rustednuggs Samba Member
Joined: June 29, 2008 Posts: 508 Location: Summerdale
Posted: Tue Feb 18, 2014 6:27 am Post subject: Gas line replacement guide? |
Hello - I have looked at a few posts and just making sure I fully understand this process as its very important. Replacing fuel lines!
I have a 73 Sportsmobile and the engine has dual carbs on it.
1.) Do I need to pull the engine to replace the fuel lines?
2.) Braided cloth fuel lines the best?
3.) New fuel filter with the little arrow facing the engine?
4.) A how to or good screen shots on how the lines get replaced? I was looking for something like the Bug-Me video but for the bus
Thanks in advance
Rustednuggs |
curtis4085 Samba Member
Posted: Tue Feb 18, 2014 6:54 am Post subject: Re: Gas line replacement guide? |
rustednuggs wrote: |
Thanks in advance
Rustednuggs |
There are a million threads on best fuel line. Cloth covered German hose people still use. Others like the gates barricade. Research and use proper size and style clamps if needed.
As for having to remove engine to replace lines that is highly unlikely! Being you have duel carbs you may have a hard to get to line if routed behind doghouse. But still doable.
Filter yes arrow goes same direction as flow, toward engine.
As for a video of how to just get in there and get your hands dirty. But first disconnect battery ground! Have sharp pair of clippers to cut new hose lengths. Use the old hose to measure your new lengths.
Make sure you use proper clamps for fuel hose. Here is a website a member posted recently that seems to have a good selection of hose and clamps.
https://www.belmetric.com/metric-hoses-multifuel-h...0olmklnfn6 _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1551 Location: Johns Island, SC
Posted: Tue Feb 18, 2014 7:05 am Post subject: |
The most difficult part will probably be trying to remove the firewall with the carbs in place. Since you'll be removing the firewall, I would also recommend checking the fuel hose and pipe from the refill to the gas tank. Those can sometimes begin to leak with age. Not sure if they are available any longer for the '73. Seems like German Supply had a replacement but can't remember if it would fit our year. _________________ My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia |
Posted: Tue Feb 18, 2014 7:15 am Post subject: |
barefootwestie - To remove the firewall that sounds like engine removal? Yes? "The fuel hose and pipe from the refill to the gas tank..its larger hose? I keep thinking about the one on the beetle. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Tue Feb 18, 2014 7:19 am Post subject: |
No you don't have to remove the engine to remove the firewall. And DO NOT use the cloth covered hose...it used to be the best there is, now it's absolute shit. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Tue Feb 18, 2014 7:20 am Post subject: |
No, i was able to remove mine with removing the engine. I do have a single carb but was able to remove the firewall without removing anything. Not sure about the dual carbs though. May be necessary to remove the carbs to make it easier.
Yes, the fuel refill is large like 2". Looks like this: Fuel Filler Rubber Hose Bus '72-'76 _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Posted: Tue Feb 18, 2014 7:30 am Post subject: |
Cool appreciate all the insight, but if the cloth braided lines are crap, what would one suggest I use. Can I get these @ Napa, Autozone, or Oreilly's?
Thanks
Rustednuggs |
Posted: Tue Feb 18, 2014 7:32 am Post subject: |
I replaced mine with fuel line from Advance Auto 7 years ago and haven't had any problems. I just make it a point to check mine several times a year. I don't recall ever hearing anything negative about Gates brand. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Posted: Tue Feb 18, 2014 7:34 am Post subject: |
Gate Barricade 30r14 low pressure hose. |
Posted: Mon Apr 14, 2014 10:43 am Post subject: |
Wondering also if the fuel filer should sit behind the firewall or under the bus. Currently its in the engine compartment. Like my beetle I would think that was a no no...and I should move it elsewhere.
Thanks in advance!
Rustednuggs |
Busdriver79 Samba Member
Joined: July 22, 2011 Posts: 1655 Location: The Peoples' Republic of "No" Jersey
Posted: Mon Apr 14, 2014 10:54 am Post subject: |
I used hose that was rated for high pressure fuel injection...a bit expensive, but it will last a long time...and yes, that cloth covered hose looks nice, but it's garbage compared to the FI hose. |
Posted: Mon Apr 14, 2014 10:58 am Post subject: |
Thanks in advance!
Rustednuggs |
I have no problem at all with a well located and mounted metal fuel filter in the engine compartment. |
busdaddy Samba Member
Thanks in advance!
Rustednuggs |
Better if it's under the bus a few inches from the tank outlet, the weight of the filter in the line to the carb tends to pull the fitting out and spray gas all over the engine. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Apr 14, 2014 11:01 am Post subject: |
Are those these filters?
http://www.busdepot.com/133133511
I am finding I have several different sized hoses under the bus for fuel delivery. Just a lovely job..
Anyone in Indiana want some free beer? Come help out. Of course I prefer we drink after we are done with the fuel line replacement!
Rustednuggs |
Randy in Maine Samba Member
Posted: Mon Apr 14, 2014 11:11 am Post subject: |
Those filters will be 7mm incoming and 10mm outgoing.
Have you been here?
http://www.ratwell.com/technical/FuelHoses.html
Also are you using the stock mechanical pump or does it have an electrical pump? You need to know what size the hoses are. One of those cheap little calipers from HF is nice to own < $10. |
Posted: Mon Apr 14, 2014 11:23 am Post subject: |
TheSamba just rocks! Yes I hav ebeen gathering numbers from that site to start looking for hoses. Thanks for heads up...electric pump |
Posted: Mon Apr 14, 2014 11:32 am Post subject: |
Also if I might ad...
Once you figure out the hose size, go down to NAPA and buy a metal filter for $5. Some of them are 1/4" (~5mm) on each side and some are 5//16" (~7mm) on each side. Put it before the pump under the bus, not in the engine compartment. |
Posted: Mon Apr 14, 2014 11:39 am Post subject: |
Sweet advice. I hope they have everything I need, fuel lines, clamps, and this filter!
Rustednuggs |
Posted: Mon Apr 14, 2014 12:00 pm Post subject: |
I like that Gates Barricade hose myself. |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Mon Apr 14, 2014 8:40 pm Post subject: |
Thanks in advance!
Rustednuggs |
Here is what the fuel filter looks like:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Fuel-Filter-Gold-/_/R-FIL3031_0322934988 _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
