Bugs4Life Samba Member
Joined: February 17, 2007 Posts: 232 Location: Nor-Cal
Posted: Thu Feb 20, 2014 8:49 pm Post subject: |
AK 107017 _________________ 72 181 Ambulance
62 Ghia |
Rabid Irish Samba Member
Joined: November 26, 2010 Posts: 51 Location: Glyndon Maryland
Posted: Fri Feb 21, 2014 11:08 am Post subject: |
Looks like it is also missing the seatbelt hanging hooks in the rear that the military versions had. If I recall correctly they are identical to the front pair but the military versions also had 2 for the rear. I don't see the screw holes so maybe it was on later military versions, lol or I am just wrong all together. |
el_safari Samba Member
Joined: January 01, 2005 Posts: 375 Location: Nouvelle Aquitaine,France
Posted: Fri Feb 21, 2014 11:26 am Post subject: |
Rabid Irish wrote: |
Hi
No original hooks at the back ...Seen of pictures but not original _________________ La terre n'est qu'un seul pays |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Fri Feb 21, 2014 3:56 pm Post subject: |
Bugs4Life wrote: |
AK 107017 |
unless I am wrong and I have been before this is a replacement case that has a new number stamped in the case unless the military stamps new numbers in the case |
Posted: Fri Feb 21, 2014 9:38 pm Post subject: |
What I got from looking it up was October 1972. I sent info in on Birth Certificate to have it verified so will know for sure when it comes in. _________________ 72 181 Ambulance
62 Ghia |
Posted: Fri Feb 21, 2014 10:33 pm Post subject: |
Bugs4Life wrote: |
What I got from looking it up was October 1972. I sent info in on Birth Certificate to have it verified so will know for sure when it comes in. |
I looked at mine again and it looks like the correct stamp I guess it is just a odd case without a place to mount the skid plate. You still have a great thing I think everyone is just trying to make sure you have everything correct because this is a very special thing that all of us crazy thing owners would like to have enjoy it we would. |
ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 242 Location: St Louis, MO
Posted: Sat Feb 22, 2014 3:23 am Post subject: |
citroen wrote: |
I'll echo what Citroen says above, you definitely have a 'one off' car !!
I took a look at the Thing Shop PDF catalog, https://www.thethingshop.com/images/thing_shop_catalog_2013_1.pdf, it appears they may a few of the military tops left in stock, check page 15 of the PDF catalog for details.
'Hugo Boss' made a good note in reference to the front turn directional assemblies. From what I'm been able to determine, from 1968 to 1972 the military 181's used the same front turn directional assemblies as the 1968 VW Bug. |
Posted: Sat Feb 22, 2014 4:41 pm Post subject: |
Thanks I do appreciate the critique, not taking anything personal, I want the info and appreciate everyone chipping in and letting me know what needs to be fixed. I want her to be as correct as I can get her. Going with mechanical first, make sure she is a sound driver, took her out today did real well, kids and I had a blast, Very nice running car, motor has no hick ups, runs a little rich, and she is a little dirty.
G _________________ 72 181 Ambulance
62 Ghia |
HUGO bOSS Samba Member
Joined: April 27, 2008 Posts: 2602 Location: Madeira Island - Portugal
Posted: Tue Feb 25, 2014 5:09 pm Post subject: |
ente_kaefer wrote: |
Small correction... All european models (even Made in Mexico), civilian and military, only have that kind of turn signals... Mine is from 1978... and have them... _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=538182 |
Posted: Wed Feb 26, 2014 8:36 pm Post subject: |
Looking at the ad, the turn signals look to me like 1966 style turn signals. 68 style look to have the sides reaching farther back than the one in the picture. _________________ 72 181 Ambulance
62 Ghia |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Wed Feb 26, 2014 9:05 pm Post subject: |
If you are using Beetle lights you need 67-69 to have a double filament. |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Feb 27, 2014 6:42 am Post subject: |
Ron Domeck wrote: |
I used the early style single filament jobs on my conversion as I believe they look more authentic.
I run a resistor inline for the parking/running lights which limits the voltage to the bulb to around 8V. When you put on the turn signal, it gets the full 12V which causes it to blink brighter. 2 functions from a single filament bulb. Or you can modify the bulb holder for a dual filament bulb. |
Posted: Thu Feb 27, 2014 12:47 pm Post subject: |
I checked on the Military Tops The thing shop have, and they are orginal military tops on their Heavy duty Frames, My top, not original, is on an original frame, lol. So do I just keep what I have, or B. buy correct top on incorrect frame and sell what I have, or C. Buy correct top, take it off and put correct top on correct frame and sell other frame and top? Might go with getting fenders with correct tabs on them first or see how hard it would be to add tabs back to these fenders first.
Plus the turn signals. those are at least easy.lol _________________ 72 181 Ambulance
62 Ghia |
oasis Samba Member
Posted: Fri Feb 28, 2014 12:53 pm Post subject: |
Bashr52 wrote: |
I used the early style single filament jobs on my conversion as I believe they look more authentic. |
Your conversion looks authentically cool. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
Posted: Mon Mar 03, 2014 10:10 am Post subject: |
oasis wrote: |
Bashr52 wrote: |
Your conversion looks authentically cool. |
Thanks! |
Posted: Mon Jun 02, 2014 3:18 pm Post subject: |
Took Coolest Thing at Bugorama 73 with my 72 Military Thing.
62 Ghia |
Joe 20 Samba Member
Posted: Mon Jun 02, 2014 7:32 pm Post subject: |
I remember seeing it on Las Vegas Craigs list. You've sure got it looking nice. Congrats on your win!!! |
Posted: Mon Mar 02, 2015 10:24 am Post subject: 1972 1863 Military Thing |
Have some updated pictures of my car, she has some new parts, and cleaned up, waiting on a pair of original Military Seats to complete her. So far all electrical is working now, blackout lights, beacon, spotlight. original headlight rings and turn signals found, engine cleaned tuned, and rewired. Beacon support fabricated and attached, beacon pole repaired. excess wiring removed from car and a ton of other things. Hoping my seats get shipped this week and get here in time for Bugorama.
62 Ghia |
