron, you gotta get your bus ready for the Southern San Juan off road trip.
We made it to Show Low. Bus ran well with no issues. Temps varied but never got to high and I did not have to turn the fan on. Had no issues pulling the 7 and 8% grades. We pulled out of the Salt River canyon in 3rd ant 3500, there was plenty left in the pedal but there was no need to push it any harder. We got 20.5 mpg from Tucson to Show Low, just a bit higher then the 15.1 mpg I got on the last tank ripping through Tucson. .
Pics pics pics
’71 Westy build
Adventure thread
’65 Deluxe Build |
Posted: Sun Feb 14, 2016 3:53 pm Post subject: Re: Road trippin to Tucson! |
We stopped at a road side attrection place just off I40, what a trip!
We make it to Galuup, NM, the bus just buzzed along. We got our best tank this trip, 146 miles on 6.6 gallons. 22.1mpg!!! _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Posted: Sun Feb 14, 2016 8:27 pm Post subject: Re: Road trippin to Tucson! |
Made it home!!! The bus ran amazing, got 22 mpg from Gallup to Durango too. Woot woot! Gotta go unload and get ready for work tomorrow. A report and pics will follow. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sun Feb 14, 2016 8:52 pm Post subject: Re: Road trippin to Tucson! |
Glad to hear your home safe! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Feb 14, 2016 9:02 pm Post subject: Re: Road trippin to Tucson! |
richparker wrote: |
Made it home!!! The bus ran amazing, got 22 mpg from Gallup to Durango too. Woot woot! Gotta go unload and get ready for work tomorrow. A report and pics will follow. |
awesome. How many miles did you cover buddy? _________________ '67 KG Cabrio (Mickey) ;
'72 Type 2 Homey
'67 Splitty Bus
Posted: Sun Feb 14, 2016 10:51 pm Post subject: Re: Road trippin to Tucson! |
Thanks Stu and DONGKG, the trip was a blast.
We kinda took our time getting ready this morning while getting ready to leave Show Low and then went out for a nice country breakfast. We were supposed to meet up with samba member Asiab3 this morning but...Unfortunately that did not happen as his plans changed. Bum deal, that was the second time were were supposed to meet, third times gotta be the charm. We decided not to change out route home because my wife wanted to go rock shopping in Holbrook. Turns out all the tourist trap stores on Historic Route 66 in Holbrook are closed on Sunday's. Crazy right? We stopped anyway stretched our legs and got some pics. Once again Google came to the rescue and directed us to Stewarts. Man, that place was a trip. We hung out for awhile and got some cool stuff. Then off to Gallup we went on I40. There was no traffic or wind and we buzzed right along with excellent temps. Stopped in Gallup on 491N for fuel and Google saved the day again. Right across from the gas station was a nice well rated Italian restaurant. We hung out for well over an hour and enjoyed some great food. That's another diamond in the Gallup rough that we found. As I wrote earlier the drive from Gallup to Shiprock is usually crazy windy. But...there was absolutely no wind today just like the trip down! The trip was a blast, we covered a lot of ground and did so many things. Tucson has many attractions to offer tourists and we're already excited to go next year again. Thanks for reading.
Did the whole trip with out lifting a screwdriver, thanks JAD Machine!!!!!!
Rich P.
Trip stats:
Total miles: 1257
Total gallons of gas (91): 59.9
Overall MPG: 20.98, I'm gonna call that 21
Total oil consumption: ~1/4 Qt
Dyno results: 75 HP 107 FPT
Pics pics pics
Dinosaurs in Holbrook
This place was a total trip...
Az/NM boarder
’71 Westy build
Adventure thread
’65 Deluxe Build |
Tcash Samba Member
Posted: Sun Feb 14, 2016 11:20 pm Post subject: Re: Road trippin to Tucson! |
Nice trip and pix. Glad you made it home ok.
Thanks for sharing
Tcash |
Posted: Mon Feb 15, 2016 8:28 am Post subject: Re: Road trippin to Tucson! |
Welcome home, thanks for sharing your trip pics. You are the master of road side attractions! Now go deliver some packages. _________________ Fat chick owner/operator |
