tncsparky Samba Member
Joined: November 29, 2008 Posts: 703 Location: santa rosa
Posted: Fri Mar 07, 2014 10:41 am Post subject: flex air line for compressor, Need ideas |
So my father inlaw has a crafstman compressor that feeds 3/4 pvc (i know) for all his air needs. I think the max psi is 175? Or maybe its 150 .
So a friend give him a new Speedaire refrigerated air dryer.
I get to install it.
I would like to make the hook ups with a short flexible piping to minimize vibration.
I was thinking of using the copper supply lines for a water heater but didn't know if there was anything better
Any ideas? _________________ "My Daddy told me, son if your stupid today you will be stupid tomorrow"
scotth17
I think you are just waiting around for a high-five from a unicorn so you can feel better about yourself |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Fri Mar 07, 2014 12:53 pm Post subject: |
Why not just use standard fittings and a standard rubber air hose? If you don't have a short enough hose try to find a hydraulics place in your town. They will be able to shorten it for you and put new ends on usually for just a couple dollars.
As for the PVC, I have used PVC for many years in our medical instrument repair shops. We only ran 40psi of line pressure. In 25 years of doing this we only had one blow up and I think that was mainly due to a poor glue job. BUT it was one heck of an explosion! Fortunately it was above the drop ceiling in the lab so no one got hurt but it sure scared the crap out of everybody in the place. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Fri Mar 07, 2014 1:19 pm Post subject: |
I wasn't sure of what to use. That is just what came to mine
I think the inlet and outlet are 1" on the unit and the piping is 3/4.
Can I get short 3/4 hose cheap? I would only need 24" on the in and out of the machine _________________ "My Daddy told me, son if your stupid today you will be stupid tomorrow"
scotth17
jspbtown Samba Member
Joe Bence Samba Member
Joined: March 14, 2004 Posts: 501 Location: San Diego, CA
Posted: Mon Mar 10, 2014 12:20 pm Post subject: |
My local auto body supply shop make/sells custom air hoses, they just have bulk hose and the correct ends (not barb). |
Posted: Mon Mar 10, 2014 4:40 pm Post subject: |
Is there really a need for ¾” hose? Unless you have a really big demand for volume, most standard air hose should be more then enough.
In our shops we used the ¾” PVC fittings and stepped down with a ¾” O.D. bushing that had ¼” ID pipe thread which is standard size for most air line fittings. Quick, simple and easy to find. Then we could just install and use the standard quick disconnect air line fittings on the rubber hose between the compressor and wall pipes, or in your case between compressor and the refrigerator drier. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Mon Mar 10, 2014 7:08 pm Post subject: |
I ordered hose to hook it up. Thanks for the help. _________________ "My Daddy told me, son if your stupid today you will be stupid tomorrow"
scotth17
Posted: Sat Mar 22, 2014 6:53 pm Post subject: |
A few days ago i made a comment in this post about using PVC for air lines and how I had only ever had one failure that we believed was a bad glue joint.
Today all that changed!
I have a PVC line running from the garage into my house where it feeds my repair lab as well as my machine shop. I only ever run 40psi in those lines. I have another compressor in the lab to run higher pressures when we need them, but it just feeds directly into the rubber air lines.
Some of the guys were here today getting ready for race day tomorrow and somebody plugged the flexible line that feeds the house into the filtered, unregulated fitting on the water separator/regulator.
I was downstairs on the computer when there was a GIANT explosion that rocked the whole dang house!
The PVC line in the house exploded. Blew plastic shards EVERYWHERE! Did a lot of damage and scared the crap out of me.
That unregulated line coming off the garage compressor usually has between 150 and 200psi in it. Looks like that PVC pipe couldn’t handle that much pressure!
I guess I need to rethink using that stuff where we may have that sort of mistake happen again. We’re fortunate no one was in that room when it blew up because the plastic shattered like a hand grenade. _________________ Mother Nature is a Mean Evil Bitch! |
Plantman Samba Member
Joined: July 12, 2004 Posts: 688 Location: Brevard,NC
Posted: Sun Mar 23, 2014 10:25 am Post subject: |
Glad no one was hurt. Would PEX work for air lines? I know it is a lot stronger than PVC and easier to work with than steel. Just curious.
David _________________ Every day may not be good, but there is something good in every day,
No matter where you go, there you are.
'69 bug & '71 Ghia |
Joined: January 01, 2007 Posts: 16886 Location: sticksville, ct.
Posted: Mon Mar 24, 2014 7:50 pm Post subject: |
https://www.rapidairproducts.com/rapidair.asp _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Tue Mar 25, 2014 12:49 am Post subject: |
We used 3/4 pvc in our shop at 150 psi for 20 plus years. We did have one explosion due to a car jumping off the four post hoist (don't ask) and slamming into the wall and pipe. It was a BIG bang when it let loose and it could have hurt someone. Not sure if I wold use it again or not. |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Wed Mar 26, 2014 8:17 pm Post subject: |
I use a 1/2" Flex Line to minimize vibration, works great. My compressor is outside the shop and I didn't want the "Squeak" of a airline coming thru the wall. Its about 30 years old at this point but still works great. We run max 150 PSI at 24CFM (sandblasting). A current Grainger part number for my type of Flex line is 4DXN6 @ $25.00 - 1/2 x 1/2 x 12" Stainless.
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Sat Apr 12, 2014 8:28 am Post subject: |
I hope anyone foolish enough to use PVC in a compressed air system doesn't have anyone other than himself in the immediate vicinity, because I hate when innocent people are harmed due to the ignorance or sheer stupidity of others.
Fluids cannot be compressed while gasses can. Using PVC in compressed air systems is akin to playing Russian Roulette with a fully automatic handgun.
PVC pipe not to be used in compressed air systems
OSHA Hazard Information Bulletins
The Use of Polyvinyl Chloride (PVC) Pipe in Above ground Installations
Oregon OSHA Fact Sheet (great "After" images)
The solution is one of the following:
Copper
Black pipe
Flexible Aluminum
There are flexible compressed air pipe systems available with specifically engineer plastic pipe. Take the time to search. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
