Left tire hopping and grinding
robcon
robcon is offline
PostPosted: Sat Mar 01, 2014 10:42 am    Post subject: Left tire hopping and grinding Reply with quote
Own a VW aircooled trike,pulled out and the left rear tire started hopping and grinding,Bike would not move unless the hopping and grinding started again.Trans is a Swingaxle,any help greatly appreciated,thanks
BL3Manx
BL3Manx is offline
PostPosted: Tue Mar 04, 2014 9:25 pm    Post subject: Reply with quote
Check these things in this order. Stop when you find something broke; Check the tightness/security of the axle nut. Remove the nut, pull the drum and check brakes. Check the splines in the drum and on the axle. Check the spacer and the outer bearing. Pull the axle tube and axle shaft. Check the axle spade ends. Check the fulcrum plates. Check the axle side gears.
If the grinding/shaking isn't caused by one of these components, then its inside the trans. If you find the problem fix it and reassemble everything following the manual, installing all required seals, gaskets and O-rings and torquing as per the manual.
robcon
robcon is offline
PostPosted: Wed Mar 05, 2014 2:41 pm    Post subject: swing axle trans Reply with quote
can the axle be pulled without removing the engine and trans?This is on a trike and have plenty of room to work.
BL3Manx
BL3Manx is offline
PostPosted: Wed Mar 05, 2014 11:52 pm    Post subject: Reply with quote
Yes absolutely, I've done it in junkyards when I just want a pair of 67-68 long axles and tubes. The drum and backing plate have to come off and the bearing needs to be pulled off the axle. The axle tube end casting needs to be unbolted from the spring plate and shock and then pulled back free of the springplate. Take the nuts off holding the side cover to the trans and slide the tube off the axle. To get the axle out of the side gears/fulcrum plates you need a quality pair of larger snap ring pliers. When the snap ring is removed, the axle, fulcrum plates and side gear can be removed.
robcon
robcon is offline
PostPosted: Thu Mar 06, 2014 7:46 am    Post subject: Reply with quote
Thanks for all the input,really appreciate the help and direction.
robcon
robcon is offline
PostPosted: Thu Mar 13, 2014 3:35 pm    Post subject: hopping and grinding problem resolved Reply with quote
Turns out it was the snapring that kind of holds the axle in place in the trans,it was just free spinning,mechanic said it was his mistake but also said it could happen again because the groove looked a little worn.Thanks for all the help and info,Who would have thunk it?
