1FUNBUG Samba Member
Joined: June 29, 2004 Posts: 599 Location: Waterville, OH
Posted: Sat Feb 22, 2014 3:14 pm Post subject: can I cut, weld my heat exchangers for modified heads? |
I could really use some advice from anyone that has had to weld, cut modify these Bus heat exchangers. Basically, I purchased these heads second hand. The step in the exhaust port stud location has been machined to the same level as the opening, for a custom exhaust. I need to find a way to get my heat exchangers to bolt up to them.
Here are some things I’ve pondered…
1. find longer studs and fab some spacers to make up the difference between HE flange and head.
I can’t find the right stud. The heads have an M9/M8 X 60mm stud now. Head is tapped M9.
2. Cut the excess off the heat exchanger.
That will affect how the HE’s bolt to the fan shroud. I don’t think this is doable.
3. Cut the flanges off the HE’s and weld new flanges on to create a mating surface to the head.
Sounds good. The local fab guy thinks the manifold is cast (based on these photos) and is concerned that welding might not be strong enough.
Any advice from firsthand experience is greatly appreciated.
[/img] _________________ 1FUNBUG
71 Beetle, 1776, dual Kadrons
77 Westy, Camper Special 2.0 F.I. |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sat Feb 22, 2014 3:40 pm Post subject: Custom Exhaust |
I would contact Chris @ www.tangerineracing.com since he has built a lot
of 914-4 exhaust systems and might have the 1979-1982 flat style flanges
that you could have welded on to your 72-74 heat exchangers.
Yes the flanges are cast and brazed to the pipes
Good Hunting _________________ V.W.owner since 1967 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Feb 22, 2014 4:16 pm Post subject: |
Or find some 79+ heat exchangers _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Sat Feb 22, 2014 5:05 pm Post subject: |
Quote: |
Basically, I purchased these heads second hand. The step in the exhaust port stud location has been machined to the same level as the opening |
1979 and later heads are what you have. You need earlier heads or later heat exchangers. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Feb 23, 2014 9:01 am Post subject: |
are the '79 heat exchangers "square port"? _________________ 1FUNBUG
Posted: Sun Feb 23, 2014 9:08 am Post subject: |
Posted: Sun Feb 23, 2014 9:22 am Post subject: exhaust flanges |
Yes the 79 -82 air cooled heads are square port
what was the reasoning for messing up this heads as the exhaust ports
look like someone was experimenting with D-shape _________________ V.W.owner since 1967 |
Posted: Sun Feb 23, 2014 9:31 am Post subject: Re: exhaust flanges |
old DKP driver wrote: |
look like someone was experimenting with D-shape |
I agree the port shape seems odd, but i would think that starting with square port manifolds would be easier than starting with oval port manifolds even if an adapter plate is necessary. The OP should get a square port gasket and set it over the studs to see how well it fits the opening. |
Posted: Sun Feb 23, 2014 11:38 am Post subject: Re: exhaust flanges |
From what I can tell, this was a machining option when ordering the head.
I'm going to explore getting some '79 heat exchangers first. I'll also email Chris at Tangerine. I'd like to think he could provide some flanges and gaskets if I need to modify the HE's that I have. _________________ 1FUNBUG
Posted: Sun Feb 23, 2014 11:50 am Post subject: |
If you are cutting them up anyways aircooled Vanagons will also provide donor flanges. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Sun Feb 23, 2014 11:55 am Post subject: |
I really don't get it. Why put a square peg in a round hole - why not just sell the heads and get the right ones? Or get the right exchangers? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Feb 23, 2014 12:03 pm Post subject: which cylinder heads? |
1FUNBUG
How about posting the part number that's is in the rocker box
These are all AMC cylinder heads
square port is 071 101 061 D 2 liter
oval port 022 101 061 G 2 liter
oval port 022 101 361 C 1.8 liter
oval port 021 101 361 K 1.7 liter _________________ V.W.owner since 1967 |
Posted: Sun Feb 23, 2014 1:11 pm Post subject: Re: which cylinder heads? |
1FUNBUG
oval port 021 101 361 K 1.7 liter |
I'm sorry but there are no numbers inside the rocker box on either head. I really need to make these heads work. On the positive side, I won't have to deal with copper sealing rings. _________________ 1FUNBUG
Posted: Sun Feb 23, 2014 1:40 pm Post subject: what Heads? |
What were the heads sold to you as
got a picture of the combustion chambers? _________________ V.W.owner since 1967 |
1967250s Samba Member
Posted: Sun Feb 23, 2014 4:06 pm Post subject: |
How about making an aluminum plate that would mount on the exhaust port with the hole cut out for a proper copper gasket, dab of grease to hold the gasket, mount exh> Or: cut 4 pipes and shape them to the ex manifold, long enough to extend a little past the mount surface, then slip in the copper gasket in the recess, mount it up then. This will leave a lot to be desired: the ports will not be matched up with the oval manifold, so not optimum flow, likely to get build-up, and hot spots. Also,a questio how the shimming would affect the muffler mounting as these would alter the muffler/flange geometry. My 2 pence. |
Hoody Samba Member
Posted: Sun Feb 23, 2014 4:26 pm Post subject: |
Those look like oval port heads that someone effed up try to get square port exchangers to fit or vice versa. Realized they destroyed the heads and then sold them to you with some BS story about a custom exhaust. It will be better and cheaper in the long run to start over with some oval port heads. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sun Feb 23, 2014 4:47 pm Post subject: |
I have square port heads on my 2L engine in my '74 and I just carefully cut the top oval part off oval port heat exchangers, filed them flat and they bolted up to the square port heads. The exhaust and everything else lines up and fits as it should. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Hoody Samba Member
Posted: Sun Feb 23, 2014 5:01 pm Post subject: |
Yup that's a mod that some people do and does work. But those heads are now neither square nor oval port. Who ever milled those must have been drunk or totally clueless. |
HAM Inc Samba Member
Joined: May 09, 2011 Posts: 161 Location: Watkinsville,GA
Posted: Tue Feb 25, 2014 9:48 am Post subject: |
Hoody wrote: |
Seriously?!
Since you don't know what the hell you're talking about you should just shut the hell up and stop worrying this poor guy.
The ports are stock sq ports, un-altered in any way from the factory specs. If they are indeed my Camper Special heads then they will have been built to those specs with all port work confined to the bowl area with none done in the the sq port exit where the exhaust bolts up, as the pic shows.
It's amazing to me how many people who have zero experience with something will chime in like they do. It's the single biggest problem with the internet. _________________ Len Hoffman
Hoffman Automotive Machine Inc.
www.hamheads.com |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Tue Feb 25, 2014 9:55 am Post subject: |
SGKent wrote: |
I really don't get it. Why put a square peg in a round hole - why not just sell the heads and get the right ones? Or get the right exchangers? |
_________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
