earlywesty Samba Member
Joined: May 03, 2004 Posts: 2357 Location: In the woods, Ontario
Posted: Wed Mar 05, 2014 4:38 am Post subject: |
sled wrote: |
well I thought I might as well throw up another update for those who were interested in this thread.
Its been slow going, taking my time with stripping the old finish and trying to repair delaminating veneers as well as doing a bit of bleaching here and there.
with some pieces mocked up
I actually have the wash cabinet finished with new Alex-repro gold edging and polished formica. I'll get some pictures and post them cause its a thing of beauty |
Do you have enough left for the table? I found another piece the other day which which you might be able to use to complete the table if not. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Wed Mar 05, 2014 5:34 am Post subject: |
Great stuff, Jake!
Please show more details of your relamination process.
Fixing up those ragged, wavy, warped plywood edges must be a total pain. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Wed Mar 05, 2014 6:07 am Post subject: |
Unbelievable, outstanding job. I would have never dreamed they would turn out thst nice. I commend you for taking on this time worthy task. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
jjjjack Samba Member
Joined: August 08, 2005 Posts: 1013 Location: Gainesville, FL
50ate Samba Member
Joined: September 22, 2007 Posts: 1171 Location: Rainier/Olympia Washington
Posted: Thu Mar 06, 2014 12:37 am Post subject: |
Looks killer, I know what it was from the beginning.. I thought about leaving it along highway 20 just to save you the headache... I love the hardware... |
Ran When Parked Samba Member
Joined: September 26, 2013 Posts: 781 Location: Birmingham, AL
Posted: Sun Mar 16, 2014 7:52 am Post subject: Any Updates? |
Any updates? I am curious what you will do for the door and ceiling panel damage. |
scholsie Samba Member
Joined: January 05, 2013 Posts: 9 Location: Derbyshire, England
Posted: Sun Mar 16, 2014 3:31 pm Post subject: |
Just starting the resto on my SO42 interior and have some water damage to the side panels, I was wondering if you use branded "wood bleach" or straight oxalic acid? If straight acid what strength do you mix it to?
Also what thickness scraper do you use for this kind of interior work? |
sled Samba Member
Posted: Thu Mar 20, 2014 10:47 pm Post subject: |
been a while since an update..had other stuff going on and I lost a little steam at one point.
anyway, back at it. To answer a couple questions first.. With the wood bleach I am actually using straight Oxalic acid. The strength of the mix depends on how bad the water damage is but from my experience it is always better to start out mild and work your way into a stronger mix, to try and prevent too much lightening. I use small amounts at a time and usually go about 2 cups water to a heaping tablespoon of acid.
I have not tackled the ceiling panels yet, those and the long wall panel will be the last items to try and repair. The door panel was too far gone to save and it was sacrificed for other repairs as explained below.
ok on to the wardrobe cabinet. previously I showed the door itself refinished but had not gotten to the bulk of the cabinet.
as seen previously the cabinet had extensive water discoloration/delamination down low and a big speaker hole heinously hacked into it, as well as a weird little picture-box thingy glued to it. I was fortunate enough to get the picture box off without ripping any veneer up. The glue didnt stick very well to the original finish on the cabinet.
like mentioned before I was going to just leave the speaker hole but then thought I would try my hand at doing a veneer patch.
here is a flitch of veneer I removed from the wasted door panel (not the actual flitch used for the patch) which shows how nice it really is after stripping the nasty old finish.
here is the offensive hole..
I decided I wanted to try and have the patch cover those two small random screw holes beneath the speaker hole. Plus, it is far more effective to use angles when patching across the grain, it helps the patch to blend rather than having a perpendicular line crossing the grain patterns.
once I had the patch cut nicely with a razor (very important to have perfectly straight CLEAN cuts) I laid it over the cabinet and traced it. Then carefully cut the tracing and slowly peeled the original veneer off the cabinet. I had some random 2.7mm lauan plywood kicking around that I used to patch the hole itself with. The tighter your patch, the better the result here as well. Of course one could always use filler to take up gaps and smooth it out.
here is the veneer patch glued in place with regular yellow wood glue and an iron applied to set the glue quickly and to flatten the veneer as much as possible.
and this is the cabinet after bleaching and finishing. Don't mind the lower area where it is up against the seat base, I chose not to spend any time on this area because it will soon be hidden again for the foreseeable future.
I think it came out pretty well all things considered. It was a bit of a mess before, but now I think it will look right at home next to the other cabinets.
lets just hope I can make the ceiling paneling look as nice _________________ drive your split. |
camerod Volksfab
Joined: October 01, 2002 Posts: 606 Location: washington state
Posted: Thu Mar 20, 2014 11:48 pm Post subject: |
whoa! that patch really came out nice! _________________ DON'T SHIT WHERE YOU EAT! |
M183kombi Samba Member
Joined: February 01, 2008 Posts: 288 Location: Kearns, UT
Posted: Fri Mar 21, 2014 5:12 am Post subject: |
Holy awesome fix busman...that patch looks sweet...I love watchin' people take the time to do things right and preserving what you were given to work with... _________________ 1960 L31 M183 kombi |
bubba Samba Member
grailoc Samba Member
Joined: March 25, 2004 Posts: 1441 Location: FRANCE and now QUEBEC city
srfndoc Samba Member
Posted: Fri Mar 21, 2014 7:19 am Post subject: |
Damn speaker holes! I had two of those in my headbanger cabinet and took the easy route to fix them.... finding a replacement cabinet. Your repair looks great and all the cabinets still look matched to each other and appropriate for the rest of the bus. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Fri Mar 21, 2014 12:39 pm Post subject: |
Very cool. Good work Jake! |
adam beefcake bruno Samba Member
Joined: April 12, 2000 Posts: 246 Location: Spokane Valley, WA
Posted: Fri Mar 21, 2014 5:50 pm Post subject: |
Damn dude! That is true craftsmanship! Not like those wannabe's that buy some pre-made sorta-westy kit for their standard microbus.....oh, wait... _________________ Don't take life too serious....you won't get out of it alive! |
Posted: Fri Mar 21, 2014 7:28 pm Post subject: Very Nice |
Very Nice! |
Posted: Fri Mar 21, 2014 8:19 pm Post subject: |
Awesome job jake _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
sled Samba Member
Posted: Fri Mar 21, 2014 10:35 pm Post subject: |
Thanks!
only one more seat base to refinish and then its on to the wall/ceiling paneling! The snow has all but melted so I'm going to be itching to camp in this thing. The pressure's on. _________________ drive your split. |
nigel naughton Samba Member
Posted: Sat Mar 22, 2014 1:47 am Post subject: |
Man this is really really nice work! I can't wait to see it when it's finished. Good job documenting your work. |
