SixVolt Samba Member
Joined: January 04, 2004 Posts: 1136 Location: Cleveland, Ohio
Posted: Tue Feb 25, 2014 3:40 pm Post subject: Are these '57 down or 58-64 rear brakes? |
I'm trying to ID what braking system (57 down) or (58-64) is w/ this transaxle.
The number on the trans (as you can see below) is A1302935 which appears to put it at the end of the '57 model year. According to the samba technical info, the first '58 beetle would have had chassis # 167038 and the trans would have been A1324871. That's later than my trans number, but I don't know if they matched chassis # and trans #'s for production date accuracy.
According to the Wolfsburg site, up to chassis # 1673410 use through '57 brakes. The start of the 58-64 brakes begins with Chassis # 1673411. This suggests they used early 57 brakes on the early 58 beetles???? Does that make sense????
So what do these look like to you? Before I order replacement stuff, I better ask.
Here's the trans number, although I realize even if its a 57 someone could have changed the backing plates and drums.
I've searched around and found a few informative threads. But they don't tell me what I have.
http://www.thesamba.com/vw/forum/viewtopic.php?t=443671&highlight=5864+rear+brakes+oval
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...mp;start=0
http://www.thesamba.com/vw/forum/viewtopic.php?t=563306&highlight=ebrake
I know the e-brake sizes are different:
1958-64 measures 1752mm in length
1956-67 measures 1789mm in length
Bob Loblaw Samba Member
Joined: August 17, 2008 Posts: 865 Location: Vancouver Island, Canada
Posted: Tue Feb 25, 2014 4:02 pm Post subject: |
2 bolt wheel cylinder tells me up to '57. _________________ sent from a phone using poor grammar and spelling |
lucille66 Samba Member
Joined: June 29, 2008 Posts: 633 Location: ORANGE COUNTY
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
ngobet Samba Member
Joined: September 04, 2007 Posts: 96 Location: Switzerland / California
Posted: Wed Feb 26, 2014 1:42 am Post subject: |
I just put some 63 brakes on my split case. Perfect fit with 63 e-brake cables. I used the 56 bearing cover.
The front brakes fit easy as well and the shoes are larger too. Nice improvement.
Posted: Thu Feb 27, 2014 9:19 pm Post subject: |
Great info! Many thanks! |
Posted: Wed Jul 16, 2014 2:02 pm Post subject: |
I got sidetracked with other projcts but I need to get this done. This is a '57 beetle. I swapped out the later leaking trans for a known good '57 original. Replaced the shocks while I was in there. I'm using the '58-'64 brakes but I have a couple questions.
There are two diagrams floating around on this site one showing that you use the gasket and one showing no gasket. SInce I'm using the '58-'64 brakes with the '57 tranny should I use the gaskets?
Here's the seal kit I have.
I'm not sure how clean the face of these contact points are supposed to be, but do these look clean enough? Do I use Indian Head or Aviation Permatex?
Appreciate any comments or advice. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Fri Jul 18, 2014 7:35 pm Post subject: |
SixVolt wrote: |
That looks like the pre-'58 backing plate!
Don't forget the oil slinger for your 1957 drums! _________________ Jesucristo es mi Seņor y Salvador! |
