theDrew Samba Member
Posted: Tue Feb 18, 2014 9:56 am Post subject: Oil Cooler Seals |
Hey Folks,
I've been fighting this oil leak for a few days now -- I've been searching and I'm outta ideas. I would call it rather significant. At idle its not noticeable, but at higher RPMS is a constant drip drip drip.
Pulling my hair out!
Background:
New Engine (2054cc)
26mm Shadek pump
Full flow, external filter
new oil pressure pistons and springs, they move freely.
I got an oil pressure gauge and pressures seem to be normal.
Brad Penn SAE30 oil
Breather box, both valve covers vented
Appears to be on the feed side of the oil cooler on the block connection. I've taken it apart a dozen times, new seals a couple of times -- I see nothing wrong w/ the sealing surfaces.
What am I missing? Any other thoughts? What else should I try?
Would something else block off oil flow through the cooler and thus cause the oil to blow out the seal?
Thanks for your help, I'm tired of dealing with this!
Off idle a little puddle forms here -- the fan is blowing the oil out.
Here is where the dribbles come down.
_________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
75smith Samba Member
Posted: Tue Feb 18, 2014 10:09 am Post subject: |
did you leak test the cooler?
you can run it for a little bit without the shroud, to see exactly where it is coming from- maybe longer if you run a couple fans over it, just make sure it is clean so you can spot the oil leakage _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
Posted: Tue Feb 18, 2014 10:30 am Post subject: |
75smith wrote: |
I haven't done that, but I see no evidence from the cooler itself, its all at the base.
I'll try and run it without the shroud and confirm. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Tue Feb 18, 2014 1:49 pm Post subject: |
Did you put in the proper oil cooler seals for your motor? There's about 3 different rubber gasket types I think. Only other thing I can think of is carefully and evenly torquing down the cooler.. _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
Posted: Tue Feb 18, 2014 3:00 pm Post subject: |
Volks Wagen wrote: |
Did you put in the proper oil cooler seals for your motor? There's about 3 different rubber gasket types I think. Only other thing I can think of is carefully and evenly torquing down the cooler.. |
The proper seals, yes -- this is all the late model stuff, so the 10mm seals are what I'm using. I am NOT using any washers/spacers.....maybe I should?
Also to torquing, I can't squeeze my torque wrench down in there, so I'm going by feel. Its possible they are not even. Just snug, right?
Thanks! _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Posted: Tue Feb 18, 2014 3:28 pm Post subject: |
theDrew wrote: |
Thanks! |
5ft/lbs on the 3 nuts, so not a lot at all. One other thing would be to check in case there's any crap on the 4 oil cooler seal surfaces as well. _________________ 1973 1303 with AB-motor - sporadic
Posted: Wed Feb 19, 2014 9:22 am Post subject: |
pulled it apart and looked it over again - the leak is definitely coming from the block/adapter surface. Just slowly oozes out.
I know sealant is not normally used there, but if I was to use some, what kind? _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Wed Feb 19, 2014 10:10 am Post subject: |
theDrew wrote: |
I know sealant is not normally used there, but if I was to use some, what kind? |
Try one of these.
http://vwparts.aircooled.net/SearchResults.asp?Search=oil+cooler+seal |
Posted: Wed Feb 19, 2014 11:13 am Post subject: |
use the above seal and some oil resistant non hardening sealant, VERY VERY little, you don't want it to get into the oil lines and such, so keep it about 1/4-1/2" away from the holes if poosible _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Thu Feb 20, 2014 10:40 am Post subject: |
Still no joy on this. I took it apart, cleaned everything and put it back together with new seals. Still leaks.
Then I pulled it apart again, cut out a gasket on some gasket paper and tried that (still with the original seals) and it still leaks.
Heh, I'm running out of ideas and patience! _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Cusser Samba Member
Posted: Thu Feb 20, 2014 11:22 am Post subject: |
Wow - I've never had any trouble with leaks there with stock oil coolers and correct seals. I wonder if the cooler itself has a hairline crack somewhere. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
BugMan114 Samba Member
Joined: March 22, 2007 Posts: 3744 Location: Ellenwood, GA
perhaps there's a slight gouge, or crack in the adaptor itself. or possibly warped. mayhaps try getting another adaptor and cooler. _________________ 1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!! |
Posted: Fri Feb 21, 2014 9:55 am Post subject: |
well the battle wages on.
got a new adapter and another new round of seals.
its much better but still seeing some seepage as I drive it. At least its moving in the right direction.
I guess pull it apart again? _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Cusser Samba Member
Posted: Fri Feb 21, 2014 10:44 am Post subject: |
Just make sure to tighten evenly. You are using the seals with the little shoulders, right? The ones that are "taller" in the middle, and look like flying saucers? Hey - don't assume that The Cuss has seen saucers !!!
Your oil pressure being "normal" really eliminates stuck oil pistons. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Wed Nov 19, 2014 2:41 pm Post subject: |
was this ever fixed?
I am having the SAME EXACT issue. I'm going insane.
Ive replaced the seals 3 times now
the oil cooler 2 times
And I will be getting a new adapter tonight and see if that fixes it..
I have the same leak, In the same spot. At the base. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Nov 19, 2014 4:12 pm Post subject: |
Thomas, are you using the correct seals? There were three different types.
Are you installing the metal spacers? like some of them require?
Tim |
Posted: Wed Nov 19, 2014 4:13 pm Post subject: |
Tim Donahoe wrote: |
Tim |
Yes Tim.
Turns out my block has a hairline crack.
I need a new engine case. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
Posted: Wed Nov 19, 2014 9:13 pm Post subject: |
Sorry to hear it.
Tim |
