danfromsyr Samba Member
Posted: Fri Oct 21, 2016 8:15 am Post subject: Re: 1991 Westfalia GL 2wd Tire fit question |
just bought your westy you need to focus on safety first.. and well tires are safety.. make sure your westy has a few items updated. each of these are searchable topics here in the vanagon forum
#1 REPLACE your fuel lines with properly rated fuel injection hose..
#2 while replacing fuel lines remove and update the plastic firewall hose barb to metal or eliminated altogether.
#3 Replace your alternator harness.
#4 make sure to use a quality MANN/MAHLE oil filter to maintain proper working pressures.
#5 replace the plastic coolant tower (2.1) or H-pipe (1.9) in the cooling system that fails abruptly with a massive cloud of coolant and steam.
#6 service brakes and flush brake fluid.
#7 make sure you have fairly new and properly rated & inflated tires.. (go rim shopping if that then suits your sensibilities)
Abscate wrote: |
geodude Samba Member
Posted: Fri Oct 21, 2016 9:00 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
Halifaxwesty wrote: |
I'm looking at the Hercules Power C/V... 205/70/15
Around 100 bucks Canadian...
Im currently running some 14 inch Westlakes, so Im ok with discount tires.
Any Hercules horror stories? |
I've been running Power C/V 205/65R16 for two years and no issues and barely any wear. Great wet traction. _________________ 1988 GL Camper
1991 Multivan — the basket case |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Mon Oct 24, 2016 4:06 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
geodude wrote: |
I've been running Power C/V 205/65R16 for two years and no issues and barely any wear. Great wet traction. |
Discontinued tire, no more Power CV |
bmouthboyo Samba Member
Joined: October 26, 2016 Posts: 1 Location: United Kingdom
Posted: Wed Oct 26, 2016 2:37 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
Can you guys confirm that 215 75 R15 tyres will fit on standard height 2wd T3?
I have a DU 4 speed gearbox with a 1.9 Golf Mk2 Gti engine in and would like to lower my RPM.
At present I have the stock 14" steels.
Thanks |
Posted: Wed Oct 26, 2016 9:29 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
I've had a hard time getting a straight answer on this question. There are many variables that affect what "fits," tire diameter, width, rim offset (ET). It also doesn't help that many Syncro owners like to chime in and not say they are talking about a Syncro when you are asking about a 2wd to muddy the water. But, based on all I've seen for 2wd you are safe if you stay below 27" diameter for all 2wd no mater which springs you are on. When you get above this tire diameter people start reporting rubbing with the lower vans (Wolfsburgs, Carats, etc.). Above 27.5" tire diameter it seems there are reports of rubbing on all the 2wd vans on hard bumps in turns. Your stated tire size is 27.7" diameter so would likely rub from what I've seen. Having a wider tire makes the problem worse, having offsets that push the wheels out further than stock makes the problem worse (the popular Euro look rims with ET of 21 for instance). _________________ 1988 GL Camper
jakefromstatefarm Samba Member
Joined: July 31, 2016 Posts: 46 Location: Bay Area, CA
Posted: Tue Nov 01, 2016 4:03 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
Tire Question for the ULTIMATE tire thread
Hey folks. I am getting my first Eurovan (01 PopTop) and it needs tires. I'll be loading my wife & three kids in the car, so I guess its a good thing to get to do for safety purposes.
I live in the Bay Area of California and my driving will be about 85% paved roads and 15% snow trips to Yosemite or dirt roads in National Parks. Bay Area and Northern Cal will get winter rains, but not ice/snow unless I head to mountains.
Given this, do you suggest going all-terrain or all-season with my tire choice? I have a few car folks in my life, and there are varying opinions.
Some say go all terrain. The EV will handle better in the snow and I won't have to worry about a sidewall at all on dirt roads. Main argument is maximum safety when the tire is prepared for most extreme conditions possible. Seems if I go this route, I'll go with the Hankook ATM's 225/70/60.
Others say go all season. Main argument is maximum safety is how tire performs in wet conditions, as an all season channels water out better and offers superior wet traction. They say a good all season tire will do fine for the limited dirt and I can use chains or cables for snow. If I got this route, I will go Michelin LTC M/S2.
I don't care about the MPG difference and am primarily driven on what is safest. I'm probably overthinking it, but am curious what the Samba-ites think. Would you go all terrain or all season and why? |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Wed Nov 02, 2016 8:30 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
jakefromstatefarm wrote: |
Hey folks. I am getting my first Eurovan (01 PopTop) and it needs tires. I'll be loading my wife & three kids in the car, so I guess its a good thing to get to do for safety purposes.... |
Eurovans came with different wheels and tires than vanagons but I think you could go with the BFG 215/65R-16 AT KO2 tire and you would be pretty happy. You could run this question by the Eurovan forum. |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Nov 02, 2016 8:45 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
davevickery wrote: |
Ya, I agree. I totally hated the stock tires that came on my 'new off the lot' 2003 EV Westy Weekender when I bought it. Certainly don't expect those V treaded freeway tires to get you out of your flat but grassy camp site when it is dewy. Total nightmare. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
dustyrhodes Samba Member
Joined: December 20, 2010 Posts: 38 Location: Venice, CA
Posted: Sat Nov 05, 2016 4:25 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
I just installed 215/65/16 BFG KO2s on 16" South African steel wheels from van-cafe.
Stock springs and KYB shocks. GW 1.5" lift and Fox shocks coming as soon as my burley UCAs come in. Love the look so far!
_________________ 1989 Vanagon Westfalia |
TheArmand Samba Member
Joined: May 11, 2016 Posts: 92 Location: Santa Monica
Posted: Sat Nov 05, 2016 5:21 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
My god, your van is freakin' gorgeous. Lookin' GOOD! |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Sat Nov 05, 2016 6:44 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
In case this one has not already been mentioned, it looks like Maxxis makes a tire suitable for a Westy, the UE-168 in the stock 185R14C size with a 102 rating. Looks stout. I spotted these on a van at a local tire shop.
_________________ '87 Westy in Wolfram Grey Metallic |
AIREK23 Samba Member
Posted: Mon Nov 07, 2016 8:31 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
New syncro owner here. I need new tires and wheels. For wheels, I am going with the Euro look 16" alloy black rims from Vancafe/Gowesty. For tires, I am debating between the BFG T/A KO2 215/65r16 VS BFG T/A KO2 215/70r16. the only difference is the 65 vs 70 aspect ratio? Anyone have any tips or recommendations? Thanks.
86 Syncro tin top. |
Posted: Mon Nov 07, 2016 8:37 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
AIREK23 wrote: |
There is PLENTY of answers to your question if you search these forums well. Spent 30-60 minutes and you will know everything you want to about syncro specific tire sizes as relating to your question. |
Posted: Mon Nov 07, 2016 8:53 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
I guess I'm just concerned that the 215/65r16 BFG's will look small. In terms of look, how much different are the 215/70r16? I want my new tires to look big and aggressive. |
Posted: Tue Nov 08, 2016 11:57 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
AIREK23 wrote: |
16" rims look much bigger than stock even with the same diameter tire. The tires you are talking about are approximately 1.3 and 2.2 inches in diameter bigger than stock, 27 and 27.9 inch diameter. Without modifying the trailing arms you can't go beyond about 28.9" diameter from what I've heard, but you probably have body mods to contend with. Also think about your gearing, you are effectively adding higher gearing. The stock 2.1 is going to be struggling with your new huge tires. _________________ 1988 GL Camper
h00drat Samba Member
Posted: Fri Nov 11, 2016 11:54 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
I've seen these tires on 16" rims on a highly modified van, but never on the stock 14" rims. Anybody see it done?
Based on my research, they will fit. Not seeing them on the first page here under the 14" wheel section, but maybe that's because they're a pretty aggressive off-road pattern, and they're also pretty new (I think).
My van is 2wd Tin-Top on camper springs (1" lift).
I want something that will be road friendly, but also get me through some dirt and mud, at an affordable price point. So far these fit the bill.
For me it's between these and General Grabbers or something, but I've heard those tread patterns perform poorly in mud.
Kumho Road Venture MT KL71
Sidewall Style: Blackwall
Load Range: C
Serv. Desc: 95Q
UTQG: None
http://www.tirerack.com/tires/tires.jsp?gclid=CjwK...174902%3As _________________ <<Tyler>>
1987.5 Wolfsburg Weekender / CHC / 2.0 ABA
CHC Top Thread
Engine Conversion Thread (2.0 ABA Swap)
ABA Swap - Image Gallery
Auto Trans Rebuild - Image Gallery |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Fri Nov 11, 2016 1:27 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
The problem you might find with these is the 95q load designation.
Since it's not an xl I think it gets derated an additional 9%, on top of already being only a 95. That probably puts it around 1400 # max, maybe even 1350, which is entirely up to you of course, but most folks don't think that is a good idea for a vanagon. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Fri Nov 11, 2016 4:04 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
levi wrote: |
Since it's not an xl I think it gets derated an additional 9%, on top of already being only a 95. That probably puts it around 1400 # max, maybe even 1350, which is entirely up to you of course, but most folks don't think that is a good idea for a vanagon. |
Good point. I was paying attention to the load range (C), and thought I had seen that 95 was sufficient. I'm a fan of "better safe than sorry". _________________ <<Tyler>>
CHC Top Thread
levi Samba Member
Posted: Fri Nov 11, 2016 7:20 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
I'm not saying that it isn't safe.
Just something that you might want to check on. _________________ One of these days I'm gonna settle down,
